2 3 8 9 end
Archive 2009 · 7D, 8FPS? only in good light!
atsi
p.1 #1 · 7D, 8FPS? only in good light!
I have had my 7D for a couple of weeks and am generally happy with it. I just discovered today that it has one perplexing limitation.
It will shoot at 8FPS quite nicely until you get below a certain amount of ambient light. Not exposure, but ambient light. I am sure this also relates to maximum aperture of the lens too. As soon as the light falls below the equivalent of 3200ISO, 1/100 and f2.8, the frame rate drops. This happens in normal view. If the camera is set to live view and continuous shots are taken it stays steady no matter what the ambient light is. This tested in manual mode where the camera has to do no thinking.
I am quite surprised by this as my 40D and my 20D do not exhibit this behavior. They both hold on to their maximum frame rate no matter what the light. Yes, I have disabled all the auto processing in the 7D, and yes I have gone over every setting to make sure there isn't anything to interfere.
So I went looking and sure enough, page 93 of the manual, last footnote:
"In low-light areas or indoors, the continuous shooting speed may become slower even if a fast shutter speed is set."
I can't think why this needs to be so.
Oct 13, 2009 at 11:44 PM
Gil_W
p.1 #2 · 7D, 8FPS? only in good light!
High ISO speed noise reduction probably. There is a CF for that too, which you can disable.
Oct 13, 2009 at 11:53 PM
atsi
p.1 #3 · 7D, 8FPS? only in good light!
Please read my post. It was not on.
Oct 13, 2009 at 11:57 PM
cameron12x
p.1 #4 · 7D, 8FPS? only in good light!
If that doesn't do the trick, then we need to convince Tramm Hudson to hurry up and port "Magic Lantern" from the 5Dmk2 to the 7D. That could be one of the many "requirements" for such a firmware update.
Oct 13, 2009 at 11:59 PM
Russ Isabella
p.1 #5 · 7D, 8FPS? only in good light!
Was your lens set to AF when the fps dropped? And do you have your CFs set to give priority to focus? Any conditions that reduce focus time will also reduce fps. And this is true with every body, not just the 7D.
Oct 14, 2009 at 12:06 AM
atsi
p.1 #6 · 7D, 8FPS? only in good light!
Manual focus set on the lens, focus assigned to back button only and it was not depressed.
Oct 14, 2009 at 12:11 AM
WesN
p.1 #7 · 7D, 8FPS? only in good light!
atsi,
I don't have a 7D, mine is on order, though I've looked at the manual. See page 93 (at the bottom) where it mentions that low light can effect shooting speed.
Wes N.
Oct 14, 2009 at 12:16 AM
atsi
p.1 #8 · 7D, 8FPS? only in good light!
I think I already mentioned that in my original post.
The point here is that all the previous cameras do not have this limitation. I don't understand why Canon would allow this to occur.
Oct 14, 2009 at 12:19 AM
WesN
p.1 #9 · 7D, 8FPS? only in good light!
Ooops! I didn't read your whole post
Wes N.
Oct 14, 2009 at 12:21 AM
Russ Isabella
p.1 #10 · 7D, 8FPS? only in good light!
So you're saying that with settings that make it impossible for the camera to have any idea of, or be affected by ambient light (not metering, not focusing), somehow the camera knows when the light is low? Does this happen no matter the ISO? If you don't have a lens attached, cap off, camera in high-speed shutter mode, M mode with fast shutter speed, you press on the shutter and fps is reduced as you walk from a well-lit room in to a closet? Like there's a sensor on the camera that's independent of all other functions?
Oct 14, 2009 at 12:22 AM
atsi
p.1 #11 · 7D, 8FPS? only in good light!
No Russ. It appears that the total EV entering the camera is responsible. If the light entering the camera drops below proper exposure for ISO3200, 1/100 and f2.8, then the number of shots per second starts to drop. All auto settings off, fully manual exposure, and no focusing going on. Moving the camera from dark to light areas while running causes the frame rate to go up and going into a dark area makes it drop. All of this in what is fully manual operation.
The same thing does not happen with the 20D nor the 40D. They hold on to their maximum frame rate no matter what.
It does not make sense that the camera has to do this. What this implies is that if you want to do high speed frames in darker situations you might be out of luck and the 40D will do better!
Oct 14, 2009 at 12:33 AM
PetKal
p.1 #12 · 7D, 8FPS? only in good light!
Interesting, but I don't have an answer.
In AF mode I'd see the camera limiting max FPS in low light. (Yet, shouldn't one have the ability to override AF by enabling the drive priority ?)
However, you are saying you lose FPS in manual mode. Could be a firmware glitch ?
Oct 14, 2009 at 12:34 AM
atsi
p.1 #13 · 7D, 8FPS? only in good light!
Petkal, I don't know what the reason is. It is mentioned as a cryptic footnote in the manual. And as I said, the limitation goes away in live view mode!
Oct 14, 2009 at 12:36 AM
Russ Isabella
p.1 #14 · 7D, 8FPS? only in good light!
Fascinating. And weird. So what's the tecnhical difference with live view that eliminates the phenomenon? (Of course if you knew that, you wouldn't have posted!)
Oct 14, 2009 at 12:39 AM
atsi
p.1 #15 · 7D, 8FPS? only in good light!
I might hazard a guess that the new fangled exposure meter array and/or the new fangled focusing array are still active and holding things up even though it is set to fully manual. Putting the camera in live view takes them off line because the mirror is up and they lose their view. So if I am right, there is no reason for this to happen because if the arrays can be disabled with live view, they should be able to be shut down and ignored in normal mode.
Oct 14, 2009 at 12:45 AM
rscheffler
p.1 #16 · 7D, 8FPS? only in good light!
In one of the other 7D discussions here someone commented that it's due to the new metering system. Whether or not that is fact remains to be seen... Maybe Chuck Westfall will clarify this in his monthly column for the Digital Journalist if someone takes the time to submit the question.
Ron
Oct 14, 2009 at 01:00 AM
atsi
p.1 #17 · 7D, 8FPS? only in good light!
If it is the metering system, why is it active or doing anything that would slow the camera down in full manual mode? It's crazy.
Oct 14, 2009 at 01:08 AM
PhotoMaximum
p.1 #18 · 7D, 8FPS? only in good light!
Others have noticed this as well with no real solution...
Oct 14, 2009 at 01:29 AM
garyvot
p.1 #19 · 7D, 8FPS? only in good light!
It probably has to do with the shutter speed. Below a certain threshold, the framerate must slow down. It takes time to cycle the mirror/shutter between frames.
Oct 14, 2009 at 01:42 AM
kodakeos
p.1 #20 · 7D, 8FPS? only in good light!
And this has nothing to do with the shutter speed - IE: like the 40D's 6.5, than falters as the SS slows (obviously, since you cant make 6fps @ 1/15th of a second)
Oct 14, 2009 at 01:43 AM
atsi
p.1 #21 · 7D, 8FPS? only in good light!
I am assuming you are asking a question as you do not list a 7D in your profile. The problem happens even at any shutter speed.
Oct 14, 2009 at 01:49 AM
RobertLynn
p.1 #22 · 7D, 8FPS? only in good light!
I really with other 7D owners would chime in too, see if it's just one or multiple bodies.
Oct 14, 2009 at 01:56 AM
cameron12x
p.1 #23 · 7D, 8FPS? only in good light!
This was not shot with a 7D and there was no loss of frame rate:
http://www.youtube.com/watch?v=QfDoQwIAaXg
1M FPS folks...
Oct 14, 2009 at 02:20 AM
photomarvin
p.1 #24 · 7D, 8FPS? only in good light!
I am pretty sure it is a 'feature' of the 7D model.
Atsi I haven't found it limiting in any real way while shooting, but I am glad you started a discussion on it...I can't remember where but I know when researching the camera when it was announced I did see something about the new metering system which had the potential to reduce frame rate given certain circumstances.
In terms of performances in real world conditions I feel the 7D delivers way more than my 1d2 every did. I know when shooting AI Servo I never really achieved 8.5 fps on my 1d2 given the shooting conditions I'm usually shooting in. To me the 7D performs as well or better...however, I do want to find out more about the technological reason behind the 7d's slowing of frame rate.
I hope someone with more knowledge can chime in...Robbie
PS - all 7D owners...go out and shoot! lol...couldn't resist
Oct 14, 2009 at 02:26 AM
ExxWhy
p.1 #25 · 7D, 8FPS? only in good light!
Mine does it. With the lens cap on, it slows down to about half speed. (guessing), take the cap off and it fires away normally. Must be some reason for it. shrug....
Oct 14, 2009 at 02:45 AM
2 3 8 9 end
