Moderated by: Tom Hicks
Macro World Resource
FM Forums | Macro World | Join Image Upload
MPE-65mm back from Canon service Go to previous topic Go to next topic
Dalantech
Image Upload: Off
p.1 #1 · MPE-65mm back from Canon service
The funny thing is that after shooting with the EF-S60mm and tubes it took me several frames to get use to focusing the MPE-65 again -odd since the focal length is almost the same!?
Life size @ F13:
4x @ F10:
Oct 30, 2009 at 03:21 PM
Kenj8246
Image Upload: On
p.1 #2 · MPE-65mm back from Canon service
Congrats on getting your MP-E back. Love the warmth in these, second frame is another wowzir.
Kenny
Oct 30, 2009 at 03:25 PM
Dalantech
Image Upload: Off
p.1 #3 · MPE-65mm back from Canon service
Thanks Kenny
Good to have it back -I had a lot of fun this morning shooting with it
Oct 30, 2009 at 03:39 PM
lauriek
Image Upload: Off
p.1 #4 · MPE-65mm back from Canon service
I suspect the MPE shortens it's focal length as you extend it, as far as I can tell there's not enough extension for 5x at the full 65mm (That would require over 30cm of extension).
Great shots, love the comp of the wider shot...
Oct 30, 2009 at 08:10 PM
Dalantech
Image Upload: Off
p.1 #5 · MPE-65mm back from Canon service
Thanks Laurie
Not sure what it's focal length is at high mag, but I suspect you're right.
Oct 30, 2009 at 08:15 PM
Zichar
Image Upload: Off
p.1 #6 · MPE-65mm back from Canon service
Congrats on getting it back. The compo in #1 is great, and I appreciate it more reading that you don't crop (should have guessed it from the name of your blog, and after so long *doh*). Have so far found it very hard to shoot the compo already worked out in my mind, than resorting to PP later.
It would be really nice if you could oblige this FM forumer's request to still bring out the 60mm for a whirl every now and then?
Oct 31, 2009 at 02:59 AM
LordV
Image Upload: Off
p.1 #7 · MPE-65mm back from Canon service
Lovely captures - looks like the lens is fine now
Any comment from the service people on what was wrong ?
Brian v.
Oct 31, 2009 at 07:03 AM
Dalantech
Image Upload: Off
p.1 #8 · MPE-65mm back from Canon service
I had two equipment malfunctions this year (had to replace my MT-24EX and send the MPE-65 in for repair) so in the last two months I just got around to making a couple of changes that I should have made earlier in the year. One of them is to take two shots, one for the web and a slightly reduced magnification for print. I have a bad habit of cropping a little too tight with the view finder, so that when I go to mat or gallery wrap a print the critter is getting cut off. In hind sight I probably need to spend more time at lower magnifications anyway...
Still in my bag, and it still have 37mm of extension tubes on it
Oct 31, 2009 at 07:07 AM
Dalantech
Image Upload: Off
p.1 #9 · MPE-65mm back from Canon service
Brian v.
Thanks Brian I just need to sort out my lighting again -had everything adjusted for the EF-S 60mm and the angles I had the flash heads set to didn't work well for the MPE.
There was a repair list included with the lens and this is from the tech who worked on it:
"We have examined the product according to your request and it was found that the part was loose causing error 01 to be displayed. The power diaphragm ass'y and others were replaced. Checked all, adjusted center/tilt/focus & cleaned all factory specs."
I think "the part" was the cable that runs between the lens contacts and the power diaphragm. The cool thing is that Canon only charged me for labor, so maybe they viewed the "the part" being loose as a manufacturing defect.
Oct 31, 2009 at 07:22 AM
michael kilner
Image Upload: Off
p.1 #10 · MPE-65mm back from Canon service
lovely shots,have you changed your light?
Oct 31, 2009 at 03:12 PM
coder
Image Upload: Off
p.1 #11 · MPE-65mm back from Canon service
Really like #1!
Oct 31, 2009 at 04:44 PM
Dalantech
Image Upload: Off
p.1 #12 · MPE-65mm back from Canon service
Thanks Michael and Daryl
Yup, redesigned my diffusers.
Nov 01, 2009 at 03:33 PM
Lost password?
