lexvo Offline Dedicated FM Upload & Sell: Off
p.1 #20 · DPreview of 50D is flawed ..please read | |
Sorry, the DPR test may be flawed, but so is your reasoning
If the lens resolution is 70lp/mm, then the total system resolution can never exceed that value.
In your example, the total resolution of the 50D would be:
1/70 + 1/105 = about 1/42 also a total resolution of: 42 lp/mm
the total resolution of the 40D would be:
1/70 + 1/86 = about 39 lp/mm
That's pretty close or not
The point is that a sensor with more pixels, always will give a higher total resolution, regardless of the lens used. Thus: one can still use the same lens to compare different sensors.
Oh, and one more thing: IIRC, you cannot just derive the sensor resolution from the number of horizontal pixels.
If you want to learn more about resolution see this site:
http://www.normankoren.com/
