2 end
Archive 2009 · Please Delete
imjustintime
p.1 #1 · Please Delete
Can a Mod please delete this thread?
Edited on Jan 16, 2010 at 01:23 PM · View previous versions
Oct 10, 2009 at 05:57 AM
dirb9
p.1 #2 · Please Delete
I don't see any fungus in the pictures. Did they say whether it was in the viewing or taking lens? Fungus can grow in shorter times than that, if the camera is kept in a warm, extremely humid environment. 14 weeks is enough time.
Oct 10, 2009 at 06:29 AM
imjustintime
p.1 #3 · Please Delete
They said both lenses...
kosmoskatten
p.1 #4 · Please Delete
If it is warm and humid fungus can grow fast, though it usually grows a little slower on non organic material.
Oct 10, 2009 at 07:21 AM
pdmphoto
p.1 #5 · Please Delete
Sorry to hear of your trouble. To be honest, your pictures are not detailed enough to show fungus in this lens. I've bought a few lenses on ebay that had a good front pic, but when I looked through it with the aperture fully open and a bright light, there was clear fungus.
Whether fungus can grow in 14 weeks, I can't answer. It is definately a problem for high humidity areas.
Oct 10, 2009 at 07:49 AM
pengland
p.1 #6 · Please Delete
I would not be able to declare your camera's lenses as "fungus free" with the provided photos. Even close-up, back lit photos taken with the camera's lenses wide open might not reveal fungus that is readily visible to the naked eye.
The presence of desiccant in a storage container does not guarantee exclusion of moisture and likely would do little to lower humidity levels within the lens. In other words, the effects of previous exposure to moisture or a high humidity environment would probably not be precluded and only be minimally reduced with the presence of desiccant. Desiccant has limited capacity to absorb moisture. There is a physical maximum amount of moisture it can absorb. Once it is saturated it no longer absorbs moisture so desiccant packs must be replaced on a regular basis. In a closed lens case it also depends on natural convective air movement in order for it to function. With positive air flow (think air conditioning) effectiveness is considerably improved.
Is it possible that you overlooked the reported fungus? Fine "spidery" fungus may only be visible with the right conditions (ie. lighting, angle, magnification etc...) and may also be limited to the outer edges of elements where it is less obvious to the naked eye. Personally, I believe that is more likely that the fungus was there and that you somehow overlooked it.
The answer is to have the buyer ship the camera back. You would need to make the buyer aware that you would need to inspect the camera for yourself before taking any action. This would have to be with the understanding that shipping costs would be at the buyer's expense in the event that fungus is not found.
Edited on Oct 10, 2009 at 04:46 PM · View previous versions
Oct 10, 2009 at 12:26 PM
Andi Dietrich
Account Locked
p.1 #7 · Please Delete
Sometimes you can not answer a question with yes or no, maybe there were a few spores on the lens which were not visible when you were shipping the item. The question would be then why does the new owner see fungus on the lenses now after only 14 weeks, and if he has to take some responsability of his own?
Oct 10, 2009 at 12:59 PM
TWoK
p.1 #8 · Please Delete
I live in a very humid area. I've seen fungus start in lenses in less than 4 weeks here.
Oct 10, 2009 at 02:41 PM
imjustintime
p.1 #9 · Please Delete
The presence of desiccant in a storage container does not guarantee exclusion of moisture and likely would do little to lower humidity levels within the lens. In other words, the effects of previous exposure to moisture or a high humidity environment would probably not be precluded and only minimally reduced with the presence of desiccant. Desiccant has limited capacity to absorb moisture. There is a physical maximum amount of moisture it can absorb. Once it is saturated it no longer absorbs moisture so desiccant packs must be replaced on a regular basis. In a closed lens case it also depends on natural convective air movement in order for it to function. With positive air flow (think air conditioning) effectiveness is considerably improved.
I know what to look for, I inspected the lens and there was no trace of fungus in the lenses, I would have disclosed that when I sold anything, haven't had one negative feedback and I usually do a good job at describing items that I sell. He sent me pictures and it does show some haze/fungus, but not readily visible, a flash shows it really good.
Oct 10, 2009 at 02:43 PM
imjustintime
p.1 #10 · Please Delete
He had the focusing screen cleaned and the person doing it pointed out that the lens had some fungus in it, and he didn't know what to look for prior to this...
Oct 10, 2009 at 02:51 PM
olyacme
p.1 #11 · Please Delete
Unless you keep your lenses in a nuclear reactor fungal spores are always going to be present. Unless they find favourable conditions (humidity seems to be the main factor) they're going to be dormant, or growing extremely slowly. In an incubator at 100% humidity, and with some food (oil film) present, they might cover a lens in only a day...
It doesn't seem reasonable for a buyer to hold a seller accountable for fungus that grew after he took delivery of a lens. If it grew from being non evident to being evident while in his care, then he mishandled the lens.
It's not reasonable for a buyer to be addressing this so long after the sale, either.
Oct 10, 2009 at 02:59 PM
David Baldwin
p.1 #12 · Please Delete
Fungus spores activate if the camera lens is subjected at a relative humidity of 70% for 72+ hours. If the camera has been out of your hands for 14 weeks and the buyer has only just noticed fungus growth, I would say it wasn't your problem IMHO. You don't know how he has been storing the camera during that 14 weeks. For the facts:
http://www.zeiss.com/c12567a8003b58b9/Contents-Frame/29cd78d56723da79c12571180042df52
Speaking personally I store my Canon in a Pelican bag with a digital humidity meter, which I check ever other day. Today my relative humidity is 45%
Oct 10, 2009 at 03:02 PM
Booone0
p.1 #13 · Please Delete
I really can't comment on the incubation of fungus, but I do have to say one thing regarding the responsibility of the buyer:
When you take delivery of an item, you have a responsibility to inspect it with in a reasonable amount of time. You can't reasonably come back 3 1/2 months late and expect the seller to do something about an issue you're having unless it was clearly negligent. If you're buying older equipment (or even something new) you need to know the issues you may need to look out for, one of which is fungus.
It sounds to me like you know what to look for and would have seen the level of fungus he is describing. I think this buyer stored his camera improperly and is looking for you to fix it.
Oct 10, 2009 at 03:16 PM
pengland
p.1 #14 · Please Delete
+1
Considering the amount of time you said had elapsed and the fact that you are certain there was no fungus present when you sold the lens...you have no obligations to the buyer. If 14 weeks passed from the time you last looked at the lens to the time when the buyer first reported any problem (unless the item was held up in shipping a very long time) .......its case closed.
Oct 10, 2009 at 04:54 PM
imjustintime
p.1 #15 · Please Delete
+1
It shipped July 15th and I think he got it around a week later... Going from NY to Louisiana.
Oct 10, 2009 at 05:17 PM
imjustintime
p.1 #16 · Please Delete
Here are pictures of the said fungus/haze... It would be pretty hard not to see something like that before I shipped the camera.
Edited on Jan 16, 2010 at 01:20 PM · View previous versions
Oct 11, 2009 at 12:03 AM
Andi Dietrich
Account Locked
p.1 #17 · Please Delete
looks like Croco food to me, i dont see how the seller of an item can prevent fungus when the buyer stores his gear in the cellar
Oct 11, 2009 at 12:40 AM
dfresh
p.1 #18 · Please Delete
Louisiana? As in one of the most humid regions of the US? This is sounding more and more like the buyer's fault...
Oct 11, 2009 at 02:17 AM
brucemuir
p.1 #19 · Please Delete
NY to Loosiana...
I think that says quite a bit.
Not too many swamps in upstate...well maybe the Meadowlands but that's Joisey.
Oct 11, 2009 at 02:31 AM
pdmphoto
p.1 #20 · Please Delete
If it has been in Lousiana for 14 weeks, I'd say it isn't your problem. That seems to be plenty of time for this to happen after the sale.
Oct 11, 2009 at 03:03 AM
Kingfishphoto
p.1 #21 · Please Delete
Is there a way to kill or stop fungus from growing? I have a lens with it(seperated from others) , rather like the soft, wierd, photos with it. In other words, can i kill or stop it from spreading to camera body, other lenses ?
Oct 11, 2009 at 05:55 PM
imjustintime
p.1 #22 · Please Delete
Leave it in the sunshine or exposed to a UV light. It will kill the fungus, but you still have to get it cleaned.
Oct 11, 2009 at 06:16 PM
olyacme
p.1 #23 · Please Delete
Strong UV light will only kill the fungus you can see. If it's on the glass, it's a given it's elsewhere in the lens as well, and will simply move back when favourable conditions return.
You can put it into suspended animation by depriving it of moisture, but save for things that would be injurious to the lens, you cannot completely kill the fungus without disassembling and cleaning each part of the lens and replacing all its lubrication. Even if you do go to this effort, you've only killed one fungus.
Spores constantly enter lenses; they're mostly microscopic and molds and fungi produce them by the billions. There is no practical way to keep lenses from hoovering them up. If one lands somewhere that supplies both food (such as films spread by many greases) and moisture (such as from high humidity), it will grow. The digestive enzymes and acids these fungi release as they break down their food are what damage coatings.
I would cringe about putting an obviously infested lens in with pristine ones, but this is probably just a psychological issue. For the threat to be real, it would require that the infected lens has nurtured its fungus so well that it's been able to put up fruiting bodies, and even then one spore and a million spores are equivalent in this situation. It shouldn't matter...
The most practical way to prevent fungal damage of lenses is to keep them in a low humidity environment.
/Acme
Oct 11, 2009 at 07:25 PM
Booone0
p.1 #24 · Please Delete
Sorry for the slightly OT:
Acme - not sure if this applies directly to the fungus typically affecting camera gear, but it might help to know that many microorganisms sporulate in response to adverse conditions - ie, low moisture or lack of food.
Not sure if it would be enough, but I can see how (hypothetically) storing fungus-infected gear in the presence of "clean" gear could increase the chance of the clean gear developing fungus when conditions become favorable - such as a few days/weeks in a humid environment.
Oct 15, 2009 at 05:52 PM
Grenache
p.1 #25 · Please Delete
Bacteria have doubling times of a few minutes to hours. Fungi from an hour or so to days, depending on conditions. I know some one who went to the Caribbean for a weekend and by the time they got back home, they had visible fungal growth on the inner rim of their lenses.
Humidity = trouble.
Does not appear to be your fault.
Keep in mind that dessicant sacks like what items often ship with last about a day in humid conditions. Perhaps a week in dry winter.
To keep humidity out of your gear, you need to constantly recharge (dry out) the dessicant pellets. Many containers are available for this approach. Amazon sells several metal tray kinds that you simply pop in an oven at 300 degrees for a few hours when the pellets turn color.
Too bad. The camera looked great at time of sale.
Jim
P.S. Hey, was Katrina your fault too? It is equally likely.
Oct 16, 2009 at 08:08 AM
2 end
