Moderated by: Tom Hicks
Macro World Resource
FM Forums | Macro World | Join Image Upload
Rev 35-80mm Go to previous topic Go to next topic
Crisjm
Image Upload: Off
p.1 #1 · Rev 35-80mm
This shot is with a rev 35-80mm ef lens. I have tried the aperature set and hold DOF preview. When I take the lens off and reverse it my AVsets to zero. Is this normal? The DOF is crazy thin at 35mm which this shot was taken. Any help is greatly appreciated as well as C&C.
Jan 08, 2009 at 11:07 PM
this time
Image Upload: Off
p.1 #2 · Rev 35-80mm
That's normal. AV 00 displays because the electrical contacts of the lens aren't attached to the camera. Newer digital slrs meter fine like this so there is nothing to worry about.
Jan 09, 2009 at 04:28 AM
Crisjm
Image Upload: Off
p.1 #3 · Rev 35-80mm
Thank you.....I did not know if it actually affects the DOF or not.
Jan 09, 2009 at 04:58 AM
Pixel Perfect
Image Upload: On
p.1 #4 · Rev 35-80mm
I think someone has their wires crossed.
Jan 09, 2009 at 06:09 AM
LordV
Image Upload: Off
p.1 #5 · Rev 35-80mm
Good one
What F stop did you set- did you check the aperture had locked by looking down the lens ?
Brian V.
Jan 09, 2009 at 07:48 AM
Crisjm
Image Upload: Off
p.1 #6 · Rev 35-80mm
Lord V--I just double checked and yes it locked. I guess I just dont quite understand getting the exposure correct. Even though the F stop says "00" can I asume that I would just adjust shutter speed for correct exposure? Using a rev lens does setting the F stop still work the same as a normal mounted lens? Again thank you for the info.
Jan 09, 2009 at 01:26 PM
Lost password?
