Archive 2008 · 1D Mark 3 error 99
Tom Rouse
p.1 #1 · 1D Mark 3 error 99
I was to shoot a football playoff game tonight. I powered up my camera, pressed the shutter button and error 99 pop up and the shutter locked up until I powered the camera down. I could not get the camera to work. I left the batt. out for 30 minutes. Put it back in and again error 99. The batt showed 90% charged. I came home and put the batt on my charger for 2 mins. I them installed it back in my camera and now it is working. I guess my question is has this happened to anyone els and do I need to ship it to canon to test?
Thanks,
Tommy
Edited on Nov 22, 2008 at 11:20 AM · View previous versions
Nov 22, 2008 at 12:28 AM
Todd Ramsey
p.1 #2 · 1D Mark 3 error 99
Tommy,
I have a MkIII and have had an error 99 twice in a month. The first time it happened was a family trip to the circus. The second was a portrait session. Both times I was never able to get it working. I paid for shipping to Canon the first time. They paid shipping (both ways) the second time since it was for the same problem. I've had it back after the second "fix" for about a month now. I haven't had any more problems but it does concern me. I'd send yours in just to get it fixed and you're not left hanging in the middle of a gig.
Todd
Nov 22, 2008 at 12:46 AM
PasiM
p.1 #3 · 1D Mark 3 error 99
Happened couple of times to me. After few weeks it went dead.
It needed a whole new mirror box.
Nov 22, 2008 at 04:05 AM
Lord Fluff
p.1 #4 · 1D Mark 3 error 99
Someone I know had a similar problem which kept occurring - new body from Canon was the final answer
Nov 22, 2008 at 04:36 AM
brainiac
[X]
p.1 #5 · 1D Mark 3 error 99
What's a 1D mark LLL? ;-) Actually you might want to change that for the benefit of the topic search. Most people won't be searching for a mark LLL.
Nov 22, 2008 at 04:47 AM
dvarnav
p.1 #6 · 1D Mark 3 error 99
Error 99 in some cases had to do with shutter failure in any case you need Canon SERVICE right now
Nov 22, 2008 at 06:45 AM
AJay
p.1 #7 · 1D Mark 3 error 99
I had this happen to me with two different Mark III's. This was back in the early days of the Mark III and the only solution is to get the camera fixed. Although an error 99 is generic, it usually indicates a shutter problem.
~Alan~
Nov 22, 2008 at 07:11 AM
s23chang
p.1 #8 · 1D Mark 3 error 99
I had same issue. You should send it in to replace the mirror charger lever assembly.
Nov 22, 2008 at 08:28 AM
Tom Rouse
p.1 #9 · 1D Mark 3 error 99
I called Canon tech. support and they said If it happens again to call them back and they will send me a shipping label to send it in. N warrenty is good thru Jan.2009.
Thanks,
Tommy
Nov 22, 2008 at 11:16 AM
nctemper
p.1 #10 · 1D Mark 3 error 99
I had error 99 on my Mark III and it was NOT shutter it was the CF box..after the "fix" it came back worse then before...
a vendor replaced it with a brand new one...and I sold it. I lost my confidence ..
before error 99 I had
"lockup" NO focus...error1, error 6....
Nov 22, 2008 at 02:01 PM
nathanlake
p.1 #11 · 1D Mark 3 error 99
I had this happen the first week I owned the camera (September 2007). Has not happended since.
Nov 22, 2008 at 02:06 PM
SLD
p.1 #12 · 1D Mark 3 error 99
My second Mark III i got in June, 2007 had this problem, took the battery out, camera worked again, but didn't solve the problem, and the err99 even came up during a wedding, and finally returned it.....
In general err99 could be caused by anything, it's a general err code by Canon's words, but for Mark III most like the SM problem before the SM fix.
Try to clean all the contacts of the lens and body, if the err 99 still happens, send it in...
Good luck !
Nov 22, 2008 at 03:07 PM
Photodan34
p.1 #13 · 1D Mark 3 error 99
I had err99, sent it to canon and they said the camera was fine. they said It probably was a communication error with the lens. Check your lens contacts to see if they have any oil or such on them before you send it in. I cleaned all the contacts of my lens, wiped them off and the error did not reoccur.
Nov 22, 2008 at 06:01 PM
Emile Gregoire
p.1 #14 · 1D Mark 3 error 99
I get an err99 on both my bodies maybe twice a year. It's a pain in the *** but I've got spare batteries and those plus getting the lens off and on again usually solves the problem. If it's persistent, contact Canon, otherwise: don't worry.
Nov 22, 2008 at 06:12 PM
Tom Rouse
p.1 #15 · 1D Mark 3 error 99
When I called in the first thing the tech asked, "Are you using a vendors lens". He said usually the 99 error occurs on the Mark 3 with when using a non Canon lens. I was using a Canon 300. I did change lens and put on a Tamron, but still had the error. I even had the error without any lens attached. I also had 2 different brand cards in and it didn't matter which card I used, same error. I got home had the same error. I stuck my battery in the charger for about 2 minutes, then back in the camera. It worked and continue working all day Saturday. Now I will never trust my Mark 3 again.
Nov 23, 2008 at 09:56 AM
