Carmen Miranda Offline Image Upload: Off
p.1 #5 · Grip Head for Lastolite Skylite? | |
The Avenger D200 is different than Lastolite's version of the same thing.
Here is the Lastolite:
The basic grip head is the same as the D200, but when you look closely (note picture with SJ bracket below) you will see that the pancake knuckle is very different having larger holes to accommodate the larger aluminum tubing of the Skylite.
Lastolite also makes another bracket for the Skylite. Here is the version with Baby receiver:
I don't use this bracket as pictured though. Mostly I use it with a 5/8 snap-in or drop-down pin, similar to the Scrim Jim post adaptor pictured below.
This (works with SJ only) and the 2nd Lastolite bracket are handy brackets for swiveling reflectors or scrims into positions the D200 version doesn't work as easily. But if I was to pick only one bracket, it would have to be Lastolite's D200 version for sure.
Good luck.
