Hide Takahashi Offline Image Upload: On
p.1 #17 · Test posting lage hummer files | |
Hungtran10 wrote:
simply beautiful. your hummer shots are top notch. beautiful lighting and exposure. could you explain again how you set up your flash units. i posted a similar question on your previous post but i could not find it again to go back and read your response.
in regards to the larger pics, i agree that larger sized pics are better for appreciating the finer textures and details on the photos. lately i have been posting pics with 1000 pixels wide. we shoot with such high resolution cameras and high quality optical lenses. it would be shame not to post a larger pic because all those great details would not be as appreciable.
- hung
Thank you,hung, And I agree with you that we should post images in a large file size to show the real performance
of high resolution cameras and high quality lenses. I haven't done justice to my equipments..untill now.
O.K,here are my hummingbird flash shoot set up.
this is my setup.
2 flashes on both sides of your camera at 45 degrees and at about 20 ich. from
the flower. Both flashes are set at about 15 degrees above the line from the flower.
These two flashes will cast a shadow on the hummer's belly or throat area ,so to eliminate the shadow,the
3rd flash or the belly flash,is set under the flower at about 30 inc. from the flower.
This flash could be right under the lens or near that line,aligned with your lens.
The 4th one is an overhead flash. This one is a bit behind the flower set at about 25-30 inc. above the flower.
And the last one is for the background. Whether you'll need 5 flashes or 6 flashes,depends on how many flashes
you'll need for the background. If you use 2 flashes for the BG,then you won't have to worry about the light fall off on the BG.
Since I use one flash for the BG, I sometimes see the light fall off on the BG.
Here's another tip. I use a water pick and a floral foam ball to support a flower.
These are very good tools and to me,they are must-have items. You can get them here.
http://www.save-on-crafts.com/pewklips.html
I use a hummzinger feeder and I think this feeder is the best for hummingbird
shoots. It's flat and it has only a slim metal post to hung the feeder.
Suppose that the hummers are already coming to this feeder and then this is what I would do. I would tape off all the feeding holes
so that the hummers would not go to the feeder. Then I would put a floral foam ball (make sure you wet the ball)on top of the feeder and then
I would stick a water pick with a flower in it. You carefully spray a sugar water on the flower,align the angle of the flower.
You want to set your camera a little lower than the flower. This way, you'll have a better chance of seeing the hummer's beautiul full gorget.
Actually, the hummers will still go to the feeder's hole thinking that's where they used to get food but soon they will find the food on the flower.
Once they found it,50% of your work is done.
I hope this will help.
Hide
