Archive 2009 · sandbag filler?
s14brent
p.1 #1 · sandbag filler?
i was hoping to maybe find/use a heavier filler than sand, I was thinking about bb's or like lead (which would probably be more than i want to spend honestly) but yeah anyone use anything besides sand? TIA
Oct 22, 2009 at 09:45 AM
lou f
p.1 #2 · sandbag filler?
you can go half and half.
Oct 22, 2009 at 10:45 AM
Greg Feldman
p.1 #3 · sandbag filler?
Lead is not good for you. Not even a little.
Consider using two sandbags. It's a modular system that way.
Oct 22, 2009 at 03:15 PM
HerbChong
p.1 #4 · sandbag filler?
steel shot isn't that expensive and is denser than sand. B&H sells that, i think, designed specifically for use in lightstand sandbags.
Herb...
Oct 22, 2009 at 03:34 PM
cwebster
p.1 #5 · sandbag filler?
I use BBs (copper plated steel) purchased at my local sporting goods shot for small bags (4-5 lbs), but for large bags (10-15 lbs) I use sand. Anything else is just too expensive in those quantities.
<Chas>
Oct 22, 2009 at 05:14 PM
Todd Warnke
p.1 #6 · sandbag filler?
You can get used steel shot from shooting ranges for next to nothing. Works great.
Peace,
Todd
Oct 22, 2009 at 05:28 PM
Cicopo
p.1 #7 · sandbag filler?
It's been many years since I bought mine but I found some nicely made weight bags in 1, 2 & 5 pound size at a dive shop. They are a nylon (or something similar) mesh bag with small lead balls inside, and from what I've read the lead is sealed inside a coating to prevent ecological damage. I don't remember prices, but they weren't expensive to me. They are easy to handle & transport, and even the 5 pounder is not very big.
Oct 22, 2009 at 05:32 PM
runamuck
p.1 #8 · sandbag filler?
wet sand
Oct 23, 2009 at 03:17 AM
borderlight
p.1 #9 · sandbag filler?
water or pea gravel
Oct 24, 2009 at 02:31 PM
cwebster
p.1 #10 · sandbag filler?
Barry Pehlman wrote:
water or pea gravel
I like the concept of using water bags, but don't want the possibility of a spill around electrical equipment, much less in my hardwood floored studio.
Shot or sand "borrowed" from a local playground for the bigger (15#) bags.
<Chas>
Oct 24, 2009 at 03:51 PM
Tomser
p.1 #11 · sandbag filler?
Silica sand is quite a bit denser than regular sand, and inexpensive.
Oct 25, 2009 at 07:12 PM
runamuck
p.1 #12 · sandbag filler?
Fine dust from silica sand can cause silicosis, bronchitis, and even cancer.
Oct 25, 2009 at 08:27 PM
Tomser
p.1 #13 · sandbag filler?
So does the air in any major city, what's your point ?
Seriously, you are plain wrong, unless you do sandblasting for a living.
Oct 26, 2009 at 06:35 PM
harrygilbert
p.1 #14 · sandbag filler?
Lead won't hurt you unless you eat it, or handle it and lick your fingers - again and again. I use lead shot from a local sporting goods store. Been casting lead fishing sinkers from old wheel weights for over 20 years and have no ill effects.
Nov 13, 2009 at 02:37 AM
wickerprints
p.1 #15 · sandbag filler?
No, I don't think you quite understand the hazard. Silica sand is extremely fine. Inhalation of silica dust particles causes them to become lodged in the alveoli, where coughing cannot expel them. Over time, this damages the lungs, causing shortness of breath, reduced oxygen capacity, and increases risk of lung cancer, much in the way that asbestos does. Damage due to exposure is cumulative and irreversible. By your reasoning, one would not have any problem inhaling asbestos fibers.
As a ceramic artist who works with such materials, it is something that I had to educate myself about. Some notable ceramic artists such as Warren MacKenzie have developed silicosis in their later years. Granted, the level of exposure is many times greater than what I presume would occur with incidental usage in sandbags, but let's just put it this way--there are equally effective and less hazardous materials available, so why not use those instead?
Non-lead shot is commonly made from metallic bismuth, which has relatively low toxicity but is high density. This would be ideal for an indoor studio setting, where portability is not a major concern.
Nov 13, 2009 at 03:04 AM
wickerprints
p.1 #16 · sandbag filler?
The problem with lead is that it is a very soft metal that leaves traces on everything it touches. You can wash your hands and be fastidious about it, but you are still exposing yourself to tiny amounts which, over time, accumulate in the body. If you had a blood panel done you may find that your lead levels are higher than normal. By the time you notice symptoms, your lead exposure is already extremely and dangerously high.
It's a bit like seeing jaundice as an indicator of liver failure. By the time the whites of your eyes turn yellow, you are already severely impaired. Many symptoms of heavy metal poisoning are not apparent until the concentration is extremely high, and by then it is too late.
Nov 13, 2009 at 03:15 AM
harrygilbert
p.1 #17 · sandbag filler?
In theory, everything you say is true. In practice, if you take normal precaustions, my experience is that risk is minimal. Because I cast lead (in a ventilated environment), I do have periodic tests, and have always come up well below any danger levels.
Nov 13, 2009 at 10:23 PM
Peter Le
p.1 #18 · sandbag filler?
Dried Beans......
Nov 14, 2009 at 05:11 AM
Roland W
p.1 #19 · sandbag filler?
One Cent coins cost a little less than $2 per pound, so that is an option. Higher cost than most fillers, but clean, and you can get your money back any time. One Cent coins are mostly zinc, and lead and zinc both cost about the same amount per pound as raw materials, at around $1 per pound.
Nov 14, 2009 at 03:48 PM
Tomser
p.1 #20 · sandbag filler?
You are right that I'm by no means an expert in that matter; but when one uses silica sand as a filler for sandbags , he's not working with it, it is kept in a tightly sealed container (sandbag) all the time.
If the bag is leaking sand, in a photo studio, you will do something about right away, trust me.
Nov 14, 2009 at 06:22 PM
E-Vener
p.1 #21 · sandbag filler?
steel shot, If you are making your own sandbags make sure you put a heavy weight zipper on the ballast compartments.
Nov 14, 2009 at 06:54 PM
wickerprints
p.1 #22 · sandbag filler?
Which is why I also wrote the following:
Selectively quoting my post and then making a statement that I had already made but you omitted does not mean you rebutted what I said.
Nov 14, 2009 at 08:03 PM
sjms
p.1 #23 · sandbag filler?
oh by the way the bags don't need to be able to hold a human body submerged.
Nov 15, 2009 at 12:56 AM
runamuck
p.1 #24 · sandbag filler?
In that case, cured concrete with the body encapsulated in the cement. Works real well for building foundations and basement floorsl Straight from Uncle Looie.
Nov 15, 2009 at 09:53 PM
runamuck
p.1 #25 · sandbag filler?
We have an outfit called the EPA that does actually make sure the air is pretty clean. Now, snow actually stays white, instead of turning a dark gray the next day like it used to.
Nov 15, 2009 at 10:00 PM
