Two23 Offline Upload & Sell: Off
p.1 #19 · Wireless Flash on the Cheap! RF-602 | |
I do a lot with off camera flash, at night. I've owned Skyport triggers in the past and currently own x10 CyberSyncs and X2 PW-II. I light up big stuff (freight trains, canyons, grain elevators) with either SB-28 flash or X3200 monolights. I'm familiar with most of the current triggers out there. I am a Strobist.
The RF-602 are probably the best of the low cost triggers available at the moment. They are reasonably reliable (90+%) and most people report range out to at least 100 ft. There are a LOT of variables affecting range. These are simple triggers in that they will fire a flash in sync with the camera. They don't do any TTL, but for most people that's not a big deal. You need flash that has manual mode is all. They use the 2.4gHz band, which is legal. I haven't tried them, but I would expect them to easily be able to trigger two flash at once, if not more. They are basically a simple switch. For someone just doing portrait type stuff they are actually very highly regarded.
I have gone with CyberSyncs, mainly because they have relay mode. That allows me to nearly double the range and I can fire a flash out to 800+ feet. When I need to fire flash from even farther than that (and many times I do) I hook a pair of PW-II triggers in tandem with the CyberSyncs. The CyberSyncs are very rugged and I know they work at 32F below zero. The RF-602 might, I haven't heard of anyone using them like that though. The CyberSyncs will also reliably trigger a Nikon camera, something I use them for. Not sure if the RF-602 do or not.
I will give a word of warning. Radio triggers are being called a "gateway drug." Once you start buying a few them, it's hard to stop. I started with x3 Skyport triggers and three NIkon SB flash. Three years later I now have x12 triggers, x7 monolights, x10 SB flash. If you think buying cameras gets expensive, wait until you start buying lighting system! I've put a couple of my shots here on the Nikon forum titled, "Trains As Art."
Kent in SD
