adamdewilde Offline Upload & Sell: Off
p.1 #1 · Indie Film Maker.... Kinoflo alternatives? | |
Alright, so recently I started working on a movie set. I'm doing the stills photos *~*
Most of the movie is filmed at night, I noticed that they use Arri lights outside the house to flood light in through the windows. They're like 1k-4k lights depending on what they need to light inside and what they need to light outside (some lights are facing trees and some are shining through the window). Then inside the house to light the actors nicer, they're using Kinoflo lights that I'm assuming are daylight balanced as they're cooler. On top of that they're covering any light outside and inside with blue gels to make it appear as if it's night. And in the corners they're lighting little tiny Arri's with warm gels to give that tungsten look.
Anyway, I wrote a post a while back trying to understand what I would need for my own little indie film. And after seeing this movie, I've realized that:
A) most of the stuff I think I need, I can't afford.
B) I need a lot of stuff, but renting is expensive and buying would allow me to use it multiple times until I've built up a nice little reel for myself.
So I was thinking, I'm not getting HMIs because they're to expensive on a whim, so Kinoflo's looked really nice to me, and they're not horridly expensive. I am going to assume I couldn't use them to light the outside of a house, but I could use them for interior close range shots (a space no bigger then 250 sqft).. But then I thought, there must be cheaper brands out there that'll work just as well... Or perhaps I could even do it myself.
After more research I realized that I'd need a Ballast, which I'm guessing is to regulate the output power. Also I'd need special bulbs, but honestly the casing I could make myself, looking at the kinoflo cases I could do that no problem with $50 worth of materials.
I think after the kinoflo type lights, my 5D a good steadicam and a tripod would be all I need to get excellent video... Sound I'm going to get a beachtek dxa-2s device which hooks up to my camera and allows me to record two XLR input sound devices at the same time. Question though, it runs the noise back to my 5D will the 5D understand that it's two separate tracks and record it as such?
So does anyone know of any brands I can buy that would have 200w or more power using tube florescent lights, that are flicker free and daylight balanced that cost less then Kinoflo?
Also something else I noticed that I found funny...
The Redone camera they are using picks up light way different then my camera.
I set my settings to the same as there camera, and when I take a quick video it looks completely different, not just colorwise, but like the way the camera sees light, as in my camera hits shadows and highlights, while the red keeps everything neutral across the board.
I guess thats the difference $50k makes
Yeah, so any help on Kinoflo alternatives would be great.
Thanks guys,
Adam
