shatterkiss Offline Dedicated FM Upload & Sell: Off
p.1 #2 · Tested 16 flash diffusers. What's good for wide angle? | |
It might be useful if, for each configuration, you took meter readings at three locations: direct center, then maybe your -50 and -18 points. While the images are helpful to demonstrate the falloff pattern, raw numbers would really illustrate the impact it has on lighting a scene.
I'd also love to see a test like this measuring the falloff over distance, rather than laterally, at a consistent power setting. I'm sure that a lot of photographers using hotshoe flash diffusers are concerned with the depth from the source that they can reasonably illuminate and how much output power it'll take to get the results they need.
