Rules: One new topic per day
Archive 2008 · Entwined
night86mare
p.1 #1 · Entwined
One more from Bolderwood, New Forest.
Nov 18, 2008 at 04:01 PM
Cloudbow
p.1 #2 · Entwined
Is that one tree or two? It looks like two trees hugging. Entwined, as you said! The greens look a little heavy, but I'm a desert dweller so maybe my eye is just not used to seeing so much of it (on fences and tree trunks, etc.). I wonder if the green metal box behind the tree on the right could be cloned out?
Bev
Nov 18, 2008 at 04:22 PM
JimFox
Moderator
p.1 #3 · Entwined
Definately a cool looking tree. Did you get any closer shots? Having the fall colors around is for sure a nice bonus.
Jim
Nov 18, 2008 at 08:40 PM
night86mare
p.1 #4 · Entwined
Hi Bev,
I think it should be one. I'm not sure why it looks like this though.. I saturated this photo quite a little so maybe the greens a little heavy.. Ah, I didn't spot that metal box.. I think it's not impossible to clone it out.. Thanks for your comments!
Hi Jim,
Nope.. But what did you envision here?
Nov 18, 2008 at 09:20 PM
JimFox
Moderator
p.1 #5 · Entwined
Hmmm, I was kind of thinking a more intimate shot, portrait oriented, shot from lower to the ground to eliminate that asphalt walkway. The right edge of the shot lining up with the right edge of the tree, and the left being out a bit from the left side of the tree, far enough to capture some of the fall leaf covered branches. Shot from about the same angle here, so that the two different trunks are seen.
Jim
Nov 19, 2008 at 06:19 AM
CarloDidier
p.1 #6 · Entwined
Funny! Well seen. I'd like to see the crop Jim proposed, but I like it as is.
Nov 19, 2008 at 06:02 PM
night86mare
p.1 #7 · Entwined
Jim - Just the trunk with that ring of leaves around it? Yes, I think that would have been a great photograph. I am really quite bad at previsualising any closeups. Will definitely keep your suggestion in mind in the future.
CarloDidier - Thanks!
Nov 20, 2008 at 10:43 AM
