Archive 2009 · Wide alternative for full frame?
shane jordan
p.1 #1 · Wide alternative for full frame?
Right now the one lens I am lacking is a super wide (16-17mm).
I was wondering if anyone had suggestions on a canon mount lens that is fast and wide. I know the 16-35 f/2.8 L II is awesome, but for to me it seems a little high for the small amount of time I will be using it. I rarely have the need to go wider then 24mm, but at times I do need it.
This will be for a 5D and 5DMII
Jan 06, 2009 at 10:48 AM
Shuko
p.1 #2 · Wide alternative for full frame?
Sigma 12-something or EF 17-40
Jan 06, 2009 at 10:49 AM
Ian.Dobinson
p.1 #3 · Wide alternative for full frame?
Widest you can go (without fisheye's) is sigma 12-24 , its FF at 12mm.
Canon 17-40/4 is pretty dam wide on FF
Or you can use some of the Crop body designed lenses (not efs) like the tokina 12-24 or 11-16 (only works at about 15-16 I think so it becomes almost a prime).
You just loose the very wide end uptil about 14-16mm which is no worse than the 16-35 anyway. Also the earlier Canon UW like the 17-35/2.8 might be worth a look
Jan 06, 2009 at 11:06 AM
ward1066
p.1 #4 · Wide alternative for full frame?
sigma 20mm 1.8, cheap, fast, optically very good.....AKA El Hombre
deepbluejh
p.1 #5 · Wide alternative for full frame?
If you can deal with F4, then the 17-40/4 L is excellent. The Sigma 20/1.8 looks great on paper, but sucks in practical usage. The 16-35/2.8 version I can be found for significantly less money than the version II, but its corners are a bit lacking compared to the 17-40/4 and 16-35/2.8 II.
Jan 06, 2009 at 11:18 AM
akclimber
p.1 #6 · Wide alternative for full frame?
The Sigma 12-24 is wide but not fast (I use one on a 5D). Good image quality, especially away from the corners. Very little to no linear distortion. 12mm on full frame is realy, wildly wide - much, much wider than say 16mm or 17mm. If you can sacrifice fast for wide, the relatively affordable Sigma may be the way to go. I also use a Sigma 20 f/1.8 on the 5D. Good (but not great) image quality, affordable, fairly wide and very fast. I use it primarily for auroras. There's always a 3rd party 14 f/2.8, like Sigma or Tamron (or is that Tokina?).
The Canon 17-40 may be a good compromise - not the widest or the fastest but a decent balance perhaps, depending on your needs.
Good luck!
Cheers!
Jan 06, 2009 at 11:22 AM
Bruce Sawle
p.1 #7 · Wide alternative for full frame?
If your shooting landscapes at F8 to F16 then I would recomend the 17-40 but on my 1DS MK III the 17-40 at F4 and F5.6 is not great.
Jan 06, 2009 at 11:38 AM
EyeBrock
p.1 #8 · Wide alternative for full frame?
I use the 16-35 II more than anything else on my 5D2. It was great on my 20D but I love it on FF. I would never sell this lens!
Jan 06, 2009 at 05:32 PM
will_fm
p.1 #9 · Wide alternative for full frame?
I have had good results across the whole range with my 17-40L, although I of course tend to shoot mostly at f/8 or more. I checked the pictures I took at f/4 and they tend to be around 40mm for whatever reason, but I have quite a few keepers at f/5.6 and 17mm. But for low light I go for a fast prime anyway most of the time.
Jan 06, 2009 at 06:03 PM
Rob Chisholm
p.1 #10 · Wide alternative for full frame?
The alternative board has been talking about the Nikon 14-24 mounted on the Canon 5D2 or 1Ds3-- I bought this lens and am absolutely blown away! On my 5D2 -- Freakin' amazing for landscapes/cityscapes, etc. -Rob
Jan 07, 2009 at 12:47 AM
dcad10
p.1 #11 · Wide alternative for full frame?
tamron 17-35mm f/2.8-4
Jan 07, 2009 at 12:58 AM
EyeBrock
p.1 #12 · Wide alternative for full frame?
I had the 17-35, nice lens but it did suck a lot of dust into my old 20D.
Jan 07, 2009 at 12:55 PM
garyvot
p.1 #13 · Wide alternative for full frame?
My 16-35 II does not get really solid in the extreme corners until about f/8 or so. However, I find this quite acceptible for landscape work, architecture and so on, and for PJ and low light work its wide open performance is fine in the center.
The Nikon is apparently better in the corners at wide apertures, but I'm not sure how many people really extreme edge performance at wide apertures. If you're one of them, by all means look at the Nikkor.
Jan 07, 2009 at 02:25 PM
mufutau
p.1 #14 · Wide alternative for full frame?
Tamron 17-35mm f/2.8-4.0
Mufutau
Jan 07, 2009 at 02:49 PM
Makten
p.1 #15 · Wide alternative for full frame?
It does? Funny, I think it shines, except for the distortion.
@ f/4 on Nikon D700:
http://img.photobucket.com/albums/v621/Makten/Sigma_20/DSC_0187.jpg
100% crop:
http://img.photobucket.com/albums/v621/Makten/Sigma_20/DSC_0187_crop.jpg
100% crop bokeh:
http://img.photobucket.com/albums/v621/Makten/Sigma_20/DSC_0187_crop2.jpg
Yeah, it really sucks...not.
Edit: And if you wanna go idiot-wide, why not the Sigma 14/2,8?
On Nikon D700:
http://img.photobucket.com/albums/v621/Makten/Sigma_14/DSC_1376.jpg
And a 100% crop:
http://img.photobucket.com/albums/v621/Makten/Sigma_14/DSC_1376_crop.jpg
Do mind the very strange flare on the bumper. This is one of the flaws with this lens. You really can get flares even when it is overcast!
Edited on Jan 07, 2009 at 04:09 PM · View previous versions
Jan 07, 2009 at 04:02 PM
orangefirefish
p.1 #16 · Wide alternative for full frame?
how fast do you need the lens to be? If you shoot at smaller apertures then the 17-40L is a good value- it really shines at f/8 and smaller.
Jan 07, 2009 at 04:08 PM
sirimiri
p.1 #17 · Wide alternative for full frame?
You could also buy the 15mm Canon fisheye and "defish" via software, but that of course alters the resolution.
It's not that expensive.
Jan 07, 2009 at 04:29 PM
Geofn
p.1 #18 · Wide alternative for full frame?
And astonishingly sharp as well.
Jan 07, 2009 at 04:36 PM
meechahel
p.1 #19 · Wide alternative for full frame?
My vote goes for the 17-40L. I love it on my 5D - provides a lot of versatility from being super wide to decent for portraits at 40mm. Mine's plenty sharp at f/4 and obviously better stopped down. Ever since I got it I rarely take it off the 5D.
Only gripe is I indoors I could really use f/2.8. But for the type of work I do it simply isn't worth the extra bucks for the 16-35.
And if you want REALLY wide, look into the Sigma 12-24mm. I've heard plenty of good things about that lens...but in my opinion the 17-40L is the better option.
Jan 07, 2009 at 04:42 PM
tsangc
p.1 #20 · Wide alternative for full frame?
Another vote for the 17-40mm. One major reason is they're easy to find on the used market and fairly cheap.
Jan 07, 2009 at 09:08 PM
