Parker_Dawson Offline Image Upload: Off
p.1 #5 · n00b flash/exposure question | |
Carmen Miranda wrote:
If you can get 1 more stop from your flash on your subject, then try ISO at 800 and reduce shutter speed to 1/100 to maintain the same ambient exposure and see if the flash is dominant enough to freeze the action with it's shorter duration.
Good luck
I will have 2 flashes on one end of the court. They will be attached to the ceiling somehow (the basketball court has a really high ceiling, I'm not sure how I will hang the flashes) and triggered with ebay slaves. Recycling time isn't a big concern, I'm just trying this out to see if it's worth getting Alien Bees or something better. So If I hang them in the corners, pointed to spread light around the center, by the goal, and set them to say, 1/4th power, would that be good enough? I'm wanting to go < ISO 1250, between 1/200th and 1/500th, f/2.8 maybe 1.8. I'm really not sure how this is all going to work out, so thanks for all help!
