2 end
5d mark ii xsync problem Go to previous topic Go to next topic
jeremymcknight
Image Upload: Off
p.1 #1 · 5d mark ii xsync problem
I'm having an issue with side vignetting when I shoot with strobes at 1/200. 1/160 it goes away. Has anyone else experienced this problem? here is a link to what I'm talking about.
http://www.flickr.com/photos/jeremymcknight/3082040132/
thanks,
Jeremy
Dec 04, 2008 at 03:01 PM
orangefirefish
Buy and Sell: On
p.1 #2 · 5d mark ii xsync problem
what focal length?
Dec 04, 2008 at 03:02 PM
jeremymcknight
Image Upload: Off
p.1 #3 · 5d mark ii xsync problem
Camera: Canon EOS 5D Mark II
Exposure: 0.005 sec (1/200)
Aperture: f/4
Focal Length: 43 mm
ISO Speed: 100
Dec 04, 2008 at 03:03 PM
Daan B
Image Upload: Off
p.1 #4 · 5d mark ii xsync problem
No true sync at 1/200
What does the manual/specs say about flash sync speed?
It will be interesting to see how other 5D2's fare regarding sync speed...
Dec 04, 2008 at 03:17 PM
blonde
Buy and Sell: On
p.1 #5 · 5d mark ii xsync problem
is this with studio strobes? as far as i know, the manual says that sync with strobes is about 1/60 but i had success all the way up to 1/160.
edit: just saw the images and read the image data so just ignore my above post.
Edited on Dec 04, 2008 at 03:21 PM · View previous versions
Dec 04, 2008 at 03:19 PM
jeremymcknight
Image Upload: Off
p.1 #6 · 5d mark ii xsync problem
This was with 580 EX II triggered by elinchrom skyports
BubbaJon
Image Upload: Off
p.1 #7 · 5d mark ii xsync problem
That would be my guess too - I've had issues with my 5D needing to be sync'd at 1/160 using studio lights. Gotta be a trigger delay issue. I don't have teh problem with my Elinchrom Ranger and Skyport - the only time was with my other lights and those Chinese radio remotes. So to the OP - what was being fired and how did you fire them?
Dec 04, 2008 at 03:23 PM
cineski
Buy and Sell: On
p.1 #8 · 5d mark ii xsync problem
The 5d I/II has a disabled shutter/sync. The mark 1 will only sync to 1/160th with pocket wizards. It's just a limitation that Canon built into the 5 series. You can step down or up to the 1D2/3 to get 1/250th. This is Canon being Canon, and it sucks.
Dec 04, 2008 at 03:25 PM
jeremymcknight
Image Upload: Off
p.1 #9 · 5d mark ii xsync problem
I just checked it with the flash on the camera and it is perfect at 1/200... this is probably a user error or skyports issue then?
blonde
Buy and Sell: On
p.1 #10 · 5d mark ii xsync problem
again, it is an issue with syncing via pocket wizards/skyports etc.. i never had that issue with my 1D bodies, only with the 5D... your only option is to sync at 1/160 or at 1/250 and just crop that side of the frame.
Dec 04, 2008 at 03:28 PM
BubbaJon
Image Upload: Off
p.1 #11 · 5d mark ii xsync problem
Whups - fast post above. So it may be the Skyports... try it without a radio trigger... eg a sync cord.
Dec 04, 2008 at 03:30 PM
CMOS
Image Upload: Off
p.1 #12 · 5d mark ii xsync problem
I'm totally ignorant on flash issues, really, but I thought I'd point out that with the 5D2 I noticed that, when using my 580EX, I can now see the flash firing through the viewfinder. On the original 5D, I always had viewfinder blackout during the flash.
Maybe the viewfinder blackout time is reduced for the 5D2 vs the 5D1? Or maybe there is something else at work.
Sorry to distract with what has probably nothing to do with your issue.
bka20d
Image Upload: On
p.1 #13 · 5d mark ii xsync problem
i believe the manual has a typo...1/60 should be 1/160, which is in line with the original 5d as it relates to the use of studio strobes...the speed for syncing with a speedlight is 1/200
Edited on Dec 04, 2008 at 03:36 PM · View previous versions
Dec 04, 2008 at 03:33 PM
Daan B
Image Upload: Off
p.1 #14 · 5d mark ii xsync problem
My guess would be a delay in the trigger system (slave) as well... try shooting one flash on the hot shoe and see how fast you can go before it darkens the frame.
Edited on Dec 04, 2008 at 03:34 PM · View previous versions
blonde
Buy and Sell: On
p.1 #15 · 5d mark ii xsync problem
did you check the "viewfiner on during exposure" custom function to make see if it is on or off? actually, the 5D might not have this option (i am thinking of my 1D for some reason).
blonde
Buy and Sell: On
p.1 #16 · 5d mark ii xsync problem
from the 5DmarkII manual:
"with studio flash units, since the flash duration is longer, set the sync speed within 1/60 sec to 1/30 sec."
Dec 04, 2008 at 03:41 PM
Daan B
Image Upload: Off
p.1 #17 · 5d mark ii xsync problem
It depends on the studio strobe (flash duration etc) and the (wireless) trigger system how fast you can sync with studio strobes. But a max of 1/60 is not good IMO. But anyway, the OP is experiencing troubles with TTL flash. He should get 1/200 according to the manual, but only gets 1/160... So it is probably a delay in the Skyports what is causing this
Dec 04, 2008 at 03:45 PM
schweikert
Image Upload: Off
p.1 #18 · 5d mark ii xsync problem
Also take into consideration that different wireless units have slightly different timing. I use PWs that work great BUT actually have slightly more shutter cutoff than a set of Cybersyncs that I use as well. And this is with speedlights, WLs, Comet packs, Dynalite that I own.
With my 5D I have always been limited to 1/160 with wireless triggers for a clean frame. With my 1Ds, it was 1/200, with my Mamiya AFD it's 1/90, 1/100 on AFDII. All of these are about a 1/3 stop less than rated x-sync. Just the way it is.
Now if you have a PW Multimax you can manually set the delay to the ten thousandths of a second which can offset some shutter cutoff partially or completely. I was able to get a 1DII to sync at 1/320, but that may have been attributed to the 1.3x frame, no way of knowing.
Leaf shutters are still the way to go if high sync is needed, aside from TTL methods.
Dec 04, 2008 at 03:49 PM
cineski
Buy and Sell: On
p.1 #19 · 5d mark ii xsync problem
Folks, it's a 5d shutter design issue. I've spoken to Canon CPS about this issue with the 5d and PW's and it's a limitation of the 5d. They literally said "Go to the 1d if you want 1/250th flash sync with strobes." Canon will always do this dumbing down to protect the 1D, and the 5d2 is no different, so we're stuck with 1/160th.
Dec 04, 2008 at 04:34 PM
Daan B
Image Upload: Off
p.1 #20 · 5d mark ii xsync problem
I don't own a 5D2 nor have I read its manual... but IIRC someone stated in this thread that according to the 5D2 manual the flash sync speed is 1/200... Furthermore, the OP gets 1/200 with one flash on the hot shoe... So what is going on here? My bet is still on a delay in the trigger system
Dec 04, 2008 at 04:55 PM
blonde
Buy and Sell: On
p.1 #21 · 5d mark ii xsync problem
we are confusing sync speed with speedlights and sync speed with strobes. the 5D can sync just fine with a speedlight at 1/200. with strobes, it is much lower.
Dec 04, 2008 at 05:06 PM
Daan B
Image Upload: Off
p.1 #22 · 5d mark ii xsync problem
Indeed we are
Strobe sync speed: 1/30-1/60
Flash sync speed: 1/200
Flash sync speed with Skyports/PW's: 1/160
How about that for a summary?
Dec 04, 2008 at 05:14 PM
Kim Bentsen
Image Upload: Off
p.1 #23 · 5d mark ii xsync problem
This is the same for all cameras. The specified best sync time is for Speedlites only. Anything else including triggers and strobes is slower - usually just 1/3 stop with a fast Elinchrom system.
Dec 04, 2008 at 11:29 PM
Chris Sorensen
Image Upload: Off
p.1 #24 · 5d mark ii xsync problem
Daan B wrote:
Indeed we are
Not quite right. The 5D, and based on what I know, the 5DII, will sync at 1/200 with on-camera Canon speedlights. Off camera, both strobes and speedlights will sync at up to 1/160 using sync cords or Skyports/PWs.
Dec 04, 2008 at 11:41 PM
lidesun
Buy and Sell: On
p.1 #25 · 5d mark ii xsync problem
No way, i used 5D with PW to triger ELs @ 1/200 sec all the time, never had a problem...
Dec 05, 2008 at 01:14 AM
2 end
Lost password?
