2 3 end
Archive 2009 · Best non Canon 300mm lense for Canon 1d Mark2n
bearcamera
p.1 #1 · Best non Canon 300mm lense for Canon 1d Mark2n
I am looking for a 300mm (close to 2.8 as possible) but I don't have 4200 for what I need right now. I was wondering if anyone is using a cool non-Canon alternative for less. For instance, I was looking at the Olympus Zuiko for the OM series. The 50/1.8 is killer so maybe the 300/4.5 is too? I'm curious to see the replies.
-Ari
Sep 06, 2009 at 06:45 AM
thrice
p.1 #2 · Best non Canon 300mm lense for Canon 1d Mark2n
You can get the Leica 280/2.8 APO from Bergen County Cameras for $2499? I've spoken with Paul there and it was recently CLA'd by Leica and has perfect glass.
Sep 06, 2009 at 06:48 AM
telyt
p.1 #3 · Best non Canon 300mm lense for Canon 1d Mark2n
The Oly 300/4.5 is OK, nothing special. The non-IF Nikon 300mm f/4.5 ED is scarce but exceptionally good. Its drawback is a long minimum focus distance of 13'.
Sep 06, 2009 at 06:53 AM
Ed Sawyer
p.1 #4 · Best non Canon 300mm lense for Canon 1d Mark2n
For the price the OM 300/4.5 is hard to beat. Optically quite good, it's not a 2.8L but then again it's like 1/20th the price or less. I have a mint one I could part with for $275 that includes case, caps, filter, and tripod ring. Feel free to PM if interested.
-Ed
Sep 06, 2009 at 11:50 AM
Steve Spencer
p.1 #5 · Best non Canon 300mm lense for Canon 1d Mark2n
Keep in mind that if you are comparing lens at 300mm the cost difference between f/2.8 and f/4 is huge. For example the Canon f/2.8 IS is $4,200 as you say, but the f/4 IS is $1,200, and the f/4 (non-IS) goes for about $600 used. So I guess the first question is do you need f/2.8 or would f/4 be good enough. If f/4 is good enough there are a lot of relatively cheap options, but if you need f/2.8 there are few that are cheap. If you give us a sense of what you need and what you are willing to spend I think people could help more.
Sep 06, 2009 at 12:05 PM
theSuede
p.1 #6 · Best non Canon 300mm lense for Canon 1d Mark2n
I'd second Steve regarding that. In a lens as "long" as 300mm, few cost-cutting alternatives would really suffice compared to the 300F/4IS. Unless you're a "never-leave-home-without-my-6lbs-tripod" kind of person...
Sep 06, 2009 at 12:29 PM
cogitech
p.1 #7 · Best non Canon 300mm lense for Canon 1d Mark2n
My answer to this was to convert the Canon FD 300mm f4 L to EF mount. Cost me $182 and it is spectacular.
Sep 06, 2009 at 01:57 PM
debuggerus
p.1 #8 · Best non Canon 300mm lense for Canon 1d Mark2n
The Tamron Adaptall 300mm f2.8 is pretty nice. It's around $600-800.
Sep 06, 2009 at 02:34 PM
bearcamera
p.1 #9 · Best non Canon 300mm lense for Canon 1d Mark2n
Thanks for the replies. I wanted to use this for sports. I wanted to check out if there were some lenses that I had no idea about, and I think you guys gave me some good ideas. However, I agree that at this length and at f2.8 there probably is no substitute for the Canon.
Sep 07, 2009 at 02:01 PM
davidearls
p.1 #10 · Best non Canon 300mm lense for Canon 1d Mark2n
Just curious, here, Paul. Did you figure out how to be able to stop the FD down? I recall from your original shots that you could initially only shoot at f4.
Sep 07, 2009 at 04:30 PM
jay tieger
p.1 #11 · Best non Canon 300mm lense for Canon 1d Mark2n
When I was shooting professionally I used the 300/4.5 MF Nikkor (preED) for years to shoot sports....I still think it's a great lens...and and especially good deal for under $100 (with adapter)....
Sep 07, 2009 at 04:46 PM
cogitech
p.1 #12 · Best non Canon 300mm lense for Canon 1d Mark2n
Still only f4. I left it that way because I have never found a need for any other aperture with this lens.
Sep 07, 2009 at 04:59 PM
davidearls
p.1 #13 · Best non Canon 300mm lense for Canon 1d Mark2n
Thx, Paul.
Just curious because I've frequently used the EF 300 f4 (non-IS) on an extension tube for butterflies, spiders, flowers, etc. When I'm looking for fine detail in these shots, I need to stop down - but that's just me and what I've used the FL for -
Sep 07, 2009 at 05:14 PM
cogitech
p.1 #14 · Best non Canon 300mm lense for Canon 1d Mark2n
davidearls wrote:
Thx, Paul.
Yeah, I don't use tubes at all, but I can see that stopping down for more DoF would be essential when used this way.
I do shoot some flowers and stuff with mine at or near min. focus distance and it does the job:
Sep 07, 2009 at 05:21 PM
siriusdogstar
p.1 #15 · Best non Canon 300mm lense for Canon 1d Mark2n
S-M-C Takumar 300/4
Sep 07, 2009 at 09:08 PM
Steve Spencer
p.1 #16 · Best non Canon 300mm lense for Canon 1d Mark2n
Hi Ari,
For sports, I would want autofocus (but maybe that is just me) and if I couldn't afford the EF 300 f/2.8 I would get the EF 300 f/4, for sports you can get by quite well without IS. As I said earlier you should be able to pick up a used EF 300 f/4L (non-IS for about $600 used (I got one from Adorama a month ago for $535). If you shoot a lot with really low light and need f/2.8 and can't afford the Canon you might want to look at the Nikon ED AiS 300mm f/2.8, it is about the same price as the Canon 300 f/4L (non-IS) or maybe $100 or $200 more. I hope this helps.
Sep 08, 2009 at 12:39 AM
p.1 #17 · Best non Canon 300mm lense for Canon 1d Mark2n
The Mamiya M645 A 300/2.8 APO is absolutely fantastic on EOS bodies.
Sep 08, 2009 at 01:22 AM
pengland
p.1 #18 · Best non Canon 300mm lense for Canon 1d Mark2n
That's another great pic Paul! Nice job on the conversion!
What kind of problem is it that prevents stopping down on your converted FD 300mm f4 L?
Sep 08, 2009 at 01:51 AM
pdmphoto
p.1 #19 · Best non Canon 300mm lense for Canon 1d Mark2n
The later non-ED Nikon 300/4.5's AIS lenses are excellent from wide open and cheap. They also work great with the Canon 1.4x TC. Here's a full frame, wide open, test with the Canon TC:
Sep 08, 2009 at 02:28 AM
pfish
p.1 #20 · Best non Canon 300mm lense for Canon 1d Mark2n
I am surprised that no one has mentioned the following lenses:
Sigma 300mm/2.8 EX DG for EOS
Sigma 300mm/2.8 EX DG HSM for EOS
Sigma 120-300mm/2.8 EX DG HSM for EOS
Tokina 300mm AF AT-X Pro for EOS
Tamron 300mm/2.8 AF SP LD IF for EOS
It seems like all of these lenses are more comparable to the Canon EF 300mm/2.8 L than any of the lenses that anyone here has recommended. I say this because they are all 300mm/2.8 autofocus lenses in native EOS mount.
I don't have any personal experience with any of these lenses, but it seems to me that the 120-300mm Sigma would be particularly well suited for shooting many types of sports.
What type of sports will you be shooting with your 300mm lens? I agree with Steve that the 300mm f4L non-IS might be a great alternative. If you happen to be shooting only outdoor sports in daylight then f4 should be wide enough for your purposes. When I'm shooting sports (which is not very often) I always prefer to grab an autofocus lens, and Canon lenses with USM focus very fast and accurately. That being said, there have been a lot of amazing sports photos taken before autofocus cameras were invented.
Sep 08, 2009 at 02:35 AM
pdmphoto
p.1 #21 · Best non Canon 300mm lense for Canon 1d Mark2n
This being the Alternative Gear and Lenses Forum, you can often expect responses for manual focus lenses
Doesn't a question about a Sigma or Tamron AF lens that is similar to Canon usually gets posted on the Canon forum
Sep 08, 2009 at 02:51 AM
cogitech
p.1 #22 · Best non Canon 300mm lense for Canon 1d Mark2n
Thanks!
NewFDs are a pain in the ass to get aperture working (in my experience) compared to FDs. This one was particularly challenging because the actual aperture is buried deep inside the lens. When the old mount is removed, there are two metal arms attached to it which are about 4.5 inches long and extend down into the barrel to work the aperture. There was just no way (that I could find) to link the aperture ring to one of the arms in such a way that aperture could be controlled directly. NewFDs with their two-lever system are still a mystery to me. I might have been able to figure it out if I could see what the hell was down in that dark abyss, but I didn't have the patience so I just frigged around with it until I found a position that holds the aperture wide open. Since then, I've never really looked back because I haven't once thought "shit, I wish I could stop this thing down". It's a good thing, too, since it is JB Welded like that.
Sep 08, 2009 at 03:03 AM
pfish
p.1 #23 · Best non Canon 300mm lense for Canon 1d Mark2n
I dunno I've never looked in there before
Sep 08, 2009 at 03:20 AM
DocsPics
p.1 #24 · Best non Canon 300mm lense for Canon 1d Mark2n
Agree with Steve on an older 300/4 non-IS. I got a really old one here on FM B&S for around $500. Does a nice job.
Sep 08, 2009 at 05:14 AM
bearcamera
p.1 #25 · Best non Canon 300mm lense for Canon 1d Mark2n
Jay,
do you remember which copy of the 300/4.5 you had exactly?
thanks again to everyone.
Sep 08, 2009 at 10:01 AM
2 3 end
