PhotogDave Offline Image Upload: Off
Tom_W wrote:
helimat wrote:
I don't use NR much at all, but I did notice recently that on the newer versions of DPP the sliders are at a 'suggested' position based on the image, I am guessing calculated by the ISO used and perhaps the histo.
The NR settings in DPP are based on the camera's ISO setting and the camera's "high ISO noise reduction" setting. I gathered the following data from the 7D at ISO 3200:
NR off: Lum - 4; chrom - 8
Low: Lum - 4; chrom - 11
Std: Lum - 5; chrom - 12
High: Lum - 6; chrom - 12
At ISO 1600:
Low: Lum - 3; chrom - 10
At ISO 800:
Low: Lum - 3; chrom - 5
I didn't gather any other information at the time from the 7D. Interestingly, the same type of settings are used on the 5D2, but with considerably different values. At ISO 3200:
Low: Lum - 5; chrom - 6
The old 5D seems to be permanently set at Lum - 2; chrom - 0 regardless of ISO setting.
I wish that I could plug Noiseware into DPP. Just a few days of playing with the community edition showed me that it is a superior noise reduction program, but as far as I know, it only works with JPG and TIF images. Perhaps if I had a paid-for version, I'd have more compatibility.
Never tried Noiseware, having read your statement, I went, downloaded the trial, and gave a few TIFFS a run thru....gotta say I was very surpised at the results.
I have used Noise Ninja and Capture One in the past, and while yes the noise is gone, so was fine detail. I used Noiseware and it seems that it can pull most all of the grain, but manages not to effect even the single stray strands of hair. They were left untouched. I was quite shocked.
This may actually be a purchase coming. C1 IMO seemed to be heavy on NR and sharpened to make up, but when viewing close, you could see the fine details looked like clay at that point...so I abandoned C1. NN ddi the same, but worse.
This program actually seems to know where to pull noise and where to leave alone.
Cool. I have 14 more days to see if this thing will be a new tool for me.
