c.d.embrey Offline Image Upload: Off
p.1 #1 · Tungsten lighting test. | |
We had 2 Lowel Tota-lights http://www.lowel.com/tota/ set-up for a video shoot, so I thought here is a chance to see what a Canon DSLR would do with 3200k lighting. Light on left bounced into white ceiling, lamp on right bounced off white wall.
Camera was in Program mode with auto white balance, just like many people would do. I could have done this all manually, but that's not how most people shoot in the real world.
Shot on left is .jpg straight from the camera, no correction. Shot on right is RAW file color corrected in Bibble Pro using click white eyedropper, no other corrections. Any RAW converter should work as well.
In the above shot the .jpg isn't too far off, but does need correction. Even though tungsten light doesn't have much blue in it, the blue bowl, after correction, looks just like you would expect.
In this shot the .jpg truly sucks ... big time. Camera does not have a clue. But RAW file still corrects nicely.
The first jpg is not too bad because there was a wide range of colors, gray wall, off white chair, white board and blue bowl for the camera to use to correct. The second, with only white (white board and mainly white shirt) and skin color, the camera does an abysmal job. Seems like digital cameras are fairly easy to fool.
