2 end
Archive 2009 · D700, even when switched off battery drains (NOT ANYMORE)
mike777
p.1 #1 · D700, even when switched off battery drains (NOT ANYMORE)
It happens with original and non original batteries and the 12-24f2.8 or 24-70f2.8 mounted. About 30% in two days, completely empty in less than a week. How can that happen while the machine is switched off? Everthing has been bought brand new last month.
Edited on Aug 15, 2009 at 10:38 PM · View previous versions
Aug 13, 2009 at 10:45 PM
stevekphotos
p.1 #2 · D700, even when switched off battery drains (NOT ANYMORE)
I think mine drains slowly too. Since it's electronic, even when it's off it's still powered and drawing juice. Unplug everything in your house unless you're actually using it, and you'll notice your electric bill will drop 40%.
Does this happen to anyone else?
Aug 13, 2009 at 10:46 PM
davenfl
p.1 #3 · D700, even when switched off battery drains (NOT ANYMORE)
You have a problem, the system is always drawing a little power but it should last a long long time.
Dave
Aug 13, 2009 at 10:48 PM
mike777
p.1 #4 · D700, even when switched off battery drains (NOT ANYMORE)
I have had lots of different Canon bodies and they wouldn't drain a battery in several months...
Aug 13, 2009 at 10:51 PM
mike777
p.1 #5 · D700, even when switched off battery drains (NOT ANYMORE)
That's what I feared but being new to the dark side I wasn't sure.
Aug 13, 2009 at 10:53 PM
Sam Bennett
p.1 #6 · D700, even when switched off battery drains (NOT ANYMORE)
My D50's battery doesn't drain that fast even with the camera "on" 24/7. Pretty sure my D700's don't drain that fast.
Aug 13, 2009 at 10:55 PM
Jammy Straub
p.1 #7 · D700, even when switched off battery drains (NOT ANYMORE)
That's not normal on my D300, I'd do a controlled test with no shooting and a freshly charged battery.
Aug 13, 2009 at 11:20 PM
lou f
p.1 #8 · D700, even when switched off battery drains (NOT ANYMORE)
could be the battery not the camera.
Aug 14, 2009 at 12:26 AM
Erik Moore
p.1 #9 · D700, even when switched off battery drains (NOT ANYMORE)
I change a battery in my D700 once every 10 days or so, shooting every couple of days. I think that's not normal. I would change batteries first.
Aug 14, 2009 at 01:12 AM
EB-1
p.1 #10 · D700, even when switched off battery drains (NOT ANYMORE)
That is not normal for any camera. Obviously something is still drawing current. It is RMA time.
Aug 14, 2009 at 01:16 AM
Alan321
p.1 #11 · D700, even when switched off battery drains (NOT ANYMORE)
There is some battery drain as it is used to power the viewfinder LCD at all times. Without a battery it goes very dark. The Canons do not operate this way but they also do not provide the built-in viewfinder grid.
However, the battery should not drain significantly within a week let alone a couple of days. You therefore have two possibilities: A dicky camera or a dicky charger. I have been told that most 3rd party batteries don't go well with the D700 charger (because of the electronic controllers within the batteries) but even if that is true the Nikon battery ought to be charging ok. On balance I would guess that the camera is at fault.
- Alan
Aug 14, 2009 at 02:53 AM
runamuck
p.1 #12 · D700, even when switched off battery drains (NOT ANYMORE)
If it's happening with more than one battery, it has to be the camera. It's time to contact Nikon.
Aug 14, 2009 at 03:04 AM
Tmeck
p.1 #13 · D700, even when switched off battery drains (NOT ANYMORE)
Second this, I leave my S5 Pro and D70 on almost 99% of the time, and unless I'm out shooting the batteries remain staunchly where I leave them... I charge both of them very infrequently.
Aug 14, 2009 at 03:24 AM
stevekphotos
p.1 #14 · D700, even when switched off battery drains (NOT ANYMORE)
I just checked mine again. Camera has been sitting for a couple of days, and the battery is still at 75% (wasn't charged when I put it away either).
Aug 14, 2009 at 06:35 AM
Mocca
p.1 #15 · D700, even when switched off battery drains (NOT ANYMORE)
I seem to recall I had something of the same problem. The battery seemed to lose charge when camera was not in use.
After some dis-recharges of the battery, this is no longer a problem. Perhaps you could try to "massage" the battery a bit.
Aug 14, 2009 at 10:17 AM
Chestnut
p.1 #16 · D700, even when switched off battery drains (NOT ANYMORE)
We have a D700 in the lab, and we shoot frequently. With the vertical grip, we have gone MONTHS without worrying about the battery before.
Aug 14, 2009 at 12:16 PM
mike777
p.1 #17 · D700, even when switched off battery drains (NOT ANYMORE)
Thanks everybody for all the input. The battery problem is a bit of a disappointment after noticing how solid the Nikon gear seems to be but I think it can be ironed out sooner or later (I have nothing else to complain about). For now I will wait a bit before taking the D700 to Nikon Service. First because I want to see if it could be related to the fact that the batteries have been charged only once (though I think it's not very likely) and second because I don't want to let go of my new toy already.
I will let you know what happens...
Aug 14, 2009 at 07:53 PM
---XR---
p.1 #18 · D700, even when switched off battery drains (NOT ANYMORE)
what about removing the batteries from the camera when it's not in use, mabey it'd keep the full charge?
Aug 14, 2009 at 08:09 PM
mike777
p.1 #19 · D700, even when switched off battery drains (NOT ANYMORE)
when the batteries are not in the camera they don't discharge
(the problem surely is body related)
Aug 14, 2009 at 08:14 PM
poisonpill
p.1 #20 · D700, even when switched off battery drains (NOT ANYMORE)
Yeah not normal. I've left my camera in the "ON" position for weeks in my bag (by accident actually) and the battery did not drain any noticeable amount -- it was still full.
D700 too.
Aug 15, 2009 at 02:10 AM
highcontrast
p.1 #21 · D700, even when switched off battery drains (NOT ANYMORE)
Yep, something is amiss. I have a D700 that has sat unused for weeks at times, with no noticeable drain. Even left on in the bag for days, not more than a couple % loss of charge, if that.
Aug 15, 2009 at 02:34 AM
runamuck
p.1 #22 · D700, even when switched off battery drains (NOT ANYMORE)
My D70 has been in the truck since last fall. I charged it the other day just to be on the safe side. Lithium batteries are the cat's pajamas when it comes to long life.
Aug 15, 2009 at 04:11 AM
traveler
p.1 #23 · D700, even when switched off battery drains (NOT ANYMORE)
I've had my D700 with it's battery charged sit dormant for a month and it's still near 100% so I've been very impressed with the LiIon battery's capability of holding on to a charge.
Aug 15, 2009 at 04:29 AM
slrl0ver
p.1 #24 · D700, even when switched off battery drains (NOT ANYMORE)
NiMH followed by NiCd have a high rate of "self-discharge" -- sitting idle, they bleed energy through internal resistance. LiON has MUCH lower self-discharge but not as much current handling capability (which isn't a huge issue for dSLRs!)
Cold performance is the other area where batteries suffer "voltage depression". I'm curious what the D700's battery is like under extreme cold, but I suspect it will still be great.
Aug 15, 2009 at 04:58 AM
mike777
p.1 #25 · D700, even when switched off battery drains (NOT ANYMORE)
And now for a rather different situation:
Battery 1, original, went completely dead after the first charge.
Battery 2, not original, went completely dead after the first charge.
Battery 3, not original, went completely dead after the first charge.
Battery 1, after the first REcharge only lost 1% in the last 24 hours.
Mocca, do you read me ? ? ?
I will report on what further happens but if things continue for the better it will take some time...
Aug 15, 2009 at 10:36 PM
2 end
