2 end
Archive 2009 · TC14E vs TC17E
tmak2654952
p.1 #1 · TC14E vs TC17E
Using on a Nikon 300mm f/4 ED-IF AF-S
Besides the 1 vs 2 f/stop difference, what are the other differences between these two TC's?
Tom Makofski
http://tmak26.zenfolio.com/p699515171
Jun 30, 2009 at 12:30 PM
DGC1
p.1 #2 · TC14E vs TC17E
Used on a tripod, with good technique, the images are almost identical. Once you go up to 400mm lenses and beyond, the 17 isn't as sharp as the 14. On both 500mm and 600mm there is virtually no loss of IQ with the 14 untl you attempt billboard size images. The 17 will start to show IQ loss at about 11" X 17" prints.
Jun 30, 2009 at 12:42 PM
Steve Perry
p.1 #3 · TC14E vs TC17E
Pretty much what DGC said. You get more reach with the 1.7, but it comes at a cost. The 1.4 is almost perfect on most teles, where you do start seeing a quality loss with the 1.7. I only put it on when there is no other way to get a shot. I generally won't hesitate to use the 1.4x if I need a little extra with my 500 or 300.
Steve
Jun 30, 2009 at 12:53 PM
gman1339
p.1 #4 · TC14E vs TC17E
You only lose 1.5 stops with the 1.7 TC, not 2 stops.
Jun 30, 2009 at 12:56 PM
trenchmonkey
p.1 #5 · TC14E vs TC17E
I prefer the 1.7 over the 1.4 with cropping. The light and which body you're using has a lot to do with AF ability. D3 sings with this combo.
Jun 30, 2009 at 01:09 PM
Andre Labonte
p.1 #6 · TC14E vs TC17E
With a 300mm lens, the 1.4 ==> 420mm f/5.6 and the 1.7 ==> 510mm f/6.3. It's like two totally different lenses. Which one is more useful to you. Or get both!
Jun 30, 2009 at 03:55 PM
Avi B
p.1 #7 · TC14E vs TC17E
Actually, the 1.7 is truly a 1 2/3 TC. Which is why it shows up as 500mm f/6.3 on the EXIF data...
Jun 30, 2009 at 03:58 PM
Scott Grant
p.1 #8 · TC14E vs TC17E
and remember the AF will be much slower with the 1.7X vs. the 1.4X.
Jun 30, 2009 at 05:03 PM
tmak2654952
p.1 #9 · TC14E vs TC17E
Thanks guys for the input. Looks like the TC14E will be my choice. . . speed of AF swung it!
Tom
Jun 30, 2009 at 05:27 PM
Avi B
p.1 #10 · TC14E vs TC17E
Post up some shots when done
Jun 30, 2009 at 06:49 PM
Len Shepherd
p.1 #11 · TC14E vs TC17E
If you download software capable of reading Nikon's 120 items of EXIF or use the EXIF link on Flickr the correct focal length is shown plus the distance to more accurate than half an inch up to about 30 meters focus distance using several AF-s lenses.
Here is an example (not with a converter) of the data on flickr http://www.flickr.com/photos/clean_mud/3663694644/meta/
I have no idea why the full (and in some cases correct) EXIF data is not available via Nikon.
Jun 30, 2009 at 07:06 PM
Len Shepherd
p.1 #12 · TC14E vs TC17E
One difference between 1.4 and 1.7 is the 1.7 front element protrudes slightly more with slightly less protection than the 1.4.
My advice is get one of each if you can afford it.
Jun 30, 2009 at 07:11 PM
geniousc
p.1 #13 · TC14E vs TC17E
Using a 300 2.8 I don't seem to notice much difference at all between the two. It's a long ways from being much slower, maybe a little, but not much slower. I've shot BIF close in many times, coming straight at me. The D300 300 2.8 +1.7 nails it everytime if I do my job. I have no complaints whatsover about slow focus.
Which lens are you using with the 1.7 that yours is so slow?
Jul 01, 2009 at 01:06 AM
cadman342001
p.1 #14 · TC14E vs TC17E
+1 but previously I had the f4 and, great lens that it is it's AF doesn't handle the 1.7 as well as the f2.8 esp in less than ideal light which was why I got the 2.8
Andy
Jul 01, 2009 at 02:07 AM
trenchmonkey
p.1 #15 · TC14E vs TC17E
Yup, there's nothing slow about the 300 f2.8 and 1.7TC
D3/D300 take yer pick. The 1.4 comes up short for BIF, in my eyes...just not worth the trouble.
Jul 01, 2009 at 03:20 AM
gman1339
p.1 #16 · TC14E vs TC17E
I think Scott uses both the 1.4 and the 1.7 on a 500 VR with a D300.
As others have mentioned I'm having no problems with the 1.7 mounted to the 300 2.8 VR on either my D300 or D700.
Jul 01, 2009 at 07:38 PM
thebeephaha
p.1 #17 · TC14E vs TC17E
What about for a 70-200 VR?
Jul 01, 2009 at 08:44 PM
Gregg Heckler
p.1 #18 · TC14E vs TC17E
They're both good on the 70-200VR. The 14 is sharper wide open but stopped down 1 stop the 17 is very good.
Jul 01, 2009 at 10:48 PM
Andre Labonte
p.1 #19 · TC14E vs TC17E
+1, the 1.7 needs to be stopped down on the 70-200VR and is soft tacked all the way out to 200mm. Pull in slightly and all is good. I need to get a 1.4.
Jul 01, 2009 at 11:17 PM
gman1339
p.1 #20 · TC14E vs TC17E
I wouldn't exactly call the 70-200 VR soft at full zoom with the 1.7 mounted. Sure it's not as sharp as the naked lens but I'll take it over the 1.4 for a more usable reach with very minimal image degredation over the naked lens. Here's one from the archives...
D70, 70-200 VR wide open at f/4.8 with the 1.7 mounted and racked out to 340mm.
Jul 02, 2009 at 02:51 AM
Andre Labonte
p.1 #21 · TC14E vs TC17E
^^^^ Nice! Maybe I need to get my lens checked out then, but if I pull in just a hair from 200mm with the 1.7 attached, I get much better results. I know others who have experienced the same thing, so it may be a sample to sample issue. I agree about the reach, which is why I have the 1.7
Jul 03, 2009 at 06:49 AM
Scott Grant
p.1 #22 · TC14E vs TC17E
the original poster asked how both TCs work with the 300mm f4 AF-S, not the 300mm 2.8.
why confuse the matter?
the 1.7X is considerable slower to focus on the 300 f4 af-s. end of story.
Jul 03, 2009 at 12:00 PM
Avi B
p.1 #23 · TC14E vs TC17E
The 1.7X is not what I would call "considerably" slower on the AFS 300, at least on a pro body. If you have a D80/D90, etc, then yeah, it will be considerably slower...
Jul 03, 2009 at 01:38 PM
Scott Grant
p.1 #24 · TC14E vs TC17E
it certainly is slower is on my D300. i shot birds all winter with 300 af-s and both teleconverters. ...maybe 20K or more shots.
it is also much slower to focus on my 500 VR than the 1.4X.
Jul 03, 2009 at 03:34 PM
geniousc
p.1 #25 · TC14E vs TC17E
the original poster asked how both TCs work with the 300mm f4 AF-S, not the 300mm 2.8. why confuse the matter? the 1.7X is considerable slower to focus on the 300 f4 af-s. end of story.
Not so on a pro body. Just think about it, the focusing sensor is seeing a little more light from a 1.4 as compared to a 1.7. How much difference is there going to be? BTW, the focusing speed is the same with either converter, it's the same focusing motor. The ability to lock on is what changes.
gene
Jul 03, 2009 at 03:43 PM
2 end
