kasakato Offline Image Upload: Off
p.1 #7 · MF with AF will damage the lens? | |
Gustaf Lindber wrote:
Rodolfo Paiz wrote:
Please note that there's a very important difference between the focusing mode of the camera (AF-S, AF-C, AF-A, etc.) and the focusing design of the lens itself. The answer to your question depends on the lens:
1. On an AF lens, with a screwdriver-type focus, you should either use the AF or the MF, but never both. It will definitely damage the lens.
2. On an AF-S lens, which uses an ultrasonic signal to drive focus instead of a physical connection, the lens has focus designations of "M/A" and "A". On these lenses, you can do as you've suggested (focus with the camera and then fine-tune manually) with no problem whatsoever.
Nikon calls these AF-S lenses, Sigma calls them HSM, and I'm not sure what Tamron calls them. But check carefully, because it's the lens that determines whether or not what you're doing will damage it.
Not all AF-S have the M/A capability. The 18-55 for example don't have it but then again, it's not really designed to focus manually.
Yup, it just says A or M on the lens.
