2 end
Archive 2009 · How slow is the 5D classic?
DLNB
p.1 #1 · How slow is the 5D classic?
I recently sold my 30D and am planning to buy a used 5D classic. I mostly shoot people, flowers, landscape etc. No sports, birds or wildlife.
What I'm wondering is just how slow is the 5D classic? Will I be running into a full buffer a lot? Autofocus speed?
My 30D was fast enough for me.
I would really like a 1DsMKII but it's a little too expensive.
Jul 02, 2009 at 03:02 PM
jamach
p.1 #2 · How slow is the 5D classic?
if you liked the 30d you will love the 5d, but the 30d gave 5 fps...if that is important then get a 50d and a great lens, or just get a great lens instead of a new camera - the 30d still delivers imho
Joe
Jul 02, 2009 at 03:05 PM
repdomman
p.1 #3 · How slow is the 5D classic?
I bought my 5d used almost 6 months ago after moving up from the XTI. and I'm never looking back. I love the camera, focus and buffer are great. I shoot portrait work and landscapes.
joeypk07
p.1 #4 · How slow is the 5D classic?
DLNB, for your type of photography I don't think you should have any problem with the buffer. If you didn't find yourself running into buffer issues with the 30D you won't like find that problem with the 5d.
Jul 02, 2009 at 03:29 PM
Russ Isabella
p.1 #5 · How slow is the 5D classic?
The 5D doesn't shoot fast enough to fill the buffer! But seriously, it is not slow in any of the ways you've mentioned and I can't imagine you will be disappointed. Frame rate is the only 'limitation' and that isn't likely to be a factor for you.
Jul 02, 2009 at 03:31 PM
Yohan Pamudji
p.1 #6 · How slow is the 5D classic?
The 5D isn't slow compared to the 30D in any way except for frames per second, and it sounds like that won't matter for your use. In just about every other way it's better.
Jul 02, 2009 at 03:35 PM
meechahel
p.1 #7 · How slow is the 5D classic?
For the type of work you're talking about, I doubt you will run into any problems with the 5D. I shoot a lot of sports and often used the 5D as a second body, next to a 1D3 or 1D2N. The cameras obviously have different speed characteristics, but I never had any problem using the 5D. Never filled up the buffer or was disappointed with the AF, just took some time to get used to.
Only gripe is a little shutter lag with the 5D (time from pressing the button to the shutter actually opening). But again, for everyday stuff this is fine and I don't even notice it since I've been using my 5D so much lately. It sounds like the 5D would suit you very well!
Jul 02, 2009 at 03:41 PM
hardlyboring
p.1 #8 · How slow is the 5D classic?
5d is not slow. it is sweet and it will blow the socks off your 30D right away. I have a 5D and 1ds2 and the 1ds2 only beats the 5D on autofocus in low light. 5D is a hell of a machine.
Doug
Jul 02, 2009 at 03:47 PM
joekraft
p.1 #9 · How slow is the 5D classic?
For action shots (my 3 & 2 y.o.), I've never noticed an issue with the buffer. If I miss a shot, it's usually because I'm trying to focus with one of the peripheral AF points, or else trying to do a focus and recompose with the center point. Kids are too kinetic for that usually.
Jul 02, 2009 at 04:15 PM
michael49
p.1 #10 · How slow is the 5D classic?
Fast enough... ...
5D, 70-200 f/4....
Jul 02, 2009 at 04:17 PM
gheller
p.1 #11 · How slow is the 5D classic?
i have 2 cameras: the 5D and the 1D2
comparatively, 5D is sloooooooow
greg
Jul 02, 2009 at 04:47 PM
DLNB
p.1 #12 · How slow is the 5D classic?
Nice! Well thanks for all the replies. I'm very much looking forward to the 5D.
Jul 02, 2009 at 04:48 PM
DLNB
p.1 #13 · How slow is the 5D classic?
greg
This is the kind of thing I've read and the reason I posted the question.
On my 30D I never used the high speed mode. As long as the camera is reasonably fast (similar to the 30D frame rates aside) I'll be very happy with it.
Jul 02, 2009 at 04:51 PM
Ian.Dobinson
p.1 #14 · How slow is the 5D classic?
I think people are getting slow mixed up with FPS. yes the 5d is 3 fps and the 30D is 5 fps (or 3 if you choose.
I think what the OP was meaning (sorry if I'm wrong) was there used to be reports that the 5D was much slower in use.
But going by the specs on TDP
The 5D shutter lag is 75ms with a VF blackout of 145ms
which compares to the 30D of 65ms and 110ms
Yes the 1 series is faster but then you'ed hope so for the extra cost
As for the buffer the 5d is bigger than OP's 30D at there respective top FPS so with the 30D chopped down to 3 fps I would think it would be about the same (the 5D manages 60jpeg or 17 Raw)
Jul 02, 2009 at 05:06 PM
chez
p.1 #15 · How slow is the 5D classic?
What situations did you come across photographing people, flowers or landscapes where you even think you'll run into a buffer issue with any camera?
Jul 02, 2009 at 05:17 PM
DLNB
p.1 #16 · How slow is the 5D classic?
Before my 30D I used a 300D. I just wanted to make sure it's not 300D kinda slow. With that camera I would often have to wait for the buffer to clear if I shot RAW, Never a problem with my 30D and it looks like it wont be a problem with the 5D.
Jul 02, 2009 at 05:32 PM
joezasada
p.1 #17 · How slow is the 5D classic?
You will find the 5D to be pretty good, although if sports or fast-moving objects are your subject then you may want to find a used 1D2 (>$1000) or a used 1D (>$500) since those are easily affordable and are pretty much the best bodies for fast AF (the 5D isn't even in the same class for AF as the 1D types)
Jul 02, 2009 at 05:37 PM
chez
p.1 #18 · How slow is the 5D classic?
joezasada wrote:
You will find the 5D to be pretty good, although if sports or fast-moving objects are your subject then you may want to find a used 1D2 (>$1000) or a used 1D (>$500) since those are easily affordable and are pretty much the best bodies for fast AF ( the 5D isn't even in the same class for AF as the 1D types)
Except when it comes to low light where the 5D has much quicker and more accurate focus than the 1dMKIIn.
Jul 02, 2009 at 07:16 PM
RobertLynn
p.1 #19 · How slow is the 5D classic?
The 5D is plenty fast. The AF is fast, and accurate. Sure, it's not a 1dmk3, but it's going to do a lot better than the 30D.
I OWNED a 30D, I OWN a 5D.
Jul 02, 2009 at 08:19 PM
joezasada
p.1 #20 · How slow is the 5D classic?
I find the opposite... low light AF is where the 1D / 1D2 shines... you can change the focus assist points option or AI servo tracking speed and have a lot of variation, depending on the situation
Jul 02, 2009 at 08:36 PM
freaklikeme
p.1 #21 · How slow is the 5D classic?
Mine had to take a few remedial classes. There was talk about holding it back a grade, but it buckled down and graduated with its class.
Seriously, though, AF is going to be roughly the same. You're losing a couple of frames per second. Work on your timing.
Jul 02, 2009 at 09:25 PM
chez
p.1 #22 · How slow is the 5D classic?
Indoors, my 1DMKIIn hunts and has difficulty getting focus, especially if there is little contrast. Under the same situations, my 5D snaps into focus. A friend of mine has the same experience with his 1DMKII. Outdoors, the situation is totally reversed.
Jul 02, 2009 at 09:30 PM
mirageII
p.1 #23 · How slow is the 5D classic?
FPS aside... How responsive is the interface compared say to a 400D/XTi? And would the buffer clear faster or slower?
Both these cameras use DIGIC II processing but as a more professional model would the 5D be clocked faster?
Jul 02, 2009 at 09:43 PM
harrygilbert
p.1 #24 · How slow is the 5D classic?
I have two 5Ds and a 50D. I find the 50D better for wildlife photography both in terms of focus speed and fps. But the 5D exceeds the 50D in image quality. For both cameras, good "L" glass is really beneficial. When I graduated to a 500/4 my keeper rate went way up.
Jul 02, 2009 at 11:53 PM
stergiopilus
p.1 #25 · How slow is the 5D classic?
The 30D and 5D are very similar in terms of menu and speed at which they do things. They are both based off the Digic II processor, so if you are happy with the speed of your 30D, the 5D will be fine for you. I moved from a 20D to a 5D and am very happy with it, an excellent camera.
Jul 03, 2009 at 12:28 AM
2 end
