Wedding Resource List
2 end
Archive 2009 · corrupt RAW files
RL15
p.1 #1 · corrupt RAW files
So for the past while now I've been getting these every 100 or so photos. I get them using my 20D and XTi across multiple brand CF cards and while using multiple different card readers to bring it onto my computer. I cannot pinpoint the source so I'm hoping someone on here has seen this before. The only thing I can think of is my computer? Although I've dropped it onto multiple different hard drives as well....
The kicker is If I go back into the CF card and recopy those images individually its fine... Its just a PITA because I have to dump and then search through all of them to make sure they aren't corrupted before I reuse the card.
When I shoot RAW+jpeg the jpeg copy is always fine.....
Any ideas?
May 29, 2009 at 11:59 PM
dpun
p.1 #2 · corrupt RAW files
jpeg is good but RAW is not. Humm.....RAW converter? What software are you using?
Dave
May 30, 2009 at 12:13 AM
RL15
p.1 #3 · corrupt RAW files
bridge + photoshop
LR also shows the file as such
May 30, 2009 at 12:15 AM
Mike Mahoney
p.1 #4 · corrupt RAW files
I have seen those from time to time, always while shooting sports and chimping / deleting a lot .. never in a wedding situation when I never delete and don't chimp as much.
You really have to watch it with this type of corruption as some programs (DPP) will stop their download at the corrupted file, leaving good files behind them not downloaded.
May 30, 2009 at 12:17 AM
Steverock01
p.1 #5 · corrupt RAW files
Just tagging this one as I have experienced this myself a few times, not when copying the files, but when going back to view them months later. I assumed I had a disk going bad and went to the back-ups again. In fact I'm in the middle of doing a chkdsk /r on the drive now and there are many errors.
If someone has an explanation (and solution) I'd be very interested to hear it.
May 30, 2009 at 12:20 AM
Garry Burton
p.1 #6 · corrupt RAW files
I've experienced the same issue with a Maxton EXT HD corrupting files and with a no name card corrupting files at the same storage/level/space. Here's my kicker, only with RAW and video files?.?.? Must be a size/format thing?
I stick to one brand of HD, one for cards, one for discs (whatever I considered the best and with a good dash of reviews and feedback. WD, SanDisc and Verbatim is my choice but whatever...)
I don't have any more tissue issues .....
Who know's when the gremlins come a visiting.
Cheers Gaz
May 30, 2009 at 02:03 AM
lpazxxsh
p.1 #7 · corrupt RAW files
You know i get these time to time with cheap brand CF cards. But i never get them with Sandisk or Lexar cards. Test your cards to see if you have any bad sectors. Also try transfering them via USB connection from your camera.
May 30, 2009 at 06:14 AM
flash
p.1 #8 · corrupt RAW files
faulty card reader? Faulty USB cable. Interferance (electronic)?
Try changing those.
Gordon
May 30, 2009 at 07:25 AM
BrianO
p.1 #9 · corrupt RAW files
I try never to fill a card more than 80% full. I also use the fastest cards I can get, because RAW files are so large and take so long to write. I don't want to be pressing the shutter release while the previous shot is still being written.
Once I have copied my pictures to my computer, I usually re-format the card IN THE CAMERA, so I'm always starting a shoot with a clean slate. If for some reason I'm going to delete only a few pictures, rather than the whole card, I still do it in the camera, not in a card reader attached to my computer. That way, all writing is done by the same device.
So far, I've never had a corrupted image.
In this case, though, where the files appear to be okay on the card, but corrupted when downloaded as a batch, the problem probably lies in the computer. Reinstalling the software may be indicated.
May 30, 2009 at 08:14 AM
kim2116
p.1 #10 · corrupt RAW files
I used to get this all of the time....Even called Apple and they couldn't figure it out. Shortly after this was happening my computer bombed....Bought a new one and it hasn't happened since. My guess is it is a computer issue. Sorry this is happening to you but am glad to know that I wasn't losing my mind.......
May 30, 2009 at 02:38 PM
jeremy_clay
p.1 #11 · corrupt RAW files
I found the best way to avoid this is plugging the cam via usb directly into the computer - I had a thread a long while ago about it, and found the RAW from a CF card reader to machine would look like the above image, but linking the cam with a cord directly to the comp and using the canon software worked fine.
May 30, 2009 at 02:43 PM
Brian Mullins
p.1 #12 · corrupt RAW files
I'd definitely start by trying a different card reader. That's definitely a corrupt file but from your symptoms, it sounds more like a bad reader or cable.
May 30, 2009 at 02:48 PM
RL15
p.1 #13 · corrupt RAW files
Ummm I've used
Sandisk, Lexar, Adata, Crucial, etc
Many different cards, three different card readers, multiple cameras and multiple HDDs.... I'm assuming it has something to do with my computer....
Just so frustrating... I will try directly from cam to comp though since I've never done that before.
Good to know I'm not the only one
May 30, 2009 at 04:42 PM
Don Price
p.1 #14 · corrupt RAW files
Since they are not corrupt on the card, and you can download them one at a time( some guys didn't read that part) I bet it is a transfer problem between your reader and the computer.
The common thing to do is to try the transfer direct from the camera, if that works using the same data card, the "Reader" if that still not working, ...guess the cable maybe a USB1 Change cables..or the processor in the computer is to slow to hand the big files(didn't say about what computer?) I would question it's the card unless the data was corrupt on the card and that would show on the back screen..
May 30, 2009 at 05:11 PM
jvarszegi
p.1 #15 · corrupt RAW files
Do you have the "Auto Half-Screen Alien Solarizer" option disabled in Photoshop?
May 30, 2009 at 05:17 PM
BrianO
p.1 #16 · corrupt RAW files
jvarszegi wrote: Do you have the "Auto Half-Screen Alien Solarizer" option disabled in Photoshop?
By Jove! I do believe you've got it!
Edited on May 30, 2009 at 10:31 PM · View previous versions
May 30, 2009 at 08:25 PM
dpun
p.1 #17 · corrupt RAW files
RL15 wrote:
bridge + photoshop
Do you experience this issue with DPP?
May 30, 2009 at 08:38 PM
calk
p.1 #18 · corrupt RAW files
I'm betting it's a computer problem: hard-drive controller, hard-drive, or maybe connection between controller and drive. I've seen images look like this in "old" folders which I had not looked at in months, but which were fine when reviewed and processed several months ago and maybe even printed. The images became "corrupt" over time. I have seen it in jpgs and raws. New drive fixed the problem... not the files that were ruined, but the problem stopped occurring when the drive was replaced. Backups "fixed" the spoiled files.
Cal
May 30, 2009 at 08:45 PM
photomania21
p.1 #19 · corrupt RAW files
This happened to me too. It drove me mad and I would even see them corrupt as I was processing them right in front of my eyes. I downloaded the cards onto my husband computer and processed them there without a problem. It wasn't until I replaced my computer for other reasons that the problem stopped (touch wood). It was so frustrating.
May 30, 2009 at 09:31 PM
figmented
p.1 #20 · corrupt RAW files
bad ram can cause this too, i use to have all of my images in my web browser do that and it was bad ram. People like to put the blame on all sorts of things, but this is a regular cause of bad ram. Especially since he said it happens on import/first try and he can re copy it and its fine. google memtest356 and test your ram.
May 30, 2009 at 10:29 PM
Corojo
p.1 #21 · corrupt RAW files
4 years ago had a similar problem - shooting raw w/1D's and would get a corrupt file every once in awhile. The frequency of corrupt files increased and the raid card in the computer died taking along w/it one of the mirrored HD's. Or maybe the HD died first - don't know for sure. New computer - no problems.
May 31, 2009 at 04:26 PM
Sam Obeid
p.1 #22 · corrupt RAW files
Ryan, is it happening everytime? Same image every time? I've personally never run into this issue yet (knocks on wood).
I use Sandisk Extreme IIIs, Sandisk reader and format my cards in camera after they've been copied and backed up.
- Check/update your camera firmware
- make sure you're not using the USB bus with something else at the same time
- card reader should be directly connected to the computer, not through a cheap hub
- make sure no other utilities are running at the same time
- I personally cut and paste the img folder from the card to my pc
May 31, 2009 at 05:07 PM
Tony Hoffer
p.1 #23 · corrupt RAW files
If Sergio took that picture, this thread would be 8 pages long debating whether or not it was art... haha
May 31, 2009 at 05:14 PM
dcaswell
p.1 #24 · corrupt RAW files
So you have two Canon raw files of the same image one that's corrupted and one that's not? Are they the same size? Are you set-up to check for the differences between them? Can you put them up for download somewhere?
May 31, 2009 at 05:17 PM
RL15
p.1 #25 · corrupt RAW files
thanks everyone!
i did a memtest and it seems like my ram is really messed up! this explains a lot actually... i thought maybe i was getting used to the speed of my computer but now that i see this it makes sense that the ram is no good. gonna head to grab some new sticks!!
thanks ya'll
now how do i RMA this ocz crap? lol
May 31, 2009 at 05:58 PM
2 end
