Archive 2008 · *How to keep your body warm*
Hide Takahashi
p.1 #1 · *How to keep your body warm*
I usually don't go out to mountain area to photograph birds during fall/winter,
because it gets quite cold in the desert,though it never snows in town. But I will do it this year.
If you live in a cold country side,how do you keep yourself warm when you're outdoor for hours?
I did a little research on that and I found "Grabber Body Warmer". It's an adhesive heating pad and
it looks like/sounds like a good tool to keep your body warm.
Has anyone used it before? if so,what is your experience?
Hide
Oct 13, 2008 at 12:03 PM
deedee4re
p.1 #2 · *How to keep your body warm*
Years ago, I was a pro skiier living up in Vail, Colorado. I also taught ski school there.
The one thing I learned is the weather can change from sunny to blizzard conditions in 15 minutes, so I had to be prepared to survive.
Head and Face. You lose 90% of your body heat through your head. If it's really cold, I suggest a jacket with a hood on top of a hat. I would also suggest a "gator" around your neck that you an pull up over your face up to your eyes.
Wool is used in the back country because if it gets wet, it still retains heat. I'm not sure about the newer fabrics - if they do the same thing. They didn't used to.
Gloves are a must. I carry one extra battery in my pocket so I can replace it to keep my camera going. I have not used my Mark III in cold weather yet (cold = below freezing for me) This did work with my 10D and 30D though.
I also carried those hand warmers that you could activate and they would immediately get warm and stay warm for up to 8 hours.
Long underwear is a must as is a turtleneck. The new expensive long underwear works well.
If you have a tripod, make sure it has an area that you can hold that is not metal or the cold will go right to your hands through the gloves.
That's about all I can contribute.
DeeDee
Oct 13, 2008 at 12:20 PM
Hide Takahashi
p.1 #3 · *How to keep your body warm*
DeeDee,
Thanks for your good suggestions. These are very useful information.
Hide
Oct 13, 2008 at 01:01 PM
Dennis H.
p.1 #4 · *How to keep your body warm*
Hide
I work outdoors year round.
It is best to layer your clothing
start with a layer of material that will wick the sweat away from your body, there are a lot of man made materials that are good for this, I use merino wool
then a layer of wool ( which is a second layer of wool) for me, like the previous poster said wool will keep you warm even when it is wet
several layers are better than one heavy layer as you can adjust your clothing depending on what you are doing
then an outer layer to protect from moisture and wind, I really prefer a goretex outer layer even though it is very expensive
do not forget a hat and gloves I really like wool there
sounds like I am a fan of wool, yep
Dennis
Oct 13, 2008 at 01:27 PM
Lil Judd
p.1 #5 · *How to keep your body warm*
Hide,
coming from Sweden I have some feedback as well....
Get a ski cap which covers your face & just leaves your eyes exposed. Layer, layer, layer your cloths.
I second Merino wool - - especially the thin kind. In layers.
Make sure you have good socks & boots. Full ski overalls is a great way.
Good luck
Lil
Oct 13, 2008 at 05:06 PM
72chevelle454
p.1 #6 · *How to keep your body warm*
Under Armour
Expensive but great stuff
Oct 13, 2008 at 05:10 PM
Hide Takahashi
p.1 #7 · *How to keep your body warm*
Dennis H. wrote:
Hide
Thank you, Dennis. These are another good suggestions. It seems like "wool'
is the best choice to keep you warm.
Hide
Oct 14, 2008 at 12:57 AM
Hide Takahashi
p.1 #8 · *How to keep your body warm*
Lil Judd wrote:
Hide,
Good luck
Lil
Thank you, Lil. The merino wool sounds like a must-have item.
Hide
Oct 14, 2008 at 12:59 AM
Hide Takahashi
p.1 #9 · *How to keep your body warm*
72chevelle454 wrote:
Under Armour
Thank you, I'll check it out.
Hide
Oct 14, 2008 at 01:00 AM
Johnny Bravo
p.1 #10 · *How to keep your body warm*
I've learned specific techniques for dealing with the coldest temperatures that enable me to stay warm, dry and comfortable in any conditions.
First, get a map of the US. Look for areas in the south that have cities with names that sound warm. Phoenix, San Diego, Miami for example.
Move there.
Beats the crap out of 'wool'.
Oct 14, 2008 at 07:54 AM
