Moderated by: Carl Auer, Fred Miranda
Sports Corner Resource
FM Forums | Sports Corner | Join Image Upload
Shooting in gym question Go to previous topic Go to next topic
RL15
Image Upload: Off
p.1 #1 · Shooting in gym question
Ok so I'm new to shooting sports. I am having trouble with WB indoors when shooting basketball. This is the situation.
I was shooting inside a gym with my 5Dmk2 + 70-200 2.8IS
Settings:
Manual
1/500
f2.8
ISO4000
custom WB by setting it at about 5000K
I was shooting with AI servo and burst a bunch. Even with my settings remaining the same the WB and exposure would differ from shot to shot when the subject was in the same position in both frames. My friend was shooting with his D700 and it yielded the same result.
So my question is by chance would this be caused by the type of flood light they used? If so how can this problem be resolved?
I wish I could post an example right now but I don't have access to the files.
TIA
Jul 08, 2009 at 06:00 PM
P Alesse
Image Upload: On
p.1 #2 · Shooting in gym question
It can't
Jul 08, 2009 at 06:20 PM
RL15
Image Upload: Off
p.1 #3 · Shooting in gym question
P Alesse wrote:
It can't
So its not just me? What is the cause?
Jul 08, 2009 at 06:22 PM
John Patrick
Buy and Sell: On
p.1 #4 · Shooting in gym question
What you're catching is the lights going through their cycling. The only way to get around that is to use either a very slow shutter speed (1/60th or slower) or strobing to overpower the ambient lighting.
If you can't do either, then you can't solve the problem and have to deal with it.
John
Jul 08, 2009 at 06:24 PM
Hammy
Image Upload: Off
p.1 #5 · Shooting in gym question
Light cycling.
Most gyms have a WB of around 4000 - give or take, depending on age of the bulbs - and can vary at different parts of the gym. Maybe they have newer, updated bulbs to get you around 5000? If you want get a custom WB, make sure you expose at 1/60th of a sec.
The reason for your varying lighting is due to the lights cycling with the AC line. You'll possibly notice different lighting at different parts of the gym - even in the same frame. But the bulk of what you are experiencing is due to your shutter speed being able to capture the lights during their cycle.
What we see as normal light - is actually a fluxuation in sync with the current - going from bright white (with an almost green tinge) down to a deep red hue every 1/120th of a second (1/60th to complete a full cycle - hence getting custom WB when you have the full spectrum available) When you shoot from 1/120th to about 1/640th, you'll capture a portion of the cycle. No way to determine which part of the cycle you'll get.
The best you can do is set a WB to match the lights 'designated' color, and deal with the cycling - expect it. The only real way around it is to shoot less than 1/60th of sec - so you always get a full cycle of light. Otherwise, if you shoot 1/800th or faster, you'll minimize the gradient in your photos - but you'll still be at the mercy of where the lights where at the time of exposure.
Older Nikons and the Canon 1D were capable of this all the time because the exposure was controlled by the CCD - not by the shutter as is the case in all film cameras and newer (CMOS and LBCAST) sensors.
Here is what the lights cycling look like to a fast shutter:
http://public.fotki.com/Hammy/gym_lights/
You'll get the same result shooting under similar lights in outdoor fields at night.
Jul 08, 2009 at 06:26 PM
RL15
Image Upload: Off
p.1 #6 · Shooting in gym question
Thanks guys!
I figured it had something to do with the lights but never knew this!
Thanks all!
Jul 08, 2009 at 06:31 PM
timgangloff
Image Upload: On
p.1 #7 · Shooting in gym question
Depending on the type of lights being used and how they are wired, you will see the lights cycle in color and intensity.
Strobing will be the best bet or you will need to do a custom WB for each shot in post processing.
Jul 08, 2009 at 07:37 PM
P Alesse
Image Upload: On
p.1 #8 · Shooting in gym question
Even if you plan on shooting RAW, the lights don't cycle in sync. Quite often, you'll see half your photo in green and the other half in red. My opinion... I have never and I mean NEVER had a parent or editor refuse a great shot because the light cycle wasn't right. Just deal with it.
Jul 08, 2009 at 07:45 PM
Matt Leitholt
Buy and Sell: On
p.1 #9 · Shooting in gym question
Strobes rock for gyms.
Hammy
Image Upload: Off
p.1 #10 · Shooting in gym question
Custom WB doesn't work for the fact that the shutter blades and dynamically cycling cause a gradient:
Only if you get a fast enough shutter speed (1/800th or higher) to 'freeze' the cycling - or use a CCD based camera - then you can deal with a color change that is not a gradient.
Until you shoot gymnastics
And as Paul pointed out, parents seek the shot - not the slight color shifting. Most can be fixed in post, which is much easier than dealing with (setting up) multiple strobe banks and being able to shoot at full speed.
Personally, I've never strobed an event: certainly not gymnastics, and alot of cheer that is held in caverns. Using primes and/or high ISO, we get the shots and parents love them and are amazed that we can get what we get.
Jul 08, 2009 at 09:31 PM
mikekel
Image Upload: On
p.1 #11 · Shooting in gym question
Also new energy efficient lighting is dependent on activity levels in gym, probably rise in temperature. Our new lights are dimmer at begining of events, much brighter an hour or two later if there's enough activity. Indoor track has to be in the gym an hour before events to drive up the lights. It's crazy but saves about $15K on the electric bill. The electric companies subsidize the new lights, we've seen it in several gyms locally. Most have some type of windows providing light during the day. So in addition to cycling, brightness constantly readjusts due to activity.
I found I can generally do 2 white balances, one where gym floor is dominent, the 2nd where gym wall's are dominent.
Jul 09, 2009 at 01:40 AM
h_2_o
Image Upload: Off
p.1 #12 · Shooting in gym question
another problem that i personally have experienced is that some gyms are now using different style lights which messes stuff up as well. it appears as you are dealing with cycling but keep a heads up for gyms with multiple temp lights on different sides causing problems as well.
Jul 09, 2009 at 02:22 AM
canonet
Image Upload: Off
p.1 #13 · Shooting in gym question
Rl15, try strobing, indirectly, with good monolights for better results and do a custom balance to keep colors consistent. Ambient lights no longer become a problem.
Jul 09, 2009 at 08:04 PM
Lost password?
