Moderated by: guardian
Archive 2008 · Damn high speed sync Go to previous topic Go to next topic
Photofiend4
Image Upload: Off
p.1 #1 · Damn high speed sync
So I bought a 580 ex a while ago thinking hey this will go perfect for getting some fill flash in my skate sequences (30D 5FPS) WRONG. It's worked great for lighting indoor situations with its little built in white card, but I finally got some skate shots in yesterday and was sadly disappointed to find that with high speed sync it fires on the first shot and then quits for the entire 12 picture sequence (at least in RAW). Is this what I should have expected or is there something I am doing wrong?
Oct 11, 2008 at 05:27 PM
turnert
Image Upload: Off
p.1 #2 · Damn high speed sync
Your flash can't recycle fast enough to keep firing while you mash down the shutter at 5 fps. If your aperture, distance, and ISO are such that the flash only needs minimal power for each frame, you can probably get off a few shots. But under normal conditions, even without high speed sync, the recycle time is longer than the frame rate.
~Ted
Oct 11, 2008 at 05:31 PM
farley
Image Upload: Off
p.1 #3 · Damn high speed sync
That is what you should have expected. There are a number of external battery packs that will decrease the recycle time, but even then the best you will probably get is two or three frames. Not only that, but in high speed light will not get out there very far.
Oct 11, 2008 at 05:36 PM
simon_says
Image Upload: Off
p.1 #4 · Damn high speed sync
I doubt you'd find many (if any!) flash units that can cope with such high firing rate. Even if you could find a way to force it, you'd end up destroying them by burning them or have them melt!!!
Oct 11, 2008 at 05:37 PM
ICQ
Photofiend4
Image Upload: Off
p.1 #5 · Damn high speed sync
Too bad. Looks like I'm gonna stick to shooting in raw and doing local adaptation.
Oct 11, 2008 at 05:52 PM
Suparman Widja
Image Upload: Off
p.1 #6 · Damn high speed sync
Hmm. Why not use 2nd-curtain in this case? You can also bump up the ISO so the flash does not have to consume that much power (and recycle faster).
Oct 11, 2008 at 05:58 PM
krementz
Image Upload: Off
p.1 #7 · Damn high speed sync
2nd curtain has nothing to do with the OP issue. You can't 2nd curtain with high speed flash, anyway
Reducing the amount of power the flash needs, (higher ISO) will help, but not solve the issue. Banging off a dozen flashes at full speed - I doubt any camera mounted flash can do this - and especially at hi-speed sync.
You might try shooting at the synch speed and give your flash a better chance of catching up. PRobably will give you toomuch motion blur.
Oct 11, 2008 at 06:18 PM
genoph
Image Upload: Off
p.1 #8 · Damn high speed sync
I found the 580 EXII could pop off five or so at 6.5 FPS before tiring out. just as fill though
Oct 11, 2008 at 06:19 PM
Gochugogi
Image Upload: On
p.1 #9 · Damn high speed sync
High speed sync vastly reduces power as it's a rapid pulsing of the flash. If it actually fired at fully output, you need 6 seconds to recycle, even with fresh batteries.
If the flash is the main light (weak ambient), try a long shutter speed with the flash in strobe mode. I used to do this with film and would get half a dozen sharp images on a frame.
Oct 11, 2008 at 06:20 PM
Mark Peters
Buy and Sell: On
p.1 #10 · Damn high speed sync
I had a big metz unit (Mecablitz 60 CT-4) that had a winder (2 fps) and motor drive (6 fps) mode. It was incredibly low power however.
Heavy and awkward for sports, but it has the feature you're asking about.
http://www.metz.de/fileadmin/fm-dam/Download/Photo_Electronic/Bedienungsanleitung/mecablitz/mecablitz_48_bis_76/mecablitz_60_CT_4_D_F_NL_GB_I_E.pdf
No idea if you will end up with a dark band if you try shooting at faster than say 1/320th.
Oct 11, 2008 at 06:24 PM
Photofiend4
Image Upload: Off
p.1 #11 · Damn high speed sync
Wow. That's a crazy flash.
Oct 11, 2008 at 06:32 PM
Gil_W
Image Upload: On
p.1 #12 · Damn high speed sync
By using the Cannon battery pack, I found the 580EX can do fairly good keeping up when shooting a burst with the lower fps rate of the 40D but not too well at the faster fps.
Gil
Oct 11, 2008 at 08:50 PM
Lost password?
