Jman13 Offline Image Upload: On
p.1 #18 · How best to clean fungus. | |
So I got a chance to look at the images at home, and I'm surprised...there is a rather significant different in the performance of my Super-Takumar and the S-M-C Takumar...the S-M-C has higher contrast wide open, seems a smidge sharper, and has nicer bokeh. Honestly, my S-M-C is approaching my Rokkor 58 f/1.2 for pure image quality. Interestingly enough, the S-M-C has a warmer color cast, despite the Super-Takumar having the yellowed thorium element. Interesting.
Unfortunately, it still has that fungus under the front element. When I got home I cleaned the rear element and I don't see a single trace of the fungus left on it. The front element has been thoroughly cleaned, and you honestly wouldn't know it was the same lens if you'd seen it before. The glass is in VERY good shape except for that little bit of fungus. I found a disassembly guide, but the first step involves unscrewing the front plate, which is threaded into the filter threads. Unfortunately, the filter ring on this lens is bent, and I can't seem to get the front plate to move (I need to get a rubber stopper or something to spin it, but even if I can get it to move, I don't know if I'll be able to get it off.
Currently, it doesn't appear to affect image quality at all. However, I want to kill any further growth, and I don't want it to etch the glass if it hasn't yet. Any suggestions? Is there a way to kill the fungus without disassembly? Suggestions?
Here's a (bad) pic of the fungus...as you can see it's just at the edge...for now:
