Archive 2009 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
m-a-x
p.1 #1 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Some days ago I finished conversion of a Konica Hexanon AR 57mm F1.2 and want to share some first impressions with you.
I used it on a 300D and I like it!
I think it's in the same league as my Rokkor-PG 58/1.2.
It's a pitty that I cannot mount the Hexanon on my full frame camera (an unshaved 5D).
Due to the protruding rear element it's basically an EF-S lens now
The good thing for users with EOS-crop-bodies who might want to convert this lens: there is no need for mirror shaving. Before I adjusted the focus it was even beyond infinity without any mirror issues.
Here is the lens-camera combo itself and some results.
Some pictures are taken at F1.2 and some stopped down until F2.
All out-of-the-camera jpeg, only resized and compressed afterwards.
May 24, 2009 at 08:01 AM
Ronan O Keeffe
p.1 #2 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Congrats m-a-x,
You've certainly joined a fairly rare group of people!
I have one of those lenses too but use it on a Konica film cam. I think Dim.ka here has converted one for use on a 5D, however a lot of mirror surgery is required. Something like 5mm if I recall correctly.
I'm just wondering does yours have that slight yellow tinge when looking through the viewfinder? Mine certainly does, but I've only shot B&W with it so far so it's not much of an issue.
Congrats once more and have fun with it!
R.
May 24, 2009 at 08:09 AM
m-a-x
p.1 #3 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Hello Ronan
Thank you, I am very happy about the lens!
Yes, the viewfinder is yellow-ish. Also the lens looks a bit yellow but this could be the coating as well.
However, I don't see it on the shots, at least on the day-time pictures.
for instance the cheese picture was shot on a sunny day with Auto-WB.
Some more:
May 24, 2009 at 08:26 AM
jotdeh
p.1 #4 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
That would be why the pics are fine - Auto-WB compensates the yellow tint, much like if you shot under yellow-ish light and WB it.
Appearantly the yellow dicoloration can be caused by a rare earth element used in old glass, but can be cured by exposing to UV light from the sun or a special lamp (read this on the forum here...).
May 24, 2009 at 10:22 AM
Ronan O Keeffe
p.1 #5 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Cheers for the update m-a-x.
One of your fellow Germans has a great site dedicated to Konica. I'm sure you are aware of it, but for others who don't sprechen Deutsch the link is here.
May 27, 2009 at 11:25 AM
Dim.ka_
p.1 #6 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Konica 57 1.2
+ 5D
wideopen
May 27, 2009 at 02:09 PM
m-a-x
p.1 #7 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Ronan,
yes I found that site numerous times when searching for information on conversion but the site does not deal with tearing them apart
Dim.ka_,
your pictures are very nice. In fact, I have to thank you because I decided to convert the Hexanon after I have seen other pictures you made with it
One question with respect to your 5D: how does it look like when you look through your shaved camera? Do you have a reduced frame coverage (less than the original 96%) in the viewfinder? If the answer is yes: does it depend on the lens or not? And is it distracting?
Thx, max
May 27, 2009 at 02:44 PM
Dim.ka_
p.1 #8 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Thanks, m-a-x. Concerning viewfinder - i will try to take a picture how it looks, but firstly i use Nikon DK-17M eyepiece (magnification by 1.2) and if you use fast prime lens 50mm f1.2 or 85 f1.2 up to f4 there is no real difference is your mirror shaved or not - when you stop down the lens defussed black bar from the upper part of the viefinder starts showing about f4 f5.6 and onwards, so if you use a lot lenses with f4 f5.6 it could be the real problem.
May 27, 2009 at 04:38 PM
cavewalker
p.1 #9 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
@Dim.ka_
how did you fit the Nikon DK-17M eyepiece onto your EOS 5D?
May 27, 2009 at 06:07 PM
h_rearden
p.1 #10 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
cavewalker wrote:
@Dim.ka_
http://www.pbase.com/kkawakami/5d
May 27, 2009 at 06:51 PM
szanszan
p.1 #11 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
hello m a x!
ich habe eine frage!
This is a konica ar mount?
Nach dem (konversion) jetzt this a canon eos mount?
We hast du das gemacht?
Du hast the alte mount veck machen end kommt the neue? So einfach?
Danke sehr. Ich habe ein ar 57 1.2 bekommen, ich möchte auch on eos probieren.
Was muss ich machen, oder kaufen?
Danke Sehr,
András
Jun 08, 2009 at 09:26 PM
szanszan
p.1 #12 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Hello MAX!
this adapter ist ein m42 eos modell? oder?
Jun 08, 2009 at 09:30 PM
m-a-x
p.1 #13 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Hallo szanszan, ich schreib Dir eine PM.
Since this is an English forum and the colleague here apparently prefers German, I will answer that by PM.
Jun 12, 2009 at 08:45 AM
debuggerus
p.1 #14 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Wahoo, finally pulled the trigger on one.
Jul 31, 2009 at 12:51 AM
m-a-x
p.1 #15 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
On ebay?
I wanted to place a bid but somebody was faster.
So you got it...
Have fun! Are you going to convert it?
Jul 31, 2009 at 12:35 PM
debuggerus
p.1 #16 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
Yes, I got it from the bay yesterday. Thank you again for the conversion guide on the other thread. It's a big help.
Jul 31, 2009 at 04:37 PM
m-a-x
p.1 #17 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
You're welcome!
Because of this lens I cannot get the idea of shaving my 5D out of my head
Jul 31, 2009 at 05:48 PM
PhotoMaximum
p.1 #18 · Konica Hexanon AR 57mm F1.2 on EOS (300D)
No disrespect, but I sort of find the image quality for this series of images not that remarkable?
Aug 02, 2009 at 06:18 AM
