bob.tullis Online Image Upload: Off
p.1 #11 · Delaware Water Gap Waterfalls | |
Tony Curado wrote:
so here is another one of the first not so blown out but looks a little dark to me what do you guys think?
Yes, it is a bit dark, but it's a much more complete presentation than the blown ones (once you spot repair that dust mote from the flow area). There's detail in the flow that really makes a difference, as it's rather the subject.
If this is from the same image (or the same HDR series), I expect it's just (sic?) a matter of being able to eke out the best of the shadows and highlights, which comes with practice. To answer the Q from up-topic, I really can't advice on the HDR technique. I used Photomatix, found it confusing, went to Enfuse (search google for "wiki enfuse"). But when I tired of the little control over the blend method, returned to Photomatix and just plugged away at it, often having to do an image more than once (had to let the results sit for a day at times, to better assess). Between the Tone Mapping and the subsequent PS processing, it's hard for me to guide, unless we take a particular image and walk through the process (holler if you like).
Keep at it, as it's part of the path we've all had to take.
