Archive 2009 · Canon 24-70L lens problem
John Rose
p.1 #1 · Canon 24-70L lens problem
Anyone know if Canon calibration can fix the following problem: The lens is real soft at 24mm at any F stop on manual or A/F. But very good at mid range to 70 zoom. This would seem to be an internal element adjustment to me. What say you guys?
Apr 09, 2009 at 02:44 PM
p.1 #2 · Canon 24-70L lens problem
Send it in.
Apr 09, 2009 at 02:49 PM
davidrwilliams
p.1 #3 · Canon 24-70L lens problem
Before you send it in try this...
1. Using a tripod frame your subject at 24mm, zoom to 70mm and focus on your subject using AF.
3. Zoom back to 24mm and shoot a frame without refocusing from the 70mm focus point.
4. De-focus the focus manually, then let the camera autofocus itself at 24mm and shoot another frame.
5. Compare the two frames to see if the first frame is more accurately focussed than the second.
The 24-70 is notorious for having autofocus "challenges" for some subjects under some lighting situations, but I've been able to work around them by focusing at 70mm and zooming back to shoot.
...and yes, my copy is as par-focal as could be hoped.
Apr 09, 2009 at 03:01 PM
John Rose
p.1 #4 · Canon 24-70L lens problem
David I tried that on an object about 12 feet away and F8 and the shot was soft from foreground to background, in other words no part of the depth of field was good. I suspect the internal elements .
Apr 09, 2009 at 03:31 PM
jhom
p.1 #5 · Canon 24-70L lens problem
Send it in for recalibration.
Jim
Apr 09, 2009 at 03:36 PM
njjuliano
p.1 #6 · Canon 24-70L lens problem
If the parfocal method outlined by David does not work, then definitely send it in.
Apr 09, 2009 at 03:51 PM
The Image
p.1 #7 · Canon 24-70L lens problem
David, when you say your "copy" is par-focal, does that mean that not all 24-70L's are par-focal?
Apr 09, 2009 at 10:41 PM
Milan Hutera
p.1 #8 · Canon 24-70L lens problem
The lens is *not* par-focal. Even the lens manual says so.
Apr 10, 2009 at 12:53 AM
BrianJ
p.1 #9 · Canon 24-70L lens problem
http://www.rogercavanagh.com/helpinfo/30_parfocal.stm
http://www.digitaljournalist.org/issue0606/tech-tips.html
and post #13 in http://www.prophotohome.com/forum/canon-eos-digital-slr-1-6x-sensors/22856-list-canon-parafocal-zooms-anywhere-2.html
and my copy certainly is
Apr 10, 2009 at 07:11 AM
orangefirefish
p.1 #10 · Canon 24-70L lens problem
The length of the front element of the lens change slightly with the zoom, so can it be perfectly parfocal?
Apr 10, 2009 at 07:47 AM
davidrwilliams
p.1 #11 · Canon 24-70L lens problem
...which is precisely why I said "my copy is parfocal", as anticipated that this debate would begin again.
Chuck Westfall's post #13 referenced above pretty much says it all. In my experience, if I focus at 70mm, zoom back to any other focal length without refocusing, and shoot, the resulting focus point remains sharp regardless of the aperture used for the shot.
Apr 14, 2009 at 06:14 PM
