2 end
Archive 2009 · Rokkor 45mm f2
Chris Radley
p.1 #1 · Rokkor 45mm f2
Hi, is this lens any good based on people's experiences?
I've just started building a collection of alternative lenses and today bought a 58mm f1.2 MC Rokkor which is beautiful. Is the 45mm f2 Rokkor similar in IQ?
Thanks
Jan 05, 2009 at 08:34 PM
rsrsrs
p.1 #2 · Rokkor 45mm f2
hi,
if you have a rollei EOS adapter, you can clamp it on the minolta mount
an test it until 3-4m without building anything.
My first view with it on my 5D was very promising.
but converting it will not be easy.
later this month i hopefully know more.
mit freundlichen gruessen
r schneider
Jan 05, 2009 at 09:53 PM
Chris Radley
p.1 #3 · Rokkor 45mm f2
Thanks.
I was thinking I might be able to follow Cogitech's conversion process. Really just wondering what the IQ of the lens is like.
Jan 05, 2009 at 11:06 PM
Ed Sawyer
p.1 #4 · Rokkor 45mm f2
IQ is ok but nothing super special. Certainly not rokkor 58/1.2 quality or even 50 1.4 quality IMO.
I have a test of it posted I think at www.edsawyer.com/lenstests/
if it's not there, I have it but haven't posted it yet.
-Ed
Jan 06, 2009 at 12:44 AM
badastronaut
p.1 #5 · Rokkor 45mm f2
i have the 45mm f2, two actually since it was so cheap might as well buy a spare.
IQ is pretty good, very pancake like compact and lightweight which helps for discrete shooting. Definitely no where near 58mm f1.2.
It was sold as a kit lens i believe.
Jan 06, 2009 at 02:24 AM
weezintrumpete
p.1 #6 · Rokkor 45mm f2
Sorry to bump an old thread, but is there any information on converting one of these to EOS? I recently acquired one for $20 and thought it'd be nice to use as a pancake on a 5D. I've heard rumors of something related to the Cogitech forum (which is down) and I can't find any information on how to do the conversion.
Thanks!
Apr 07, 2009 at 02:55 AM
trumpet_guy
p.1 #7 · Rokkor 45mm f2
It's small but not greatly smaller than a Contax CZ 50/1.7 and so I've never
thought much about converting mine to EOS mount.
I don't recall ever seeing instructions here on how to do that conversion,
but best wishes. Maybe you'll find the site.
Apr 07, 2009 at 04:35 AM
CVickery
p.1 #8 · Rokkor 45mm f2
JimBuchanan described his approach once for me. It isn't easy and the lens probably doesn't have the IQ to make it worthwhile. The 45/2 I bought for $15Cdn is still a Minolta mount. If I happen across a MD>4/3 adapter some day that's cheap enough I may try it out on my friend's Oly.
Apr 07, 2009 at 04:41 AM
debuggerus
p.1 #9 · Rokkor 45mm f2
Well, I really like my converted one .. I think it's a sleeper, especially so cheap. I think it is easier than the 50 1.4. Used a circular grinder, sanded down .5 mm. It's easy to sand since the MD mount is removable from the bottom base. I think you should try to convert it. Good luck.
A sample:
Apr 07, 2009 at 10:06 PM
weezintrumpete
p.1 #10 · Rokkor 45mm f2
That looks great debuggerus. Any more samples? I also sent you a PM...
Apr 07, 2009 at 10:57 PM
JimU
p.1 #11 · Rokkor 45mm f2
i'd like to see more samples as well please. about 1028x768?
i've got one on my minolta XG-1 but it's focus ring is kinda loose.
Apr 07, 2009 at 11:00 PM
debuggerus
p.1 #12 · Rokkor 45mm f2
One correction: now that I look at the conversion, it is the same difficulty as the rokkor 50 1.4. I had to grind both the mount base and the M42-EOS adapter and adjusted infinity focus from the front in the end.
As request, a few more larger samples:
100% crop:
mounted on a 40D:
some more:
Apr 08, 2009 at 03:45 AM
weezintrumpete
p.1 #13 · Rokkor 45mm f2
Wow, I am impressed and now very interested in doing this conversion
Apr 08, 2009 at 02:27 PM
debuggerus
p.1 #14 · Rokkor 45mm f2
I've completed another 45mm f2 conversion. This time I managed to record the process.
The process should be similar with many other rokkors (50 f1.4, 85 f2, 28 f2, ...) using simpler tools (I wish I had a lathe). I hope it will be helpful.
45mm F2 to EOS conversion
Cheers!
PDo
Apr 21, 2009 at 02:51 AM
weezintrumpete
p.1 #15 · Rokkor 45mm f2
Thanks for posting that! Does anyone else have any experience with the 45mm on EOS? I'm going to attempt the conversion soon...
Apr 21, 2009 at 03:09 PM
matthewm
p.1 #16 · Rokkor 45mm f2
I really, really love this lens on my X700 so I think I'll keep it that way. Don't want to go cutting and gluing and messing around with a perfectly good lens. REALLY wanted this to use on my 5D, but I can't justify the trouble that it's most likely going to cause me.
Not to mention I don't have the tools to get it done properly.
Nice images though. And a GREAT tutorial.
Best,
Matthew
Aug 28, 2009 at 08:55 PM
Makten
p.1 #17 · Rokkor 45mm f2
Lovely bokeh there! Just a trace of outlining of the blur discs, which makes it "interesting" but still smooth.
Edit: And of course; great shots of the kids!
Aug 28, 2009 at 09:22 PM
Jim Schemel
p.1 #18 · Rokkor 45mm f2
Here is a set taken with my 45 Rokkor on a 5D
http://www.flickr.com/photos/footstool67/sets/72157622079471838/
Very nice lens great sharpness and color and very small and light
-Jim
Aug 29, 2009 at 04:38 PM
Cableaddict
p.1 #19 · Rokkor 45mm f2
Cheers!
PDo
Debuggerus, thanks for the excellent pictorial guide.
One thing puzzles me, though: You remove the aperture mechanism, and never replace it? How does that work? Is that mechanism only there for when the (Minolta) camera does auto stop-down?
Also: Any mirror issues? (I use a 5D, so this is always a concern)
thanks
Sep 17, 2009 at 07:07 PM
cogitech
p.1 #20 · Rokkor 45mm f2
The aperture mechanism needs to be re-installed onto the back of the plate before assembly, or aperture control will be lost altogether. There should be no mirror issues to worry about.
Sep 17, 2009 at 07:50 PM
Dim.ka_
p.1 #21 · Rokkor 45mm f2
smooth bokeh is only at close to minimum focusing distaces at more common 1-2 meters it is quite busy, but has very strong 3d look
upper part crop
Sep 17, 2009 at 08:00 PM
Cableaddict
p.1 #22 · Rokkor 45mm f2
Thanks, Paul.
I figured as much, but that tutorial fails to mention this step. ( ! )
In general, are there no mirror issues with MD lenses and a 5D? I'm considering a different MD lens. I will be doing a slight shave of my mirror anyway, for my upcoming MC 58/1.2 conversion, but it would be good to know. It's really hard to find this info online.
Thanks.
Sep 17, 2009 at 10:02 PM
cogitech
p.1 #23 · Rokkor 45mm f2
I wouldn't generalize about all MDs, but the 45/2 didn't cause mirror issues for me and I haven't heard anyone else complain about it.
Sep 17, 2009 at 10:19 PM
Jim Schemel
p.1 #24 · Rokkor 45mm f2
I also had no mirror issues with my 45 f2 on my 5D and achieved infinity focus with out adjustment
-Jim
Sep 17, 2009 at 10:22 PM
pengland
p.1 #25 · Rokkor 45mm f2
How is the adapter attached to the reduced back in this conversion? I see no screw holes in the adapter so some other method must have been employed.That step looks to be missing.
After taking a second look I see mention of glue. If it is glued on, how does one carry out cleaning or repairs afterward?
Sep 17, 2009 at 11:24 PM
2 end
