2 3 4 end
Archive 2008 · FAQ For Canon to Nikon
Avi B
p.1 #1 · FAQ For Canon to Nikon
Seems there is some small demand for a Canon to Nikon FAQ. So I am starting this thread. I will put in the questions that I have seen pop up multiple times, and answer them to the best of my ability. I am sure that someone will fix up my answers as appropriate
1. Why is Nikon called the "dark side"?
I don't know. The lenses are nice and black, so that you don't stand out in the crowd
2. What lens will work on my new Nikon?
Short answer, all of them will mount. Any Nikon F-mount lens will mount on a modern day DSLR. Please note that you should not mount pre-AI F-mount lenses on modern bodies (D40 is an exception).
Long answer, it depends on which camera you have as to the functionality you get depending on lens.
- On D40/D40x/D60 you will not get autofocus with non-AFS or non-AFI lenses. This means lenses that have screwdriver mount (AFD/AF) lenses will not AF. All AF lenses will meter.
- On all other camera bodies, AF lenses will AF and meter properly.
- If you have a AI/AIS lens (manual focus only!) then you can mount it on any camera, and it will meter with the following camera bodes: D1 series bodies, D2 series bodies, D200, D300, D700, D3.
- If you have a AI/AIS lens, with the exception of D1 series bodies, you can input the non-CPU lens data into the camera so that the f-stop and lens info appear correctly in the EXIF. Note that regardless of what you enter, the camera WILL meter correctly in ambient light instances (ie if you have info in there for a 35 f/1.4 but you put on a 28 f/2.8, the camera will meter correctly for your set aperture even though the EXIF will be wrong). If you have incorrect lens data for the lens (on a camera that supports metering with non-CPU lenses) flash metering will not work correctly as it requires correct aperture info to meter correctly.
- AI-P lenses work like screwdriver AF lenses on the D40 series (metering, no AF) and meter on all bodies.
- "D" versus non-"D" lenses: D means distance information is sent to the camera, seems to only affect flash shooting. Note that there are AF lenses that are non-D.
The D1/D2/D3 bodies turn the screwdriver lenses the fastest (personal experience says D1 series AF the fastest out of those).
3. My new Nikon shows number of shots on top LCD, how do I turn it off?
You can't. This is a feature.
4. How do I make my new Nikon go into auto-shut off?
You can't. The camera's meter will time out after a set number of seconds (selectable in the menu). This mode is very low power consumption, so it is not a problem. If you hit the shutter or AF buttons, the camera will spring back to life, ready to shoot.
Its a tiny 1bit display that takes virtually no battery power from the battery. Think of a digital watch, it has 10 times the information, and the battery lasts for years and years, and those batteries are only 1/15th the mAh.
5. Is the AFON button the same as the * button?
It's close. You can separate out the AF function onto the AFON button just like the * button. However, the VR function will only activate on shutter half-press.
6. I have heard you can use the electronic rangefinder to help focus manual focus lenses?
Yes, this is true. Simply put the focus point on the object you want help to focus (be aware that you need sufficient contrast on your object), then press the AF-ON button, or half-press the shutter button. Look in the viewfinder, in the lower left corner, you will see a green dot light up when the object is in focus. Note that this works on ALL Nikon DSLRs. The pro bodies actually have arrows that tell you which way to turn the focus ring in order to achieve correct focus.
7. Which are the lens replacements for my Canon setup?
? ---> Nikon 14-24 f/2.8
Canon 16-35 --> Nikon 17-35 f/2.8
Canon 24-70L --> Nikon 24-70 f/2.8 (28-70 and 35-70 are also contenders depending on your finances)
Canon 70-200IS ---> Nikon 70-200VR or AFS 80-200 f/2.8
Canon 35L --> No real equivalent, but older AIS 35 f/1.4 is nice. AFD 35 f/2 is closest match these days
Canon 85L --> Nikon 85 f/1.4 Nikon has a different rendition and faster focus
Canon 70-200 f/4 ---> No exact equivalent, but the 70-300VR is very good
8. My lens is an autofocus lens and has an aperture ring and I can't get it to work, help?!?
Check to see that you have the lens set to its smallest aperture and locked in place with the tab. If not, you can always use the aperture ring, just go to Manual exposure mode. You need to have the lens set to its smallest aperture in order for the camera to have electronic aperture control (the ability to select aperture from the camera).
9. Is EF-S like DX?
No, EF-S is a smaller mount, whereas DX is the same F-mount, just with a smaller image projection. A DX lens projects about 44% of the image as compared to a FX (or film) lens. The DX lens will work on your FX camera, if you want to use it, just be prepared for vignetting (in FX mode) or 44% less MPs (in DX mode).
10. What is "ED"?
A glass developed and trademarked by Nikon Corporation, used in telephoto lenses to obtain optimum correction to help prevent chromatic aberration, improving sharpness. These lenses are resistant to temperature changes, preventing focus shift problems in lenses that use calcium fluorite crystal elements.
This is similar to UD + flourite elements that Canon uses to achieve similar results. You will find there are a lot consumer glass even that has ED elements these days, which is a good thing for us consumers
11. What is the equivalent of USM?
This is AF-S (Silent Wave Motor).
Well, that's all I can think of now.
Cheers!
Edited on Nov 20, 2008 at 02:28 PM · View previous versions
Nov 04, 2008 at 03:34 AM
turnert
p.1 #2 · FAQ For Canon to Nikon
Avi,
Good FAQ to start. But to add to #2, please note that you should not mount pre-AI F-mount lenses on modern bodies (D40 is an exception).
Here's a good reference:
http://www.nikonians.org/nikon/slr-lens.html
~Ted
Nov 04, 2008 at 03:52 AM
kjcramer
p.1 #3 · FAQ For Canon to Nikon
Great stuff Avi, very helpful to recent converts like myself. Thanks!
Nov 04, 2008 at 03:54 AM
mawz
p.1 #4 · FAQ For Canon to Nikon
Note also for #2 that if you have incorrect lens data for the lens (on a camera that supports metering with non-CPU lenses) while ambient light metering will work just fine, flash metering will not as it requires correct aperture info to meter correctly.
Also AI-P lenses work like screwdriver AF lenses on the D40 series (metering, no AF) and meter on all bodies.
Nov 04, 2008 at 04:15 AM
BenV
p.1 #5 · FAQ For Canon to Nikon
Edit on #4:
This is a feature, you cant turn it off. Its a tiny 1bit display that takes virtually not battery power from the battery. Think of a digital watch, it has 10 times the information, and the battery lasts for years and years, and those batteries are only 1/15th the mAh.
Nov 04, 2008 at 04:21 AM
BenV
p.1 #6 · FAQ For Canon to Nikon
8. Do you guys have EOSfun on the Nikon board?
Nov 04, 2008 at 04:22 AM
turnert
p.1 #7 · FAQ For Canon to Nikon
Canon converts should also know about the more resourceful Nikon-related websites. I could list some of my favorites here, such as Bjorn Rorslett's lens reviews (www.naturfotograf.com), but you never know what someone needs to know.
So here's a link to all of the links:
http://www.nikonlinks.com/equipment_main.htm
~Ted
Nov 04, 2008 at 04:33 AM
monochrome
p.1 #8 · FAQ For Canon to Nikon
Isn't that guy gone? I haven't seen a post from him in a while. Sounds like the rumor of him being a troll was true.
Nov 04, 2008 at 04:39 AM
Avi B
p.1 #9 · FAQ For Canon to Nikon
Okay, great points all. Thanks. I will go and update the original post with edits.
And no. Please no mention of that guy. Let's keep this thing on topic shall we? Merci.
Nov 04, 2008 at 04:45 AM
monochrome
p.1 #10 · FAQ For Canon to Nikon
I learned over the weekend that the newer Nikon lenses with the aperture rings need to be set to 22 and they'll work with no problems.
Nov 04, 2008 at 04:53 AM
Avi B
p.1 #11 · FAQ For Canon to Nikon
Actually newer Nikon lenses with aperture rings will work just fine with the aperture ring if you put it in M mode. Otherwise if you want electronic control of aperture, then yes, you need to set it on the smallest aperture of the ring (eg AFS 300 F4 has F32 as smallest aperture) and lock it.
Nov 04, 2008 at 04:56 AM
jkittmer
p.1 #12 · FAQ For Canon to Nikon
That kinda sucks.. or is there a benefit to this I am missing?
Nov 04, 2008 at 05:47 AM
RCicala
p.1 #13 · FAQ For Canon to Nikon
Most helpful. Tag.
Nov 04, 2008 at 11:17 AM
Craig Yannuzzi
p.1 #14 · FAQ For Canon to Nikon
Almost spit out my coffee on this one
Great Job Avi! As another recent convert I have already found this thread helpful!
Nov 04, 2008 at 12:46 PM
Avi B
p.1 #15 · FAQ For Canon to Nikon
It's different. Just be aware. I will not make a judgement call for you I think it's better because you can focus independently of the VR kicking in and giving you a headache, but you may feel differently
Nov 04, 2008 at 01:13 PM
mkchang
p.1 #16 · FAQ For Canon to Nikon
You guys are awesome!
Nov 04, 2008 at 02:30 PM
BenV
p.1 #17 · FAQ For Canon to Nikon
he wasn't really a troll, more of just extremly annoying with his own catch phrase for everything he has ever said.
Nov 04, 2008 at 03:08 PM
traveler
p.1 #18 · FAQ For Canon to Nikon
On #1:
Nikon has used black as their typical designated color as Canon chose their off white/grey color due to use of Flourite in their lenses. The lighter color avoids higher tempertures being transmitted to the lens elements in direct sunlight as this can damage the flourite lens elements. Nikkors have no such issues as they don't use that material.
Nov 04, 2008 at 03:09 PM
EOS20
p.1 #19 · FAQ For Canon to Nikon
Great stuff!
Can you set the AF To "Beep" to confirm focus? (I can't seem to work out how to do it on my new D300).
Nov 04, 2008 at 03:41 PM
Sam Bennett
p.1 #20 · FAQ For Canon to Nikon
Technically speaking EF-S mount isn't "smaller", it just has a portion that protrudes enough into the mirror box from preventing it from being mounted to bodies that don't support it. This is due to the fact that Canon decided to take full advantage of the extra space available when you make the mirror smaller, with some of their lens' rear elements extending well into the mirror box. You can get around this with some lenses by simply removing the back of the lens, which I outline here. Have to be careful which focal lengths you use, but it works.
Nov 04, 2008 at 03:52 PM
monochrome
p.1 #21 · FAQ For Canon to Nikon
Yes, and the warning you didn't mention is that putting a EF-S lens on a EF body, the mirror can slam into the EF-S lens because it's too far into the camera.
Nov 04, 2008 at 03:56 PM
Sam Bennett
p.1 #22 · FAQ For Canon to Nikon
It's mentioned in the thread I linked to, and it's what I was implying by saying "be careful of the focal lengths you use".
Nov 04, 2008 at 04:06 PM
jkittmer
p.1 #23 · FAQ For Canon to Nikon
Thanks for the response.... not a big fan of that I don't think... so essentially when the shutter is pressed to take the picture is the VR then activated? or is there not enough time for it to get started up and actually work?
I really like the separate focus button on my Canons with IS on that button as well.. This whole thing isn't a deal breaker and it is not like VR is disabled it is just different and may take a bit of rewiring on my part....I am not doing too bad if that is the only "complaint" I can come up with..
Thanks!
Nov 04, 2008 at 10:13 PM
Avi B
p.1 #24 · FAQ For Canon to Nikon
No it's just that it saves more battery this way I guess. VR usage does have a marked decrease in battery life. Anyway I am guessing as to why they did it this way. I like it myself, so no complaints from me
Nov 04, 2008 at 10:19 PM
jkittmer
p.1 #25 · FAQ For Canon to Nikon
cool..thanks for the response..
Nov 04, 2008 at 10:28 PM
2 3 4 end
