Archive 2009 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
RustyBug
p.1 #1 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Does anybody have any input regarding the Leica 24mm 2.8 Elmarit R?
Nov 02, 2009 at 04:31 PM
mMontag
p.1 #2 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
I researched the Leica 24 some time ago - not one of Leica R strong points - I believe it has adapter problems with some cameras. Check pebbleplace for adapter feedback info.
Nov 02, 2009 at 05:26 PM
mawz
p.1 #3 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
The Leica is a rebadged Minolta MD 24/2.8. Good but not great.
I'd say the real question is ZE/ZF 25 vs the Oly 24.
Nov 02, 2009 at 06:28 PM
Sam N
p.1 #4 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
I just got the Oly 24/2.8. I haven't done extensive testing but it seems very sharp so far. Vignetting seems fairly high at f/2.8, but it is the smallest SLR lens I own by far.
Edit there's a comparison of the Oly 24 vs other lenses here:
http://www.16-9.net/lens_tests/24mmcup/final/24mm_final1.html
Not bad for a lens that costs 1/10th as much as a 24L.
Nov 02, 2009 at 07:22 PM
Paul Yi
p.1 #5 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Zuiko 24/2.8 is so small and compact, and yet pretty sharp...
It's great for hiking......you can practically carry in your pocket.....
Nov 02, 2009 at 07:49 PM
JohnJ
p.1 #6 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
I've had the Leica R 24 for over 10 years now and have shot many magazine DPS (double page spreads) and covers with it when I was using Velvia 50. As others have said it may not be the sharpest tool in Leicas shed but it doesn't deserve the bad rep it seems to have. Who cares if it was designed by Minolta? By way of comparison, I also have the current R 28 and the R 24 does not have the same level of resolution.
I tried the Contax Zeiss 25 and although it seemed like a decent lens it was not impressive in any way. I haven't tried the Olympus 24/2.8.
The Leica R 24 won't work on 1dsMk2 so it won't work on other FF bodies. It works fine on my 40D where I tend to use it wide open and the crop still gives me an image with excellent sharpness overall although you can already start to see some falloff in sharpness in the corners. The lens performs best around F8, as do most lenses of this kind.
JJ
Nov 02, 2009 at 08:54 PM
Lotusm50
p.1 #7 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
The Zeiss ZF/ZE 25mm is a significant improvement over the old Contax 25mm.
Nov 02, 2009 at 09:50 PM
RustyBug
p.1 #8 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Thanks everyone ...
I've got the Oly 24 2.8 ... I like its colors & I like the 3D ness of Zeiss. Was wondering if maybe the Leica might sit somewhere between the two.
Nov 03, 2009 at 04:33 AM
thrice
p.1 #9 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
the difference between 25mm and 28mm is tiny! I have a 25/28 accessory viewfinder from zeiss and the gap is about one step back or forward! So I would consider the Leica 28mm (if the funds stretch that far) or the new Zeiss ZE 28/2 as well
Nov 03, 2009 at 05:59 AM
alexandre
p.1 #10 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Kent, good choice
Nov 03, 2009 at 09:30 AM
Empire
p.1 #11 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Second that.
I have had two Om 24/2.8's and have been unanimously impressed. They have Red-Green CA but it is extremely easily corected.
Reportagé
'scaping @ 5.6 or thereabouts
Did I mention that it's sharp? (hand held @1/30th no less)
Nov 03, 2009 at 05:01 PM
Empire
p.1 #12 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Since I'm posting images, may as well make it an extravaganza
Nov 03, 2009 at 05:12 PM
RustyBug
p.1 #13 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Thanks all.
Thrice ... moving the subject (er, discussion) toward 28mm, I had my eye on the C/Y 28mm 2.8. How would you compare that to the Leica 28mm?
Nov 03, 2009 at 05:17 PM
Empire
p.1 #14 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
While the CY looks great, might I recommend a Zuiko 28/3.5? It's sharp as nails and costs less than a carton of beer. Cheap fun!
It's my take-with-while-drinking lens
Nov 03, 2009 at 05:50 PM
cjfromaustin
p.1 #15 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Paul Yi,,, Perfect Exposure.....
Nov 03, 2009 at 05:54 PM
RustyBug
p.1 #16 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
+1
Paul's got that 'foggy / misty' exposure nailed down
Nov 03, 2009 at 05:59 PM
davidearls
p.1 #17 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
+1 for the Zuiko 28 f3.5. When I did side-by-side comps with my C/Y 28 f2.8, the Auiko won it hands down, and even with the lowered price on the Zeiss, the Zuiko is a fifth the cost -
Nov 03, 2009 at 08:25 PM
RustyBug
p.1 #18 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
The Zuiko has more 3Dness than the Zeiss ?? ... and still has Oly colors ??
Nov 03, 2009 at 09:49 PM
davidearls
p.1 #19 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Kent,
I don't find a lot of "3D" in the Zeiss 28. It's a very sharp "edgy" kind of look. It's not as sharp into the corners FF as the Zuiko, but that may not matter on your 1DII crop body - haven't seen it there.
Nov 03, 2009 at 11:12 PM
Jim Schemel
p.1 #20 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
I have just picked up a used copy of a Zeiss Contax 28mm f2.8 lens.My first impressions are this is an impressive lens.I see no distortion, and CA is non existent.Sharpness and color are a given.Few Samples below
-Jim
1. at 2.8
2.
3. Pano of 4 images -
4.
Nov 03, 2009 at 11:42 PM
RustyBug
p.1 #21 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Thanks,
Recommendations for more 3Dness if not the 28mm 2.8 C/Y ??
Nov 04, 2009 at 12:52 AM
Sam N
p.1 #22 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
Everyone's definition of 3D-ness will be different even if it is a real thing. I don't think someone could prove one 24/28mm lens has more of it than another.
Nov 04, 2009 at 07:15 PM
Lotusm50
p.1 #23 · Leica 24mm vs. Zeiss 25mm vs. Oly 24mm
RustyBug wrote:
Thanks,
More 3D than the 29/2.8 c/y?? Perhaps the Zeiss 28/2.0...
Nov 04, 2009 at 08:38 PM
