Enir Offline Image Upload: Off
p.1 #21 · D90 - overexposure problems | |
90 5.0 wrote:
Andre Labonte wrote:
1st, do yourself a favor and never ever go to KR's site. He is an idiot.
2nd, check your D-lighting setting. D-lighting can do this.
3rd, Those mountains are dark and will cause the meter to read low. Meter off the sky and fix exposure based on that.
4th, if you want to reduce your exposure issuse, learn to manual expose everything. Understand Exposure by Bryan Peterson is a great place to start.
I agree with you on the most part except the use manual exposure all the time part.
Learning about exposure will help a ton, but there is no reason not to use ap. You have to learn your camera as well. It seems all to often these my camera meters wrong posts come up, but in actuality there is no wrong metering , only interpreting what you feel as "correct". With the age of digital cameras and technology metering accuracy is getting better and better but no two cameras meter the same. It's just the way it is.
Exposure compensation is on all camera's for a reason, it needs to be there.
Start out by learning how your camera meters in a certain lighting situation, I suggest starting off in bright light because thats the easiest and the one you seem to be having a problem with.
Learn the "Sunny 16 rule" for proper exposure in direct light and see where your meter is.
Go to ap setting with d-lighting off
Set your aperture to 16 and iso 100 or , since your native is 200 on that cam do 200.
At f/16 200 iso meter off of green grass or grey/light brown tree bark. Your meter should tell you 1/200 is the exposure length it chooses. If not use exposure compenstaion to make it that way.
Ie, it gives a reeding of 1/400 you know that is a full stop overexposed so set the compensation to -1 and shoot .
Now compare the compensated exposure to the original, and expose to taste.
After a while it will be second nature to adjust your exposure to the way your camera acts and the way you like your pics to come out.
I know my D80 overexposes +7 in harsh bright light on bright objects and under -3 in shadows on dark objects. Shooting manual which i normally do i know depending on what i am pointing at if i should be above or below the metering mark.
But for action, bif and other rapidly moving /changing conditions i use ap and set my ex. comp, and can change it on the fly whit the thumb wheel a lot faster than chasing the manual meter in and out of shadows.
On Kens site there is a ton of information, some of it good some of it bad take it all with a grain of salt and use what works for you from there.
I might suggest buying a photography book and going from there.
I find John Shaw's books to be excellent.
http://www.adorama.com/BKJSNPFG.html?sid=1223660947644601
Thanks for your tips. I would also like to make clear that I have been in photography for some 40 years, so I roughly know what I'm doing, including the f/16 1/ASA rule. But I had my D90 for just a few days and admit I don't know it well yet. It is also my first Nikon reflex.
Kind regards,
Enrique
