2 3 4 end
Archive 2008 · New (used) Rokkor 21mm/2.8
PhotoMaximum
p.1 #1 · New (used) Rokkor 21mm/2.8
On a whim I purchased a nice looking MC W Rokkor-X 21mm/2.8 lens today.
This is the later "waffle" focus grip style. Body and glass seem really nice, especially for the price. From what I have read this is supposed to be a really sharp lens. The build quality seems excellent.
I am now waiting for Ed to convert his copy of this lens (shamelessly like a golfer watching another player's putt...)
I have converted the Rokkor 58/1.2 successfully so I hoping this will be no real problem?
Cheers,
Max
Nov 13, 2008 at 08:21 PM
JimBuchanan
p.1 #2 · New (used) Rokkor 21mm/2.8
Just a thought.
Check on whether this is a floating element design or not. I don't know. I believe the 21mm pre-dates the 20/2.8, which is floating element design. If the 21mm is too, you will be forced to use the subtractive method to adjust for infinity, which requires not going overboard in reducing the optical path.
Looks nice.
Nov 13, 2008 at 08:49 PM
PhotoMaximum
p.1 #3 · New (used) Rokkor 21mm/2.8
There is not a ton of info on this lens as far as I can tell.
I found this site: http://digitalrokkor.altervista.org/eos-photos.html
And the quote on this lens:
The Minolta MC W. Rokkor 21mm f2.8 was one of the best ultra wide angle lens made by Minolta and was the first to use a complex "floating elements design" (12 lens in 9 groups). It was annunced on the market on 1973 (first version on 1966) it looks as an impressive piece of glass and metal (it has a great solid construction !). It was one of the best wide angle, on 20-21mm range, with very hight optical performance second only to the "Zeiss Distagon 21mm f2.8.
A lens that is very difficul to find on the used market as its optical quality that is simply marvelous.
Nov 13, 2008 at 09:20 PM
JimBuchanan
p.1 #4 · New (used) Rokkor 21mm/2.8
There you go! Sounds very promising, too.
I've EOS adapted the 24/2.8 and the 28/2.0, both having the "FED". I didn't have to remove alot of optical path for infinity focus. There is a reference on the web that suggests the register difference is more like .275mm than .5mm that is widely quoted.
Good Luck!
Nov 13, 2008 at 09:29 PM
PhotoMaximum
p.1 #5 · New (used) Rokkor 21mm/2.8
I found out that Dim.ka has converted this lens to a 5D with infinity focus:
https://www.fredmiranda.com/forum/topic/633864/6
He has some nice shots on his site but I can't understand the language : he is from Latvia
Nov 13, 2008 at 09:35 PM
Ed Sawyer
p.1 #6 · New (used) Rokkor 21mm/2.8
I looked at mine briefly but haven't spent time with it yet. I think it should be doable, from eyeballing how much distance is between the rear element and where the stock bayonet ends. I think it might require a retaining ring shave but other than that should be doable.
It does predate the 20/2.8. I had forgotten that it has a floating element design (presuming the above is correct).
the hood is fairly rare too, hard to find, I don't have one.
I want to compare it to an Oly 21/3.5 (which I have) and an Oly 21/2 (which I don't have yet), plus 17-40L.
Indeed it's impressive, in build quality.
_Ed
Nov 14, 2008 at 02:32 AM
Ed Sawyer
p.1 #7 · New (used) Rokkor 21mm/2.8
I read the italian site, he stretches things a bit. It wasn't all that much more expensive than comprable offerings from oly, nikon, and canon.
I have a review in modern photo here somewhere, I will post it if I can find it soon.
-Ed
Nov 14, 2008 at 02:45 AM
PhotoMaximum
p.1 #8 · New (used) Rokkor 21mm/2.8
Glad you spotted this thread Ed. I was on the fence about getting this lens. Not sure if this is because not a lot of folks use it or if the IQ is so-so. What I have read indicates that the Rokkor 21 is a quality lens. I do know that they are not that easy to find. I think KEH lists two between the $250 and the $450 range.
Not sure how it stacks up against the Olympus offerings, the EF 16-35/2.8 or the famous 21mm Distagon. But I am in no hurry to convert it. Once I have done so it will be interesting to test it against some of these other wide lenses though.
I must say I am very impressed with the build quality though. This coming from a guy who never gave Minolta gear a second thought until stumbling onto this forum and learning about "rock star" Rokkors etc.
Any idea when you might tackle the conversion?
Cheers,
Max
Nov 14, 2008 at 03:48 AM
JimBuchanan
p.1 #9 · New (used) Rokkor 21mm/2.8
What a great Minolta lens link. A hit list of some of the top performers. I've had about 5 of them, but now down to 3.
Interesting concept, changing the mount base of the Canon camera to use native, unmodified Minolta lenses...
I guess one could make a case for a small travel system: possibly for less than a $thousand:
Canon EOS crop camera with the plain Minolta 28/2.0 as a faster normal lens. The MC50/1.4 for a short tele portrait. And the plain Minolta 85/2.0 for longer shots.
Nov 14, 2008 at 02:42 PM
cogitech
p.1 #10 · New (used) Rokkor 21mm/2.8
I'm surprised you didn't know about this. Pretty cool, eh?
Too bad the new mount is only compatible with a limited number of EOS bodies.
Nov 14, 2008 at 02:45 PM
Ed Sawyer
p.1 #11 · New (used) Rokkor 21mm/2.8
Max I'll try to work on that one next. I am in the middle of an FD-from-hell Vivitar 28 1.9 series 1 (which is supposed to be a kick-ass lens), that I should have done soon. The hard parts of that are done now. (I have another one in Minolta mount that should be easier, hopefully... ). Once I get the vivitar out of the way I'll work on the rokkor 21. I am sure the IQ of it is quite good, I have tried it on a minolta body and it's pretty nice. I haven't done any serious comparisons with it yet though. I had forgotten that it was a floating element design, I will have to look more closely into that.
Re: changing the mount on the EOS rather than the lens... not a bad idea, indeed too bad it's not engineered to work with more bodies.
One thing I was thinking would be cool (since I am all-film) would be get an Eos 1N-RS (pellicle, non-moving mirror) and put the Minolta mount on that. No mirror clearance issues! ;-) The world needs a pellicle mirror digital body I think.
Nov 14, 2008 at 05:57 PM
gasrocks
p.1 #12 · New (used) Rokkor 21mm/2.8
Aren't they about to come out with DSLRs that do not have a mirror at all? I would imagine some kinda LiveView LCD viewfinder. Not only would that prevent any clearance issues, but less camera shake and less delay.
Nov 14, 2008 at 06:40 PM
PhotoMaximum
p.1 #13 · New (used) Rokkor 21mm/2.8
Ed, I will keep watching for updates on your progress. I have only done one real lens conversion before, the Rokkor 58, but I bet the 21 will not be that bad. There are some noticeable differences at the back end of both lenses, but I think the same procedure (like Paul's 58 page) would apply.
It would be interesting to do a test with the Canon 20/2.8, Canon 16-35/2.8, Oly 21/2, Oly 21/3.5, Distagon 21/2.8 and the Rokkor 21/2.8. I would be OK sending my converted Rokkor to someone who has the other lenses to do such a test.
Once I get the conversion done I will be at least able to test the Canon 16-35/2.8 against the Rokkor though...
Nov 14, 2008 at 07:12 PM
cogitech
p.1 #14 · New (used) Rokkor 21mm/2.8
To make things simpler, but much less funny, omit the CZ21 and the Canon 20/2.8.
The CZ21 is too good to be included and the Canon 20/2.8 is too bad to be included.
Nov 14, 2008 at 07:17 PM
PhotoMaximum
p.1 #15 · New (used) Rokkor 21mm/2.8
Good point!
I have always enjoyed and used (needed) ultra wides. I really don't understand the all or nothing reasoning of "I don't use ultra wides therefore they are unnecessary" thread that is going on...
Nov 14, 2008 at 07:24 PM
Dim.ka_
p.1 #16 · New (used) Rokkor 21mm/2.8
I have both MC W Rokkor-X 21mm/2.8 and MC W Rokkor-NL 21mm/2.8 for Europian market and the last one has different bluish coating and last week received MC rokkor 20mm 2.8. So will convert them in near future and will show results.
Nov 14, 2008 at 07:26 PM
PhotoMaximum
p.1 #17 · New (used) Rokkor 21mm/2.8
I think the X version was for the US market?
Dim.ka, any tips or things to watch for in the conversion process?
Thanks,
Max
Nov 14, 2008 at 07:30 PM
Dim.ka_
p.1 #18 · New (used) Rokkor 21mm/2.8
X version was for the US market - that is correct.
A perfect tool will be a lathe - you need to do something like this
(although these samples are from 35mm convertion but 21mm will be in the same way)
Nov 14, 2008 at 07:46 PM
Ed Sawyer
p.1 #19 · New (used) Rokkor 21mm/2.8
DimKa -
How do you keep the rear element from falling out on that 35 1.8 conversion? I never took my rear rings down that far.. looks like nothing left!?
agreed 21 will be simliar to this.
This is about how I converted my 35 1.8s also.
There have been extensive shootouts on 21s here on FM a few years ago. Look for posts from Mike Hatam and others. I think the end result was the Ziess 21 was pretty much the best, the Oly 21/3.5 (and maybe 21/2) a close 2nd (better in a few ways), everything else after that. They didn't test a Rokkor 21 though.
-Ed
Nov 14, 2008 at 08:14 PM
PhotoMaximum
p.1 #20 · New (used) Rokkor 21mm/2.8
Dinka,
Thanks for the pics! Which part did you need the lathe for?
I shot a pic of the back end of the 21mm and did some color coding for reference.
* The "yellow" stuff gets discarded, no?
* The "red" rear element rings gets filed down?
* The "blue" ring stays but gets shaved for infinity focus like we all do on the 58/1.2?
* What happens to the "green" ring?
Thanks!
Max
Nov 14, 2008 at 08:23 PM
PhotoMaximum
p.1 #21 · New (used) Rokkor 21mm/2.8
It looks like you are grinding off quite a lot of material from the new EF mount: the flat outer part? This allows the new mount to sit inside the "blue" ring? (in my illustration)...
Nov 14, 2008 at 08:39 PM
cogitech
p.1 #22 · New (used) Rokkor 21mm/2.8
Max,
The one marked blue may look like the silver ring on the 58/1.2, but it is not. It serves an entirely different purpose. Seeing the "silver ring" and assuming the lens is constructed like the 58/1.2 is a mistake. It is nothing like that, and most of these lenses are nothing like the 58/1.2 in this respect. The conversion process is significantly different.
The ring marked green is not a ring. It is the actual mount base. The silver ring is just a shroud over the mount base. It is the mount base that needs to be reduced (see Dmitry's second shot, it is silver because it has been reduced and the bare metal is exposed).
Like I said, completely different than the 58/1.2.
Nov 14, 2008 at 08:42 PM
Dim.ka_
p.1 #23 · New (used) Rokkor 21mm/2.8
Max, so
* The "yellow" stuff gets discarded, no? Yes throw it away (you need to unscrew it from the inside - four screws)
* The "red" rear element rings gets filed down? Yes as low as possible, actually i unscrew holding ring and glue the back lense in place - the answer for -Ed
* The "blue" ring stays but gets shaved for infinity focus like we all do on the 58/1.2? it stays as is (maybe it will need a bit to sand) and take a role of outer surface of original M42 adapter - where you drill a hole for EOS bayonet stopping pin.
* What happens to the "green" ring? Green ring has to be thinned by lathe and then you could screw in inner part of M42 adapter (also needed to thin with lathe)
you see all stages of the process here
Edited on Nov 14, 2008 at 09:12 PM · View previous versions
Nov 14, 2008 at 08:57 PM
Ed Sawyer
p.1 #24 · New (used) Rokkor 21mm/2.8
Max you have it mostly right. Blue and green become the new lens mounting surface for the zero-addition EOS bayonet (flangeless).
Paul is correct re: the ring purpose. However it does get shaved down a little but it's not a spacer, it's the actual mount surface (in this new paradigm).
in the 35 1.8 at least (and I think the 21 also) the minolta bayonet is removable, via screws. That allows replacement with an EOS bayonet, after removing the flange. I nest the 2 together and make them one piece, then use original screws/holes in the minolta bayonet to hold it on.
-Ed
PhotoMaximum
p.1 #25 · New (used) Rokkor 21mm/2.8
Thanks Guys!
I just opened it all up and I can see what you are talking about...
Nov 14, 2008 at 09:03 PM
2 3 4 end
