FM Forums | General Gear-talk | Join Image Upload
Best 24" monitor Go to previous topic Go to next topic
epphoto
Buy and Sell: On
p.1 #1 · Best 24" monitor
Looking for a good 24" monitor for photography
any ideas ??
Thanks Emmanuel
Jul 03, 2009 at 01:53 AM
vladan
Image Upload: Off
p.1 #2 · Best 24" monitor
Eizo make the best monitors for color critical work....
www.eizo.com
Jul 03, 2009 at 01:58 AM
epphoto
Buy and Sell: On
p.1 #3 · Best 24" monitor
Thanks ...wow $1300.00
Looks good , do you know ware to find one ??
Jul 03, 2009 at 02:09 AM
vladan
Image Upload: Off
p.1 #4 · Best 24" monitor
I'm from Australia so you'll have to source them there, most high end photographic and graphic suppliers should sell them, or at least know where to get them. Good luck!
Jul 03, 2009 at 03:15 AM
dirb9
Image Upload: Off
p.1 #5 · Best 24" monitor
NEC 2490uxi is as good as anything Eizo offers in the 24" range.
Jul 03, 2009 at 03:46 AM
jimmy462
Image Upload: On
p.1 #6 · Best 24" monitor
Hi Emmanuel,
Some info discussed on the boards here about the NEC monitors...
http://www.fredmiranda.com/forum/topic/711467/
...and...
http://www.fredmiranda.com/forum/topic/721077/
...and...
http://www.fredmiranda.com/forum/topic/746778/
...also, the NEC pages for their SpectraView II line...
http://www.necdisplay.com/Products/Series/?series=f52d7f47-df4d-4223-b75e-c23e8b085ed7
...good luck with your shopping! Let us know what you decide!
Peace,
Jimmy G
Jul 03, 2009 at 11:55 AM
joezasada
Image Upload: Off
p.1 #7 · Best 24" monitor
the 24" NEC spectraview model is good... although if you can afford it, the NEC LCD2690WUXI2-BK-SV is extremely good, especially for the price...
Jul 03, 2009 at 04:47 PM
Greg Feldman
Buy and Sell: On
p.1 #8 · Best 24" monitor
Leave room in your budget for a hardware-based calibration system--unless you get a monitor that already comes with one.
I would much rather use a calibrated $500 monitor than an uncalibrated $2000 monitor. The latter is basically useless.
Jul 03, 2009 at 04:53 PM
pipspeak
Buy and Sell: On
p.1 #9 · Best 24" monitor
cheaper than an Eizo or LaCie would be the NEC LCD2490WUXi or the HP 2475w. Dell also makes a decent 24-incher but I'm not sure of the model number.
Personally I'm an NEC fan but any high-gamut monitor with at least 12-bit LUT capability is gonna be great for graphics, regardless of the panel technology. And if you're spending $1K+ on a monitor you really need to spend a hundred more and get a hardware calibration system.
Jul 04, 2009 at 02:13 AM
UCSB
Image Upload: Off
p.1 #10 · Best 24" monitor
The best 24" monitor is the 26" NEC 2690.
Jul 04, 2009 at 04:12 AM
stan2
Image Upload: Off
p.1 #11 · Best 24" monitor
the Dell model is the 2408wfp I think. It goes for around $500USD, on sale occasionally. basically, you want either an IPS or a PVA panel, and not a TN panel. you can search around on those technologies and get a lot of info. The 24" iMac is a good monitor and it comes with a computer. Their new price is attractive... Apple 24" is also a nice monitor. There are just a few in the $500-600 range; after that, you're in the pro range and the price goes up.
Jul 05, 2009 at 02:29 PM
BluePixel
Image Upload: On
p.1 #12 · Best 24" monitor
I am also looking for monitor with 1920x1200 resolution, and want to spend about $600-750.
Do any of you know how good are Dell Ultrasharp monitors ?
Thanks.
Jul 05, 2009 at 08:08 PM
wlachan
Image Upload: Off
p.1 #13 · Best 24" monitor
I am eyeing the NEC LCD2490WUXi2 which can be hardware calibrated using the i1D2 (but u need their SPECTRAVIEWII software). At 1/2 that price, there is the Philips 240PW9EB which has H-IPS panel. I had the Samsung 245T for a week but the unevenness was too much to bear.
Jul 05, 2009 at 08:16 PM
mogur2
Image Upload: On
p.1 #14 · Best 24" monitor
What do you recommend for calibrating a monitor?
Jul 08, 2009 at 02:07 PM
n0b0
Image Upload: Off
p.1 #15 · Best 24" monitor
One more thing. LCD runs best at its native resolution so make sure your graphic card can handle high res without chugging if you want to run something high like 1920x1200.
Jul 08, 2009 at 02:10 PM
dirb9
Image Upload: Off
p.1 #16 · Best 24" monitor
Depends on how much you budget, just like anything else. Higher priced calibrators can also calibrate printers and projectors. For under $200, the Xrite i1 Display 2 is very nice, as is the Datacolor Spyder3 Pro. The older Spyder2 doesn't work that well with newer wide-gamut monitors. If you get the NEC 2490/2690, which have built in color look up tables (LUTs), you have a couple choices, you can get the -BK-SV version which includes the calibrator (a rebranded i1) and the software to program the LUT, or you can get the regular version, buy the i1 Display 2, and then purchase the NEC calibration software for $100. If you do get the NEC, you really should get the NEC software, either way.
Jul 09, 2009 at 12:54 AM
Daniel Buck
Image Upload: Off
p.1 #17 · Best 24" monitor
use NEC at work, they seem to be pretty good.
Jul 09, 2009 at 02:06 AM
Lost password?
