Archive 2009 · Melissa: More IMGs added
jprezant
p.1 #1 · Melissa: More IMGs added
For your consideration.
Melissa:
http://jasonprezant.com/melissaheadshot.jpg
this one is just a bit of fun
2
http://jasonprezant.com/melissaretro.jpg
And another
3
http://jasonprezant.com/melissasitting.jpg
Jason
Edited on Jan 03, 2009 at 11:58 PM · View previous versions
Jan 03, 2009 at 06:37 PM
mttran
p.1 #2 · Melissa: More IMGs added
Very Nice, Jason
Jan 03, 2009 at 06:49 PM
canerino
p.1 #3 · Melissa: More IMGs added
looks good j!
can you describe your lighting?
Jan 03, 2009 at 07:36 PM
mel14
p.1 #4 · Melissa: More IMGs added
very good candidate for magazine cover...
Jan 03, 2009 at 07:45 PM
radioblurs
p.1 #5 · Melissa: More IMGs added
canerino wrote:
looks good j!
i'll take a stab at that it's a rembrandt, so light should be high and to camera right with a white reflector on camera left-i'm thinking the background was lit by the falloff-how'd i do, j?
definitely like the pic, though i would suggest lightening the shadows under her eyes
daniel
Jan 03, 2009 at 08:24 PM
jprezant
p.1 #6 · Melissa: More IMGs added
Spot on Daniel Thanks.
Jan 03, 2009 at 09:05 PM
Steady Hand
p.1 #7 · Melissa: More IMGs added
Looks nice for this type of image.
Keep up the good work.
Jan 03, 2009 at 09:20 PM
stan_r
p.1 #8 · Melissa: More IMGs added
I agree Rem lighting. Nice job with smooth transition from light to dark.
Jan 03, 2009 at 09:39 PM
John Power
p.1 #9 · Melissa: More IMGs added
I am missing something here. According to this article
"The fourth style of lighting is Rembrandt Lighting. Rembrandt lighting is obtained by combining short lighting and butterfly lighting. The main light is positioned high and on the side of the face that is away from the camera. This technique produces an illuminated triangle on the cheek closest to the camera. The triangle will illuminate just under the eye and not below the nose."
No part of her face is away from the camera. She is looking directly at it. For this reason, there is no "cheek closest to the camera"
Jan 03, 2009 at 10:01 PM
jprezant
p.1 #10 · Melissa: More IMGs added
More Images Added
---John--- I don't know the names for lighting setups. I don't even know the setups. I'm just playing to see what looks good and what looks like mud.
Jan 04, 2009 at 12:08 AM
radioblurs
p.1 #11 · Melissa: More IMGs added
nice, j-these are some of the best images i've ever seen from you-kudos!
not sure but it might help to retouch/fix the purple sports bra/tank top sticking out in shots 2 and 3-by no means a dealbreaker, though-rock on, man
daniel
Jan 04, 2009 at 12:11 AM
jprezant
p.1 #12 · Melissa: More IMGs added
Haha yea. I don't know why she was still wearing that, I should've had her take it off. Not sure if there's a good way to fix it other than rebuilding the dress in #2 and her back in #3.
Jan 04, 2009 at 12:18 AM
John Power
p.1 #13 · Melissa: More IMGs added
Regardless of the lighting style nomenclature they certainly are great exposures. Are those baseboards I see behind her in 3?
Jan 04, 2009 at 09:57 AM
RobertLynn
p.1 #14 · Melissa: More IMGs added
John, keen eye, I think they are baseboards
Jan 04, 2009 at 11:25 AM
Y_vdm
p.1 #15 · Melissa: More IMGs added
The #1 and #2 are really outstanding and works for me.
The #3 doesn"t work ... I comes from the legs position combined with the feet....
Jan 04, 2009 at 11:28 AM
jprezant
p.1 #16 · Melissa: More IMGs added
Indeed they are. I was going to remove them, but I decided that they added a subtle touch that I actually enjoyed. I like the lines.
John Power
p.1 #17 · Melissa: More IMGs added
To be perfectly honest Jason I think they are distracting, but each to his own. Great minds do not always think alike.
Jan 04, 2009 at 11:44 AM
jprezant
p.1 #18 · Melissa: More IMGs added
Fair enough also. I'm lazy.
Jan 04, 2009 at 02:19 PM
rcorrington
p.1 #19 · Melissa: More IMGs added
Here are my thoughts about image #3…
1) I love the lighting, although I would have darkened the left edge a bit to help push attention towards the model’s face.
2) Love the hair and the makeup. They really add to the feel of the image.
3) My rule is… if it can bend, bend it. The model’s back leg and left arm are straight. The straight leg looks like a slab of meat rather than the lovely feminine form that it is. The left arm looks like a column of meat. Adding bends to the legs and arms will create some more dynamic angles. Look at the shape of the left leg and then look at the shape of the right leg. The left leg is slender and sexy. The left calf and thigh have a lovely form. The placement of the right leg makes the leg look dull and almost lifeless.
4) Again, the horizontal orientation of the model’s right arm again creates a slab of meat. Bend the elbow more, bring the hand up off of the leg.
5) The position of her left hand looks almost painful. I suggest the model use her abdominal muscles to hold up her weight and gently glide her hand across the floor.
6) The model’s lower back is curved out. I suggest asking her to arch her lower back just a bit, at the very least so that the spine is neutral.
7) It looks as though the model’s black bra is poking out under the model’s left arm, but I suspect that is material from the dress. Either way, I find it distracting.
8) The selected dress isn’t a “sitting” dress. It doesn’t show off the model’s feminine form while sitting. It’s just a clump of material piled on to her body. It gives her a pooch in front and because it hangs in the back it makes the model look thicker than I suspect she really is. I suggest using an outfit that is more formfitting and mind the points where the material gathers (e.g., straighten out the material around the waist to emphasize the hour glass form).
Keep going. You’re doing great.
-r
Jan 04, 2009 at 05:10 PM
John Power
p.1 #20 · Melissa: More IMGs added
"If it bends, bend it" Never heard that one before and I suspect some might argue that there are many exceptions to that rule.
Jan 04, 2009 at 09:44 PM
