sjms Offline Dedicated FM Upload & Sell: On
p.1 #23 · Just ordered the Demb Flip It! Reflector/Diffuser! | |
Joe Demb wrote:
Steve, Please try the boiling water solution. You can do it an unlimited number of times. I test a material in a heat box with an oven thermometer. When I report to the manufacturer that warping starts to occur at about 125 degrees, he laughs and says that no one works in an environment over 120 degrees, at that temp all sorts of things start to fail, & blah blah blah. The fact is that obviously there are conditions, like the dashboard of a car, etc. where that temp is reached. Molecules don't lie. Like most people I start with my own experience and note that this stuff never warped on me in about 8 years of usage. It is necessary at some point to get over myself, listen to people like you, and acknowledge that I may have to abandon a couple of thousand dollars of stock on a shelf and just move on to something (hopefully) better. Ultimately, you folks are my bosses.
oh i have no real issues about it. its just one of those things and i just flex it back into position when i "need" to. as to the 120F temp environ well i don't suggest the middle east as a working location then. i have been in it higher and its not what i call pleasant. . i'll boil it up and make some soup.
