2 3 end
Archive 2008 · EOS 5D Mark II: full-resolution, uncompressed clips from ...
GregM5
p.1 #1 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
Three original, full-resolution, uncompressed clips from Laforet Visuals REVERIE
Clips
Sep 27, 2008 at 04:07 PM
krobatshov
p.1 #2 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
I don't like the fact that it's 30p... but hey - it's taken with a dslr
thanks for sharing
Sep 27, 2008 at 04:19 PM
GregM5
p.1 #3 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
I did notice a bit of a stuck pixel problem... but what the heck, the movies are pretty amazing for a dlsr.
Sep 27, 2008 at 04:23 PM
ward1066
p.1 #4 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
I played it on my 52 inch LCD TV and it looks darn good, I used a apple tv and converted the .mov file to a mp4 in visualhub. This converted the file to 10mb h.264. Wonder if the camera has different file formats and compression settings?
Sep 27, 2008 at 04:59 PM
pcunite
p.1 #5 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
To play the files correctly with VLC...
Download the latest from videolan.org and do the following:
H.264 codecs are pretty CPU intensive and VLC can't use multi-cores to decode it yet.
1. Open Tools/ Preferences
2. Click Show settings = All
3. Go to "Input/Codecs
4. Go to "Other codecs/ FFmpeg" subcategory
5. Set "Skip the loop filter for H.264 decoding" to ALL
6. Restart VLC
Sep 27, 2008 at 06:01 PM
Beni
p.1 #6 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
My dual 2.2ghz with 3 gig ram can't play these clips without serious pauses/sticking, what do you need, a quad core as minimum?
Sep 27, 2008 at 07:32 PM
John Power
p.1 #7 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
This is beginning to sound like its more trouble than its worth....
Sep 27, 2008 at 07:51 PM
canerino
p.1 #8 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
i have about the same setup as you and mine lags as well
Sep 27, 2008 at 08:14 PM
Beni
p.1 #9 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
Just imagine what editing the videos must be like then!
Sep 27, 2008 at 08:17 PM
canerino
p.1 #10 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
wow, what a buzzkill.
Sep 27, 2008 at 08:18 PM
skibum5
p.1 #11 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
if you have powerdvd 7 or 8 and a somewhat more recent graphics card that has FULL h.264 HW decoding you can play it on almost any CPU. For whatever reason, either .mov header bug that QT ignores, or some new header than only QT understands yet or powerdvd bug there is no audio though.
quicktime doesn't appear to take advantage of any HW accel on windows machines and it basically it's on eo fmy least favorite and worst performing multimedia players. it does play the audio though.
anyway on socket 939 AMD 4400+ X2 with QT it is really choppy
with powerdvd it is smooth as silk (I do have one of the latest ATI cards that happens to have full h.264 decoding, I think any nvidia 8800 or higher so long as not the 640MB 8800 version has full h.264 decoding as do the 2 newest ATIs and I think their previous generation too)
there are some videocards out there now in under $100 range that have the full 5.264 HW decoding, so if you use a decent program and not quicktime junk, it'll be silky smooth and not even get your cpu above 20% usage.
Edited on Sep 27, 2008 at 08:30 PM · View previous versions
Sep 27, 2008 at 08:29 PM
moondigger
p.1 #12 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
The full clips play with slight pauses/hiccups in the motion on a 2.33 GHz iMac C2D. This is most visible in the clip in which the male lead walks across the frame from left to right. However, converting it to 1080i rather than 1080p allowed it to play smoothly on the same computer. Converting to 720p also allowed smooth playback.
Hask
p.1 #13 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
6. Restart VLC
Thanks, this makes it run smoothly on my quad core machine
I do see all cores being used when I play the vid though.
Sep 27, 2008 at 08:42 PM
swanny338
p.1 #14 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
my puny 2.4Ghz Core 2 Duo iMac with 4gigs runs them just fine no lag what so ever. I will try them on my older dual 2.7 G5 later.
Sep 27, 2008 at 08:47 PM
moondigger
p.1 #15 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
Mine is only 70 MHz slower... and I'm seeing slight hiccups on the clip I mentioned above. Put up your Movie Inspector window during playback and see if you get the full 30 fps during playback. Mine's fluctuating between 24 and 27 fps. When I convert the clip to 1080i, I get 30 fps.
Sep 27, 2008 at 08:56 PM
c00kiem0nster
p.1 #16 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
my 2.4 ghz quad core computer with 4 gigs of ram plays those videos smoothly! i use quicktime btw.
and for my taste they look incredibly good coming from a camera that is supposed to 'only take photos'.
Sep 27, 2008 at 09:56 PM
LiquidAir
p.1 #17 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
The key to playing back smooth H.264 is a codec which offloads some of the processing to the video card. The higher end Macs all have as part of Quicktime, but you need to pay some attention to your choice of codec and video card to get the same on a PC.
My MacBook Pro plays the clips back fine, but my Dell XPS desktop doesn't come close despite having a faster processor, cache and bus. If I end up editing a lot of H.264, I am going to upgrade my video card to one which supports H.264 decoding.
Sep 27, 2008 at 10:03 PM
dcmiller
p.1 #18 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
Not a problem at all on a macbook pro. You may have noticed in the "making of" video what they were using to edit.
Sep 27, 2008 at 10:21 PM
dcmiller
p.1 #19 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
The quality looks great to me. I'm not going to be picking it apart frame by frame, however. I'll leave that to the RED users.
Sep 27, 2008 at 10:23 PM
Gochugogi
p.1 #20 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
Probably something wrong with your configuration. I just played the helio clip full screen in QT on my 23" Cinema Display and it was smooth and beautiful--not a single hiccup. Damn that was good! Well, the sound suked. And I'm running a 2004 Apple G4 Duo (1.25GHz x 2) with ATI 9600 & only 2GB RAM. I haven't tried it on my MacBook Pro (2.2GHz CoreDuo) but it's never had problems with HD content.
Sep 27, 2008 at 11:57 PM
ward1066
p.1 #21 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
you can also reduce the file size and not notice a huge reduction in quality. This video is 1920x1080, you can convert it in Quicktime pro ($20) to around 1280x720 HD h.264 and it will look just as good on your moniter and play easier.
Sep 28, 2008 at 03:14 AM
moondigger
p.1 #22 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
Actually, there probably isn't anything wrong with Beni's config. See below.
I just played the helio clip full screen in QT on my 23" Cinema Display and it was smooth and beautiful--not a single hiccup. [...] I'm running a 2004 Apple G4 Duo (1.25GHz x 2) with ATI 9600 & only 2GB RAM.
There's no way in heck a Dual 1.25 G4 could handle those full-res clips without serious stuttering/frame drops. So the H.264 decoding must be offloaded to the ATI 9600 on that box.
It will have problems with these clips, if the video card doesn't do H.264. A 2.2 GHz CoreDuo doesn't have quite enough power to decode these clips at the full 30 fps.
Sep 28, 2008 at 03:35 AM
swanny338
p.1 #23 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
For the very first second it says 27fps and then stays put at 30fps. I have music playing and most of my normal apps open.
Sep 28, 2008 at 04:40 PM
moondigger
p.1 #24 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
It's gotta be the video card, then. Mine has the NVIDIA 7600 GT. I'm guessing yours has one of the newer ATI cards that does hardware decoding of h.264.
Sep 28, 2008 at 04:57 PM
Beni
p.1 #25 · EOS 5D Mark II: full-resolution, uncompressed clips from REVERIE
I have the same NVIDIA.
Sep 28, 2008 at 05:13 PM
2 3 end
