Macro World Resource
FM Forums | Macro & Still Life | Join Upload & Sell
Archive 2008 · Springtail mix
LordV
p.1 #1 · Springtail mix
As you will have gathered, Winter is springtail season but you do need a high mag system to capture them. All shots taken at 4 or 5:1 withan MPE-65 - some focus stacked.
Brian V.
Bit of a "bum" shot - but good for ID purposes
Camouflaged at last
A fairy godmother springtail ?
Springtail grazing - about 1.3mm body length
Different globular springtail. 0.92 mm body length
Nov 18, 2008 at 02:57 AM
e6filmuser
p.1 #2 · Springtail mix
Just to clarify, I think you are suggesting that springtails are among the few insects available in winter. They occur all the year round, although some of the plant-dwelling (epiphytic) globular ones are found only in the warmer months.
The purple grazer is an isotomid, possibly Vertagopus arboreus.
The purple globular one is probably one of the black Sminthurinus spp (Sminthuridae), requiring microscopic examination to identify to species and the genus needs revision anyway.
Nov 18, 2008 at 07:13 AM
LordV
p.1 #3 · Springtail mix
perhaps I should have said globular springtail season but even that is not strictly true. They just seem to become more visibly numerous in cooler periods.
Frans I'd those as Vertagopus arboreus and Sminthurinus domesticus respectively - so some agreement
Brian V.
Nov 18, 2008 at 07:26 AM
e6filmuser
p.1 #4 · Springtail mix
S. domesticus is generally a species of greenhouses and suchlike but I found a couple of males in moss in South Wales. S. niger is the same size and colour as domesticus and is common and widespread. The latter, according to Hopkin, usually has a yellow dorsal stripe.
Nov 18, 2008 at 09:09 AM
e6filmuser
p.1 #5 · Springtail mix
If you want to photograph Collembola with highly modified antennae, the following being the least spectacular:
http://www.stevehopkin.co.uk/collembolamaps/Symphypleona/407SPpum/
look for yellow globular species on the surface of ponds (at the base of marginal aquatic plants is good) but I am unsure of the seasonal occurence. Males of Sminthurides aquaticus have highly modified second and third antennal segments and their setae, for grasping the antenne of the female during mating.
Nov 18, 2008 at 09:24 AM
michael kilner
p.1 #6 · Springtail mix
v.nice love the 2 new finds
Nov 18, 2008 at 10:40 AM
MichAg92
p.1 #7 · Springtail mix
excellent series - like the fairy godmother the best
Nov 18, 2008 at 09:30 PM
LordV
p.1 #8 · Springtail mix
THanks for the comments and info everyone
Brian V.
e6filmuser - oddly the one place I don't seem to find springtails is around my ponds - I thought they be swarming there. Find them everywhere else- even on my car at the moment
Brian V.
Nov 19, 2008 at 01:41 AM
e6filmuser
p.1 #9 · Springtail mix
LordV wrote:
oddly the one place I don't seem to find springtails is around my ponds - I thought they be swarming there. Brian V.
I think it has to be a very long-established body of water. After all, an insect which doesn't fly, and would jump off any transient vertebrate doesn't travel too well.
Having said that, somewhere I have some preserved specimens of an exotic species which I found thriving on the surface of my tropical aquarium decades ago.
There are terrestrial species of Sminthurides, one of which was found in UK cereal fields.
Edited on Nov 19, 2008 at 02:56 AM · View previous versions
Nov 19, 2008 at 02:52 AM
LordV
p.1 #10 · Springtail mix
My ponds are over 20 years old mind you I do have a nice colony of water measurers (hydrometra) - maybe they eat them
LordV
p.1 #11 · Springtail mix
You may be interested in this comment by Frans on Flickr
"Note also that the species is easily confused with S. niger and S.concolor.
But based on the series of shots taken by Brian, only S.domesticus consistently shows the white and red spot at the inner side of the eye cluster. I consider this characteristic now as diagnostic for the species. "
Brian V.
Nov 19, 2008 at 06:34 AM
Igor Shuryak
p.1 #12 · Springtail mix
Wonderful shots. Is that a small mite in #3? Or just a plant bit that looks like one?
Nov 19, 2008 at 01:19 PM
LordV
p.1 #13 · Springtail mix
Thanks Igor
Think it's a bit of plant on the tail hairs of the springtail.
Brian V.
Nov 19, 2008 at 01:22 PM
Goldenorfe
p.1 #14 · Springtail mix
wonderfull fairy tail creatures!
phil
Nov 19, 2008 at 02:03 PM
LordV
p.1 #15 · Springtail mix
phil
Thanks Phil
Still waiting for the full herd of the globulars to build up like below.
Brian V.
Nov 20, 2008 at 01:52 AM
