2 end
Archive 2009 · Shift-lens clamp for parallax-free flat stitch?
AJSJones
p.1 #1 · Shift-lens clamp for parallax-free flat stitch?
Right now, one can slide the camera an equal and opposite direction to compensate for the movement of the lens, twice to get a three shot set to stitch.
I'm curious to know how many folks would be interested in a clamp that would hold the lens body of a shift lens to allow easy, parallax-free flat stitching by allowing the camera to be moved while the lens is held stationary. The clamp could be made to attach to a rail like the RRS rail so the camera/lens combo would slide fore and aft to line up the axis of rotation with the nodal point/exit pupil as normal. The Canon shift lenses at least have locking nuts so the camera wouldn't move after locking and it would be soooo much more convenient than sliding cameras side to side, especially if you plan to use the shift in a vertical direction to get multi-rows, while rotating around the optical axis to get the horizontal shots for each row.
My email with this suggestion was sent to engineering at RRS and if there's enough interest, we might be able to convince them it's worth developing
Aug 27, 2009 at 10:11 PM
mMontag
p.1 #2 · Shift-lens clamp for parallax-free flat stitch?
I had to read your post a few times to "get it". This thing needs to look like a tripod collar.
It may work - you'll probably find a lot of variation in the many types of tilt shift bodies for a universal clamp. On the Canon TS-E's the amount of available mass to clamp onto is very narrow - less than 1/4"thick - right up against the camera body - with a rotation lock / release at 9 o'clock. Then there is the weight of the hanging camera body that would need to be moved by a small lens knob - tough to do with a 1D series Canon body - especially vertically. If anyone could do it - RRS would do a great job.
I do use my 24TS-E for three stitch pano's and use an RRS "L" bracket on the camera with a quick releases on the tripod and just slide the "L" bracket left and right in the quick release. I'm very happy not to need additional hardware.
Aug 28, 2009 at 01:09 AM
AJSJones
p.1 #3 · Shift-lens clamp for parallax-free flat stitch?
The clamp has to attach to the lens well away from the camera body so the body can move freely - I'm looking at my 24 TSE and the square part between the mount and the focusing ring has large grooves on either side (the sides that don't have the tilt controls on). The newer ones look like they would need the clamp to have semicircular indents to grip the circular part of the lens body. Unless I had all the lenses in front of me, I couldn't tell whether there's a hope of designing a clamp that could be useful to them all - possibly with different grips on the basic U-shaped clamp that attaches to the rail. For simple horizontal 3 shot stitches, the sideways sliding of the L-bracket isn't too much of a hassle. Using portrait mode to get three verticals to stitch flat, then rotate around the "nodal" point then repeat to get each angle of a 3-row pano is where it would help some
Aug 28, 2009 at 01:49 AM
Cableaddict
p.1 #4 · Shift-lens clamp for parallax-free flat stitch?
I'm not sure how much this would really help, but it's a brilliant concept, worth exploring further.
It would indeed be hard to do, clamping to the lenses. Plus, that would put serious strain on the shift screw - it is designed for the weight of a small lens, not a camera. Seems like a BAD idea to me.
Maybe there's a better way:
The camera sits on a base (basically a different type of pano system) and there is a long flat rail UNDER the lens, pointing forward. It is adjustable and so can be pulled out to just past the front edge of the lens.
This rail has a line etched into its center, which marks the LENS longitudinal center.
Once you dial-in your desired shift, you then turn a dial on this rig which moves the CAMERA left-right (or up-down in portrait mode) and you do so until the center of the lens once again aligns with the line on the extender rail.
Done.
-But this will be heavy & expensive. There would have to be some SERIOUS optical benefit for this to be a viable thing.
Well, you could go cheaper, and just have the camera on a locking slider, instead of geared teeth.
Aug 28, 2009 at 02:43 AM
Cableaddict
p.1 #5 · Shift-lens clamp for parallax-free flat stitch?
One has to ask the question: How often do you need to take panos with high structures (causing keystoning considerations) that also have in-focus object in the foreground?
Landscapes? Not likely
Citiscapes? Maybe, but probably not that often.
Architecture? Bingo. There's your market. You might want to find some architecture or real estate forums, and float this idea there.
Aug 28, 2009 at 02:53 AM
AJSJones
p.1 #6 · Shift-lens clamp for parallax-free flat stitch?
Thanks for thinking it through! Landscapes may not need to have much very close to the camera for parallax to be an issue for stitching multi-rows (art least my mainly wide-angle ones) The TSE24 isn't much lighter than the 5D so the weight issues are not too much of a concern for the mount. Tripod collars on long lenses let the body hang out on its own (think super tele with a 1D series on it) . It can be done with other devices but they're cumbersome and probably more costly than this would end up. It's mainly for folks trying to increase the MP count. A full pano rig is quite a few $$$ and that's the real alternative that is used today. Perhaps RR$ won't be interested enough because it would eat into their pano rig market
I may have to look up a couple of pals with machine shops
Aug 28, 2009 at 03:12 AM
Cableaddict
p.1 #7 · Shift-lens clamp for parallax-free flat stitch?
It's a LOT lighter than a 5D with a battery pack & L-plate.
Sure, but only the lens-mount takes the weight. We're talking here a bout a tiny screw & threaded rail, meant to move the lens sideways. It won't last. I guarantee that RRS will say the same thing.
Aug 28, 2009 at 04:18 AM
dendowling
p.1 #8 · Shift-lens clamp for parallax-free flat stitch?
I've been shooting shift lens stitched panos for a few years. As mentioned above when doing landscape with subjects far away the parallax wasn't a problem. But, now doing architecture or close subjects parallax is off and the overlaps don't line up. So, I've been planning to build a lens clamp like you suggested to keep the lens stationary thereby shifting the camera body side/side or up/down. I think the point of using a shift lens is to keep the 2 or 3 image pieces parallel (making the subject lines parallel). So, I don't see any need to rotate the camera around the nodal. If you rotate around the nodal your lines won't be parallel and then there's no need for a shift lens anyway. But, maybe you have a different capture/stitch method in mind.
I was also imagining clamping onto the flat sides of the squarish center piece of the 24TSE although the newer TSEs don't have these big wide flat sides. Or, maybe doing a thin clamp around the round part just behind the focus ring where the aperture range is printed but, might be trickier to build.
Aug 31, 2009 at 09:31 AM
Cableaddict
p.1 #9 · Shift-lens clamp for parallax-free flat stitch?
I still think my way would be safer, and probably much easier.
You could likely just modify a macro-rail system. Find some way to mount it sideway (to the camera.) Then, mark the dead-center point, and add a matching mark on your camera's base.
Last: mark the two outer points that correspond to you maximum shift amount, and you're done.
(or add a sliding front guide-rail, as I originally outlined.)
Aug 31, 2009 at 10:01 AM
Cableaddict
p.1 #10 · Shift-lens clamp for parallax-free flat stitch?
dendowling, two questions for you:
1: When you make these using SIDEWAYS shift, (just to be clear) is there a specific amount of shift that works best, or does one simply use the most that the lens will give? Is there some kind of math involved?
2: Have you ever made comparison shots, as I asked about earlier? That is, two "identical" panos, but one done with sideways shift, and the other done with nodal panning?
I am DYING to see if there's a noticeable difference, either in perspective, or in sharpness due to the software "faking" the perspective.
Aug 31, 2009 at 10:05 AM
dendowling
p.1 #11 · Shift-lens clamp for parallax-free flat stitch?
Honestly, I haven't experimented with nodal pan/stitch. When you use nodal pan/stitch do the two pieces just line up without digital correction or do you need software that bends image shape of the two pix into alignment? Also, when you do a nodal stitch are all the horizontal lines still parallel or are they curved?
The reason why I use the shift pan stitch is to avoid any software tweaking the image shape. I can align the two halves by simple up/down left/right movement in photoshop. The reason for this is because on each half I shoot two exposures (under/over) for a light and dark version that can be used to dodge/burn the image. But, the auto-stitch software won't do the light version exactly the same as the dark version so, the auto-stitched light pic never aligns with the auto-stitched dark pic.
I like your idea of just sliding the camera sideways to counteract the lens shift but, I wonder how accurate is the placement of the lens even with the guide you mentioned. The concept with the lens mount is to keep the lens perfectly stationary so you don't have to worry about the position of the lens .
Here are examples of the side/side shift stitch and up/down shift stitch. Is this possible with a nodal pan/stitch? I'm not making a challenge, just wondering what nodal can do.
Aug 31, 2009 at 11:03 AM
Cableaddict
p.1 #12 · Shift-lens clamp for parallax-free flat stitch?
Den,
Your first pic has a LOT of keystone error. What stitching software you are using? According to some posts, above, modern stitching software automatically compensates for this (though I don't see how it could be automatic, and it may well cause a noticeable loss of detail)
Did you perhaps turn off this function, on purpose, to keep maximum sharpness? -I recently did a test of basic keystone adjustment, using Lensfix, and was shocked at how much detail was lost. Never thought about it before.
I think the ultimate rig for that type of shot (exactly what I was talking about in my OP) is to use a shift lens n portrait orientation, shifted UP, plus a nodal-panning base. That combination should yield minimum keystoning, no parallax error, and maximum sharpness.
But I'm still interested in seeing results & hearing more opinions.
Aug 31, 2009 at 11:39 AM
HerbChong
p.1 #13 · Shift-lens clamp for parallax-free flat stitch?
you haven't tried any modern software. 5 shot HDR panos where there are 5 shots in each position at 1 stop apart are no problem with anything modern. you stitch all images at once and then go away until it is done. as for simple shift alignment, there is a lot to be said for it but that's not why i am going to get a shift lens. it's to get better control of the focus plane for DOF control.
Herb...
Aug 31, 2009 at 04:10 PM
millsart
p.1 #14 · Shift-lens clamp for parallax-free flat stitch?
Herb...
Well you could also do DOF focus bracketing in addition to the exposure bracketing. Of course then you'd be taking up to 5 frames for HDR at each focus point in your image, and you'd want several frames at least for the focus bracketing to get the DOF your after, so we are talking up to 25 frames per stitched part of the scene, and with just a simple 5 frame pano you'd then but up to 150 frames. Yikes!
Not only would that take forever to stitch but I'm sure the light would of changed from the time the first frame is taken til the last so then that poses an issue.
It could be argued that you could selectively focus bracket just parts of the image, as with exposing less frames for certain parts, but then that gets really confusing to keep track of in the field I think.
"Old school" tilt method to increase DOF is the winner and makes a pc-e/ts lens well worth the money. Just one shot can give you the front to back sharpness you need at an average apeture you want.
Aug 31, 2009 at 07:13 PM
millsart
p.1 #15 · Shift-lens clamp for parallax-free flat stitch?
I'm curious what a clamp would provide holding the lens over simply doing it the "old" way of shifting the lens one direction and then shifting the camera body the other direction ?
I have marks on my clamp that shows how far to shift the dovetail plate to match what I shift the lens and it works great.
I guess if only the camera was moving it would be slightly faster but it would seem like sort of another pricey clamp to get, probably $300 knowing RRS.
I think everyone already has an L plate and dovetail clamp on their ballheads (or at least those who are serious enough to own PC lenses) so I would think it would be a very limited market for such a product.
It woudl work of course but I think to be sturdy you'd have to attach it to the lens body, and while there are some nice flat panels to do that with, you'd have to drill out the lens to attach it and how many want to drill into a $2k lens ?
Aug 31, 2009 at 07:19 PM
Cableaddict
p.1 #16 · Shift-lens clamp for parallax-free flat stitch?
Well, I don't, but then I have yet to buy a fancy pano rig. I am very new to panos and so far have just done hand-helds.
I am looking to improve my quality, and recently obtained a shift-lens, hence perusing threads such as this one.
Can you describe (with pics if possible) your rig? I realize that dovetails are used to mount a pano rig onto your regular ballhead. OK, that works for nodal-panned panos, but how are you using this for shift-lens panos? Something like what I outlined, above? (A sideways-mounted "macro" rail?)
Sep 01, 2009 at 01:34 PM
mMontag
p.1 #17 · Shift-lens clamp for parallax-free flat stitch?
Use an RRS "L" bracket on your 5d - there are center line marks on the bracket for the landscape and portrait positions. Use an RRS ballhead clamp - there are center line & 10mm graduation marks to the left & right of center. Set up on a tripod - use a bubble level. If you have those items you don't need a pano rig or marco rail for three frame shift pano's. I keep my "L" bracket on my camera - full time.
Set (slide) your camera to the left 10mm graduation - shift TS-E right 10mm - SHOOT - Set (slide) camera to center - TS-E center - SHOOT - Set (slide) camera right 10mm - shift left 10mm - ETC. The lens stays on a center line - the body moves. I don't even lock the ballhead clamp or TS-E locks.
Sorry no pics - gotta go to work to pay for camera gear! Have fun!
Edited on Sep 01, 2009 at 11:08 PM · View previous versions
Sep 01, 2009 at 01:59 PM
Cableaddict
p.1 #18 · Shift-lens clamp for parallax-free flat stitch?
OK, I get it. You are just sliding the plate inside the clamp. I guess that's workable. I was thinking more along the lines of a threaded-screw micro adjuster. (like a macro rig, but sideways)
-But I don't understand how you are using the marks on the L-plate. It's the LENS that must stay centered. It seems to me that you are just guess-timating, and not keep the lens ABSOLUTELY in the same position. No?
Sep 01, 2009 at 03:47 PM
Masahara
p.1 #19 · Shift-lens clamp for parallax-free flat stitch?
I would definitely be interested. My current solution is the same as above with the L bracket marked (or maybe a macro rail ?) but it gets expensive fast.
This does keep the lens centered on the same axis and effectively moves the body 10mm left or right for a given shot. There was an article on this a few years back a google search might turn up.
Sep 01, 2009 at 03:57 PM
millsart
p.1 #20 · Shift-lens clamp for parallax-free flat stitch?
You shift the lens 11mm to the left, so then you shift the camera body 11mm to the right. The net result is the lens stays in exactly the same postion.
The lens has mm markings so you can tell how far you shifted it, and the L plate has markings to tell how far you moved that.
If your L plate doesn't have markings on, its pretty easy to just measure 11mm and put a little paint mark so you know how far to slide it each direction.
It is exact right down to the micron ? No, but its accurate to at least half a millimeter and thats more than accurate enough
Sep 01, 2009 at 04:26 PM
AJSJones
p.1 #21 · Shift-lens clamp for parallax-free flat stitch?
Like the first line of the OP suggests, I've been doing the shift lens/slide camera/repeat for flat stitching for a long while too. It's a bit tedious but manageable if the slide is horizontal. I tried it once or twice with the clamp vertical (to offset rise) and it's way less convenient, since the camera wants to slide out and it's not difficult to nudge the tripod (and start all over). A geared rail approach would work, but heavy complicated and $$.(Might as well get a true pano-rig and live with recent stitching software). Building a clamp that holds the lens seems relatively simple (either with flat jaws or curved indents for the lenses that have all-round parts).
The addition of rotating around the axis was not a necessary part of the original plan, but it would provide the other dimension for a multi row - let's say the flat stitch gives you 3 shots high, the rotate gives you 2 or 3 (or however many you really need) wide. (Or vice versa obviously) The clamp only provides the benefit in one axis, so the stitching software only has to mess with 2 or 3 separate (3-shot-flat-stitched) shots - rotated around the right axis.
One could shoot any rectangle within the 67mm image circle of the new TSE's with ease using 4 shots also - to get wider FOV and more MP for bigger prints with the clamp. Not so easy with the clamp-sliding system.
There may only be a few of us that would like such a clamp, so it would be even more $$$ if RRS or someone developed and made them. I still have my 4x5 outfit so this would be a backburner project (until I sell it - these thoughts triggered by the increasing MP and TS lenses from Canon to go with the rest of my Canon small format gear )
Sep 01, 2009 at 11:30 PM
millsart
p.1 #22 · Shift-lens clamp for parallax-free flat stitch?
The shift can be very useful even when doing a single row rotational pano because it allows you to pan level but since you can shift up or down, you can have more or less foreground in your shot and don't have to be stuck with the horizon line in the middle of the frame.
Panning level with a single row and nodal plate is very quick and easy and generally error free, and you can do it quickly under changing light conditions. Multi rows are always cool, but dont work so well for dynamic subjects
Sep 01, 2009 at 11:46 PM
AJSJones
p.1 #23 · Shift-lens clamp for parallax-free flat stitch?
I have the RRS MPR and PCL and 24TS for just such occasions where the flat-stitch view isn't wide enough and have done exactly as you are suggesting. The stitching software does indeed handle the lens distortion and angular distortion and (usually I use cylindrical) projection very nicely. I still like the idea of having only one image coming through a fixed lens and capturing that image in pieces that reassemble with no software needed (other than copy/paste in PS).
I just need to cultivate my acquaintance who has a nice machine shop
Sep 01, 2009 at 11:57 PM
montespluga
p.1 #24 · Shift-lens clamp for parallax-free flat stitch?
That's how I make the flatstitches, the yellow screws stop the cam at the right position, e.g 11 mm away from the center.
Sep 02, 2009 at 12:08 AM
millsart
p.1 #25 · Shift-lens clamp for parallax-free flat stitch?
There is always the option of carrying a DX body with you as well (if your on full frame) and use that to have an option of a wide stitch (though you have to adjust your distance from the subject)
Experimenting just with the crop mode I've found I can actually get a 3:1 ratio as the lens shift covers a larger effective percentage of the image circle with the smaller sensor.
I'm thinking of adding something like a Nikon D5000 to enhance the functional focal length of my 24mm PC-E to also work as a 35mm PCE
Sep 02, 2009 at 02:02 AM
2 end
