thomasfxlt Offline Upload & Sell: Off
p.1 #7 · Profoto Barndoors....(505-521) | |
Thanks for the measurements. My speedo's are only 6-5/8's as well. If they were a true 7 inches, I think the grids would actually sit on prongs that stick out of the bardoors over the edges of the reflector and under a spring clip that is part of the barndoor designed to hold something in place. These diameter of these grids is too narrow. Anyone aware of another after-market grid set that is closer to a true 7"? The profoto reflector is 7-1/8 as you indicated.
316shooter wrote:
The profoto grids actually only measure about 7 1/8" across. But the 10 degree one I have is nearly 1" deep. For what it's worth, the other speedo grids I have, while considered 7", only measure just over 6.5"
