2 end
Archive 2009 · New to Nikon, help me pick Portrait lenses
photomatt88
p.1 #1 · New to Nikon, help me pick Portrait lenses
Hello! I come from the Canon world and I am thinking about switching systems to Nikon. I mainly shoot people portraits, senior pictures, etc. I shoot indoors and outdoors, although I don't have much room indoors to work with.
On the Canon side I use a full frame 5D with quality "L" lenses.
I love sharp lenses.
Help me validate my selections on the Nikon side to replace my Canon gear. I am looking at the following:
D700 body
Nikon AF DC-NIKKOR 105mm f/2D
Nikon AF-S NIKKOR 24-70mm f/2.8G ED
I'm pretty sure nobody will have any issues or other recommendations for the D700 body, but how does my lens lineup look for portraiture? Are there any better lenses that I should be looking at? I'm trying to keep the entire purchase around $5k - $6k
Thanks for helping.
Matt
Apr 30, 2009 at 05:51 PM
Chris Dees
p.1 #2 · New to Nikon, help me pick Portrait lenses
What L-lenses where you using?
The 24-70 is one of Nikon's best and better than Canon's counterpart.
Nikon has a 85/1.4 which is almost of the same quality as Canon's 85/1.2 II. The AF is much quicker on the Nikon.
The 105/2.0 DC is also a very fine lens and there is a 135/2.0 DC as well (although not that good).
For portraits the 70-200VR is a very good option. Only flaw is relatively soft corners and easily correctable vignetting(in camera or with PP).
Apr 30, 2009 at 05:59 PM
jasoncallen
p.1 #3 · New to Nikon, help me pick Portrait lenses
The 24-70 f/2.8 AFS is just as sharp as (if not sharper than) most of the primes covered by its range. You won't be dissapointed, even coming from using Canon's "L" glass on your 5D. I've used one for multiple portrait shoots, and I can't find a fault with the lens (other than its weight perhaps, but I normally use kit lenses or primes in this range, so I just need to get used to that). I'm going to be getting one soon for use on my D90.
I'd go with the 85mm f/1.4 instead of the 105mm f/2.0 DC. You get a full stop greater amount of light, which is useful as a fast short telephoto for concerts, weddings, or action sports. The AF speed is slightly faster on the 85. Both are excellent, but I'd rather have the 85 f/1.4 (aka the "Cream Machine" due to its buttery-smooth bokeh).
Also, consider getting the 70-200mm f/2.8 AFS VR (my favorite lens. EVER.) or an older 80-200mm f/2.8 AFS at some point. The 70-200 f/2.8 is perfect as a portrait lens (at least in my usage it is), and it completely nukes the background and foreground with smooth, creamy bokeh at f/2.8-f/4. The 80-200 f/2.8 AFS focuses just as fast and does not experience corner softening, but it also lacks VR (Nikon VR = Canon IS). The focusing speed on both is frighteningly fast on consumer grade Nikon cameras, and on pro bodies, neither miss a shot
So my kit for $5k-6k would be:
Nikon D700 ($2100 used/$2700 new after rebate)
24-70mm f/2.8 AFS ($1400 used/$1700 new)
70-200mm f/2.8 AFS VR ($1500 used/$2000 new)
85mm f/1.4 ($900 used/$1100 new)
I'd get the 2 f/2.8 zooms first for the most flexibility and zoom range coverage, and get the 85mm f/1.4 later as an add on. It all depends on whether you buy used or new, and how flexible your budget is! If you buy all used, you're looking at around $5900 with a full setup. If you get everything new, you're looking at about $7500 for the full setup.
Edited on Apr 30, 2009 at 06:16 PM · View previous versions
Apr 30, 2009 at 06:10 PM
jamphan
p.1 #4 · New to Nikon, help me pick Portrait lenses
I would suggest the 24-70 of your options. The 85 1.4 is another option. Great lens!
photomatt88
p.1 #5 · New to Nikon, help me pick Portrait lenses
Thanks all for the comments.
I currently use (canon) 24-105 f4L for my indoor stuff with studio strobes, and I use 70-200 f2.8 for my outdoor stuff.
I had thought about the 85, but it would be too tight for my indoor stuff and too short for my outdoor stuff. I like the outdoor working distance of 100mm +.
I know Nikon has a comparable 70-200 2.8 but it is a little pricey for me at the moment if I also get the 24-70. Plus I would like to start working with a fast prime, which led me to the 105 f2.
I don't mind buying used lenses, but I will need them fast if I make the switch. I'll be selling my Canon gear to fund the Nikon purchases and I can't be without too long. So, waiting for used stuff to turn up, may not be an option.
Thanks,
Matt
Apr 30, 2009 at 06:32 PM
gugs
p.1 #6 · New to Nikon, help me pick Portrait lenses
What I am using for portraiture:
#1 (by far) 70-200VR
#2 24-70
#3 105VR
occasionally: 85 1.8
Guy
Apr 30, 2009 at 06:57 PM
photomatt88
p.1 #7 · New to Nikon, help me pick Portrait lenses
#2 24-70
#3 105VR
Guy
Guy, is that the Nikon AF-S VR Micro-NIKKOR 105mm f/2.8G IF-ED?
Do you have any sample pics taken with that lens?
Apr 30, 2009 at 07:08 PM
gugs
p.1 #8 · New to Nikon, help me pick Portrait lenses
I'll have to search in my database, this is an example from my flickr pics: (105VR @5.6)
Guy
Apr 30, 2009 at 07:20 PM
photomatt88
p.1 #9 · New to Nikon, help me pick Portrait lenses
what body are you using?
Apr 30, 2009 at 07:21 PM
khiromu
p.1 #10 · New to Nikon, help me pick Portrait lenses
Then, you will be happy with 24-70+70-200 for sure. I don't have first hand experience with 70-200, but I do with 24-70 and it's far better than what I expected from my Canon experience. It is expensive, but is well worth it.
And I do have 105VR and that works very well as well, if you don't need reach up to 200mm.
Hiromu
Apr 30, 2009 at 07:28 PM
ryan stewart
p.1 #11 · New to Nikon, help me pick Portrait lenses
If you dont mind used and can afford $1000 look for the 80-200AFS to go along with the 24-70. Its every bit as good as the 70-200 (some argue better opitcally) except for the lack of VR. If you dont need VR that could save you $600-800.
Thanks,
Matt
Apr 30, 2009 at 07:39 PM
photomatt88
p.1 #12 · New to Nikon, help me pick Portrait lenses
Thanks Ryan, that may be an option as I usually use a tripod with all my portrait shots anyway.
Apr 30, 2009 at 07:41 PM
MajinHurricane
p.1 #13 · New to Nikon, help me pick Portrait lenses
I think everyone should be using a 105 f/2.
Seriously.
Apr 30, 2009 at 08:42 PM
musclepics
p.1 #14 · New to Nikon, help me pick Portrait lenses
That depends on the aperture being used with the 24-70's. From F2.8 to F4.0 the Nikon has the edge, but from F5.6 to F11, the Canon is sharper. So for strobes, the Canon is better. Also, the build on the Canon is slightly better imho (but both are good). People who complain about the Canon version probably had poor copies (which used to happen a lot a few years ago).
The 85L is MUCH better than the Nikon 85/1.4 in IQ, but the Nikon is still dece.
On full frame, the Canon 70-200's are better than the Nikons, but the Nikons are still not bad (the corners are a problem).
Personally, for portraiture, I would stick with Canon since you already have the better L lenses, and get a 5D2 over the D700. With the money you save not switching systems and on expensive Nikon glass, you get twice the resolution, and some money saved for a new lens or two... and HD video to boot
Apr 30, 2009 at 08:49 PM
Bruce Sawle
p.1 #15 · New to Nikon, help me pick Portrait lenses
I have both systems and they are Apples to Apples. Both 24-70 are excellent lenses and only the most anal pixel peepers would find any difference from F4 to F11 at F2.8 the Nikon has a slight edge. The 70-200's once again are both stellar. I prefer the Nikon version it is much sharper at all apertures in the center. Canons 70-200 has the advantage in Minimum focus distance about 5 feet less. Lets talk about the 85's both are incredible lenses the Canon is much sharper at 1.2 (duh). The Nikon is IMHO is at least a sharp if not better at F1.4 they seem to be equal at all other apertures. The Nikon is also much smaller and focuses much quicker. With that being said I still miss my 85L the bokeh was the king.
Apr 30, 2009 at 09:47 PM
thedruid
p.1 #16 · New to Nikon, help me pick Portrait lenses
Why are you switching? I'm just wondering as I did exactly the same 5 months ago. I take exactly the same type of images with the D700 as I did with the 5D, there was no wow factor as I shot full frame for 3 years with the Canon. The 24-70G is worth the price of admission on the D700, it was way ahead of my calibrated Canon L. BUT I miss my 17-40L /24-105L/ 70-200 L IS F4 combo. I'm a generalist these days and the D700 handels all I shoot. If I was shooting a lot of portraits boy I'd hesitate.
The grass can appear greener on the other side, I had a loaner D700/24-70G from Nikon for a month before taking the plunge, but even today I do have second and third thoughts...
Please no flames here just an honest opinion of someone who made the move and shoots daily.
Apr 30, 2009 at 10:02 PM
AGeoJO
p.1 #17 · New to Nikon, help me pick Portrait lenses
Matt,
I believe thedruid asked a valid question. Especially now, since the D700 is a tad short on MP compared to the 5D MarkII. It would be different if the D700x with at least 21MP would be available right now. Most people considering the switch because of the AF but you are shooting portraits and senior pictures... Well, Matt, it is your money though. Good luck!
Apr 30, 2009 at 10:35 PM
musclepics
p.1 #18 · New to Nikon, help me pick Portrait lenses
Bruce Sawle wrote:
I have both systems and they are Apples to Apples. Both 24-70 are excellent lenses and only the most anal pixel peepers would find any difference from F4 to F11 at F2.8 the Nikon has a slight edge. The 70-200's once again are both stellar. I prefer the Nikon version it is much sharper at all apertures in the center. Canons 70-200 has the advantage in Minimum focus distance about 5 feet less. .
Yeah, that's pretty much what I saw with the 24-70's, very close, with an edge to one or the other depending on the aperture.
Are you using full frame or crop on the Nikon? Because Dpreview shows that while the Nikon 70-200 is sharper on the crops, the Canon 70-200 is much better on the full frame sensor.
For example, this is what I get with the Canon 70-200/2.8L IS at 200mm wide open. And 200mm is that lens' softest range. I get even sharper shots at 135mm. I use a 1D so I'm half way between normal crop and full frame.
Canon 70-200/2.8 IS, 200mm, F2.8
I think the fact that the systems are so close is why I don't think it's worth switching from one to the other.
Starting from scratch though, the D700 is a really nice camera.
Apr 30, 2009 at 10:46 PM
AGeoJO
p.1 #19 · New to Nikon, help me pick Portrait lenses
musclepics,
Sorry, I must have missed your post before that of thedruid.....
Apr 30, 2009 at 10:59 PM
Bruce Sawle
p.1 #20 · New to Nikon, help me pick Portrait lenses
I am shooting with a full frame D3x and while the Canon is a bit better in the corners the Nikon to me is better in the middle of the frame. This is where it is crucial for me as I shoot primarily portraits. But as I said before they are both so close that I would be happy with either one.
Apr 30, 2009 at 11:13 PM
musclepics
p.1 #21 · New to Nikon, help me pick Portrait lenses
Thanks for the info Bruce.
May 01, 2009 at 12:01 AM
photomatt88
p.1 #22 · New to Nikon, help me pick Portrait lenses
Thanks all for your concern and advice about why I am considering the switch from Canon to Nikon. Although I did say that I do mainly shoot portraits and for that my 5D and canon system works great. The part where it falls short is when I use it for personal shooting of my 2 year old son. The autofocus system just cannot keep up as well as I think the D700 could. I also really miss the built in pop up flash that is non-existant on the 5D or 5D2, not for portrait work, but comes in handy shooting with the kids. I just think the speed of the D700 and the low light capabilities will meet all my needs.
May 01, 2009 at 02:16 AM
Gregory.Rotter
p.1 #23 · New to Nikon, help me pick Portrait lenses
I think on FF the 105 F2 has a focal length, that for portraitrs is easier to work with than the 85 F1.4. I've heard of issues with front/back focus on the 105 F2, which is what would hold me back. I'd test this lens for either of these issues. Sure some say you can adjust the ammount of DC to compensate for the front/back focus issue (if present), but you shouldn't have to do that. Then theres the fact that the D700's af fine tine might not be able to fix to the problem 100%. I'm speaking purely on what I've read on forums.
May 01, 2009 at 09:35 AM
thedruid
p.1 #24 · New to Nikon, help me pick Portrait lenses
The pop up flash is more useful as a commander when shooting off camera strobes, you'll need to have a "short" lens mounted to avoid shadows in the lower part of the frame.
I'd also read up on the 105/135DC on some of the Nikon based forum as there are issues. Some say it may be a lack of understanding of how DC works but there's a long thread on Nikon Cafe form a pro portrait shooter about 105DC going back and forth to Nikon with a Canon like response that the lens is within specs.
Not tying to put you off it's your money but I've figured out the people I work with don't care what I shoot with they care only about the file. I'm still turning that damm wheel to change my aperture the wrong way after five months...
May 01, 2009 at 12:01 PM
Oasisbill
p.1 #25 · New to Nikon, help me pick Portrait lenses
Here's my 2c. If you don't mind MF, 105mm f/2.5 P-C ($150ish) It's made for portraits.
The older 28-70mm f/2.8 is just about as good as the 24-70 (not just according to me), just different, and is now a lot cheaper and you lose 4mm at the wide end. I have it and it's a bit big and unwieldy but I love what it does. Hope that helps..
May 01, 2009 at 01:21 PM
2 end
