RodBarker Offline Image Upload: Off
p.1 #2 · Need Help Please with finishing this photo up | |
A few ways
Have the hat on its own layer , select the hat and add a mask to the layer , then apply gausian blur to the mask itself , if you have the mask reversed it will appear to not wont so if it dont work for you click in the mask itself and appy invert .
or
On hat layer select hat with magic wand , contract selection a few pixels then inverse selection so only just inside the edge to the outside is selected , either apply a blur , or knock the edge over by hand with the smudge tool .
You need to adjust the hue and saturation of both the hat layer and the green background layer to match the gorilla layer they are way too intense compared to the gorilla .
The white rim is burned out and to brilliant , it needs to be dirtied up a little and have the slightest tint of green to it as it would reflect the green foliage .
Its important the have all components on there own layer so you can adjust each separately , you can do it if they are all on the same the layer by using selections its just a little messier in cleaning up the edges .
Cheers Rod
