andrewd01 Offline Upload & Sell: Off
Roland W wrote:
The Gitzo S series tripod legs have a removable top area where you can mount the flat plate to use various heads directly, or buy a column assembly that mounts where the plate normally goes. This allows easy changing between both methods of use. The non S series have a column mounting system built in. The new series do have a way to remove the column, but it leaves the full column nut and clamping system in place, and is not quite as rigid as the S series when in the non column mode. Also, the non S units with the column removed do occasionally work loose in the field, so you need to keep an eye on them and keep them tight.
I would strongly recomend the S series to give the best stability for no column, and with the full versitility to add a column to the legs if you want it. You get a faster and easier change between column and no column, and you also can add a Gitzo leveling head to the S series.
Screw clamp vs lever clamp is a personal choice, but I find I really like the RSS lever clamps for speed and ease of use. Lots of opinions both ways, but you will find each works very well.
Thanks, really helpful post. I am leaning towards a lever clamp, as I like the idea of rapid switches to vertical shooting. Sliding the dovetail in at the end of a screw clamp sounds fiddly to me. The S series legs also sound like the best way to go. I can't remember the last time I used my centre column. I am generally not that fussed about the rig being eye level. If I have to stopp a few inches then so be it.
