2 end
Archive 2009 · Canon 10-22 vs 17-40L
roniamarie
p.1 #1 · Canon 10-22 vs 17-40L
I recently upgraded from a Rebel XT to a 40D. I was using the 17-40L lens as my walkaround lens but recently purchased a 24-105. I figure that is a good walk around but not as good for landscape. I shoot landscape and action sports. I'm wondering if I should keep my 17-40 for a landscape or go with a 10-22 for shooting landscape. What are the benefits to keeping or switching?
Thanks.
Oct 02, 2009 at 07:13 PM
Ago51
p.1 #2 · Canon 10-22 vs 17-40L
I have recently bought a used 5D (with 2700 actuations only). I feel since then gratified. A month ago I traded my 10-22 (I will keep my glorious EOS 20D) with a used 17-40L. They are both great sister lenses. Actually, a closer sister would be the 16-35L, after which the 10-22 is practically modeled, but not as regards aperture (2.8 vs 3.5). The 17-40L is rugged and weathered. Feels solid. I appreciate the extra 5mm over the 10-22 and I do not miss the 1mm at the wide end. Optically, they are both valid performers. The corners give it away. Both are absolutely sharp in the center, but the 17-40L has better corners. Overall, the 17-40 edges out for an overall perception of just more clarity: a reward that comes only from L glass.
Oct 02, 2009 at 07:28 PM
Ago51
p.1 #3 · Canon 10-22 vs 17-40L
In your case, with a "1.6" sensor, you are considering two different lenses. The 17-40 will work just fine, but a good part of its range is covered by the 24-105. I would go for the 10-22. There is a new world to see at 10mm. It is great for indoors, and straight lines are well corrected. Best around f/7.1.
Oct 02, 2009 at 07:34 PM
Tony Llerena
p.1 #4 · Canon 10-22 vs 17-40L
Specifically for the 40D, which is the body I shoot with, you can't go wrong with the 10-22. I owned the 17-40 for about a week and realized that on a crop body, it is just not wide enough (17 * 1.6 = 27.2 at the wide end. There is a HUGE difference between 16mm and 27mm. As far as quality goes, I find the 10-22 to be about as sharp as my other "L" glass and there are others that have reported the same. I also have the 24-105 so the 10-22 range fits nicely.
Oct 02, 2009 at 07:36 PM
roniamarie
p.1 #5 · Canon 10-22 vs 17-40L
interesting......
Oct 02, 2009 at 08:42 PM
michael49
p.1 #6 · Canon 10-22 vs 17-40L
17-40 is an odd FL on 1.6X crop.
The 10-22 (or even the Tokina 12-24) is an excellent UWA on a 1.6x crop camera. I only purchased the 17-40 once I had a 5d.
By the way, I loved my 10-22 on my XT and 40D....
10mm will give you an entirely different perspective compared with 17mm....
10mm.....
10mm...
Oct 02, 2009 at 08:49 PM
Matt Shelton
p.1 #7 · Canon 10-22 vs 17-40L
Roniamarie, here's another strong endorsement for the 10-22 with the 40D. It's a superb, sharp EF-S lens. Several of my personal favorite pictures from 2008 were with the 40D / 10-22 combo. Don't let the fact that it doesn't have a red stripe on it keep you from getting it, especially since you have the 24-105.
Oct 02, 2009 at 08:57 PM
roniamarie
p.1 #8 · Canon 10-22 vs 17-40L
Wrapping up a trade for the 10-22 then ... thanks everyone!
Oct 02, 2009 at 11:26 PM
kodakeos
p.1 #9 · Canon 10-22 vs 17-40L
ive loved my 10-22 since i got it shortly after its introduction.
Its fabulous but is kind of a pain in the dark. I do like its size (compared to the 24-70/17-40 size) and weight..I would go with the 10-22 for a 40D any day
Oct 03, 2009 at 05:49 AM
Timwim1
p.1 #10 · Canon 10-22 vs 17-40L
10-22 is the way to go for your cropper!
I love mine, most of my favorite landscape pictures were taken with it! ?That 10 mm will give you a whole new "perspective".
Tim
Check my website below for more examples
Oct 04, 2009 at 04:55 PM
Ian.Dobinson
p.1 #11 · Canon 10-22 vs 17-40L
while the 17-40L is a great lens there is just too much overlap if you have a 24-105 as well.
I paird the Tokina 12-24 with my 24-105. they make a great pair so I dont see why the EFS 10-22 wont be any better
Oct 04, 2009 at 05:49 PM
Ago51
p.1 #12 · Canon 10-22 vs 17-40L
Tim, you should buy a thinner filter. It shows on the edges and, knowing the 10-22, I am sure that it is not lens vignetting
Oct 04, 2009 at 05:54 PM
15Bit
p.1 #13 · Canon 10-22 vs 17-40L
Another endorsement for the 10-22mm. Only problem i have with it is that the zoom and focus rings are the opposite way round to my 17-40L. But while it takes pictures like these, i can live with it:
Oct 04, 2009 at 06:01 PM
roniamarie
p.1 #14 · Canon 10-22 vs 17-40L
beautiful pics 15bit
Oct 04, 2009 at 07:33 PM
bushwacker
p.1 #15 · Canon 10-22 vs 17-40L
timwim1,
what's up with the vignetting? is that the lens or filter?
Oct 04, 2009 at 09:54 PM
15Bit
p.1 #16 · Canon 10-22 vs 17-40L
Thanks.
That looks like filter to me. I've had similar when i stacked two (slimline) filters. The lens really will only take one filter.
Oct 05, 2009 at 04:31 AM
tamalematt
p.1 #17 · Canon 10-22 vs 17-40L
How is the 10-22mm in low light? I am also looking into going UW.
Oct 05, 2009 at 05:54 AM
J.D.
p.1 #18 · Canon 10-22 vs 17-40L
bushwacker wrote:
timwim1,
That's a filter vignette for sure. Lens vignettes are much more gradual than that one.
I have both 17-40 and 10-22. Both are great lenses but both have their good and bad points
17-40:
Good:
*High quality of manufacture with weather sealing
*Constant f/stop
*Excellent centre sharpness and excellent contrast throughout.
*Good zoom range for FF
Bad:
*Some barrel distortion at wider settings
*Minor vignetting on FF
*Some moderate CA at corners at wider settings
*Lens hood almost useless
10-22:
Good:
*Good zoom range for 1.6 CF
*Rectilinear throughout zoom range
*Light weight
*Amazingly wide
Bad:
*Construction slightly inferior to L series
*Moderate CA at corners in wide settings (worse that 17-40)
*Mild vignetting at wider settings
*Lens hood almost useless (from 17-40)
I used to use my 17-40 as my standard lens and it could still serve the purpose well. With the arrival of the 10-22, that changed and the new lens stays on my 40D pretty much all the time. In performance they are both good. The difference is mostly theoretical. A lot of the CA errors are correctable through ACR or Lightroom.
Another small point: I don't know why but my 10-22 has deteriorated a bit in corner CA performance in the time I've had it. I suspect a construction issue. It's still a pretty amazing lens and has better distortion-free performance than the 17-40. For 1.6 cameras, it's the bomb in WA zooms.
Low light performance is nothing special in either case but I use the 17-40 in preference.
Oct 05, 2009 at 11:03 AM
luant16
p.1 #19 · Canon 10-22 vs 17-40L
17-40 has better contrast and color, 10-22 is much more useful for landscape & cityscape than 17-40. I have both and if only have crop camera, 10-22 definitely to go..
Oct 06, 2009 at 01:38 AM
Alek Komarnits
p.1 #20 · Canon 10-22 vs 17-40L
10-22 is *the* ultra-wide for crop cameras IMHO ... last last few mm really opens up your field of view and you can create some fun shots if you are willing to get really close.
Oct 06, 2009 at 03:59 AM
Dawei Ye
p.1 #21 · Canon 10-22 vs 17-40L
The 10-22 is a bit overpriced though. Unless you need 10mm, the Tokina 11-16 and Tokina 12-24 are better value propositions. They arguably have better IQ too
Oct 06, 2009 at 06:55 AM
luant16
p.1 #22 · Canon 10-22 vs 17-40L
the canon 10-22 has better flare resistant though (if the OP care about it)
comparison
http://www.pbase.com/lightrules/uwaflare
Oct 06, 2009 at 03:45 PM
tonyhart
p.1 #23 · Canon 10-22 vs 17-40L
In my opinion, having owned both, the 10-22 destroys the 17-40. I know my 17-40 copy is a poor copy, but all the same. I wish I'd never sold my 10-22 as it was a truly phenomenal lens!
Tony
Oct 06, 2009 at 03:55 PM
cgardner
p.1 #24 · Canon 10-22 vs 17-40L
I held off making the jump to a digital SLR system until the the 20D and 10-22mm became available and the 10-22mm is one of the reasons I stayed with 1.6 and a 50D instead of going full frame.
As others have stated the difference of 10mm on the wide end vs 17mm is significant, especially shooting in close quarters or tilted when dramatic perspective distortion is desired...
Kept level there is relatively little distortion, except the astigmatic correction stretching which is characteristic of any UWA..
It is the lens I have the most fun using because it provides other than normal "by eye" perspective and the one I used for walkabouts because it it so small and light in weight, but no lightweight performance-wise
Chuck
Oct 06, 2009 at 04:37 PM
bushwacker
p.1 #25 · Canon 10-22 vs 17-40L
hello guys....
what about Sharpness across the frame... between these two lenses? which one has the edge?
May 27, 2010 at 10:23 AM
2 end
