Lotusm50 Offline Dedicated FM Upload & Sell: Off
p.1 #18 · ZE/ZF WA: Strengths and Weaknesses | |
Justin D wrote:
The reasons I'm struggling to fall in love with the ZF:
bokeh is pretty average. Summicron bokeh was much better.
large and heavy for a lens of this FL/Aperture {snip}
comparatively expensive
Expensive compared to the Summicron?? The comparable 35/2.0 Summicron-R, whose bokeh you feel is much better, costs 3 times as much as the ZF. It seems to me that the ZF 35/2.0 is comparatively inexpensive (and there are others who prefer the ZF's bokeh, which I think is quite nice).
Justin D wrote:
perhaps TOO MUCH contrast which, I am beginning to suspect makes it appear sharper than it really is.
Sorry to be somewhat confrontational about this point, but I really don't know hat this means. It looks sharp but it really isn't?? (its also not clear how you could not know for sure, and only "suspect") I've heard this before (and usually in reference to a Zeiss lens), and it's as if lens contrast is used by the manufacturer as a fig leaf to disguise that the lens is actually a piece of crap. Contrast just doesn't make something "appear" sharp, contrast is responsible for sharpness -- whether you are talking about resolution or acutance. If a lens can't produce contrast between 2 items (like a line pair used in testing) it can't resolve them and won't be sharp.
I might also point out, that this business is all about "appearance". There is no real difference between something that "appears" a certain way, and what "is" a certain way. If it appears sharp, it almost certainly is sharp.
Justin D wrote:
Ultimately, IMO, the 35-70mm may be just as sharp, from comparing different images of different subjects, though I have yet to test them directly against each other (no digital body until 5DII ships). The 35-70 would have considerably more distortion at 35, though. They look fairly similar, too. I have been looking for the perfect 35 for a while, but it appears there isn't one.
Having both the 35-70 and the ZF 35, I would say that the 35-70 zoom only potentially reaches the capability of the ZF35 by f8.0 (where most competent 35mm focal lengths will perform similarly in terms of sharpness). So if you never intend to use the lens at an aperture larger than f8, then the 35-70 might meet your needs (other factors beyond sharpness will be more important -- but I think the ZF 35 wins here as well, except for cost and the zoom's macro-focus function if those are important to you). I do agree, however, with your point that there is no perfect 35mm. "Horses for courses", as they say.
