dcains Offline Buy and Sell: On
p.1 #5 · where is entrance pupil point on 17-55 f/2/8 please help | |
Roland W wrote:
A fast way to get close is to set your aperature to F22, and do a stop down of the diaphram of the lens with the depth of field preview button. While stopped down, look into the front of the lens, and estimate how far into the lens the diaphram blades appear to be located. Tilt the lens from side to side to help with your guess. That process will produce a very good estimate. From there, if you need to, you can use the standard process to refine it. And yes, most zoom lenses change when the focal length is adjusted.
Also, if you have the aperture stopped down, and remove the lens from the body while holding the DOF preview button, the aperture will stay stopped down with the lens off the body.
