astrolucida Offline Upload & Sell: Off
p.1 #25 · Exposure Compensation -- Why? | |
alfarmer wrote:
Hmm. I'm not sure the point of my question is getting through to most responders, so let's assume always shooting in Aperture priority mode for a second.
When shooting snow or a white suite in daylight, I could certainly adjust exposre by +2 or -2. But it's MUCH easier and quicker to dial the big fat knob that adjusts shutter speed.
Well, this is exactly how exposure compensation is changed in Canon DSLRs! So you are using exposure compensation. When the aperture is fixed in the Av mode, the only way to change the effective exposure is to change the shutter speed. Thus, e.g. dialing in +1 for exposure compensation (you can see it in the viewfinder, too), results in doubling the exposure time.
alfarmer wrote:
And this leads to the one scenio not mentioned thus far, and the one case I can think of for my personal usage of Exposure Compensation -- low light settings where adjusting the shutter speed or ISO might result in unacceptable blur or noise.
No, exposure compensation does not help that because it changes those exact parameters, resulting in exactly the same results as if you had manually selected the same settings. There is no exposure compensation function like the one you seem to be thinking of.
Let's summarize:
- exposure settings consist of aperture, shutter speed and ISO,
- for ISO you can either pick the value or use Auto (in some cameras),
- you can set both the aperture and the shutter speed if you use M mode,
- you can set the aperture in Av mode and the camera sets the shutter speed,
- you can set the shutter speed in Tv mode and the camera sets the aperture,
- the camera will set both shutter speed and aperture in P mode.
When the camera decides some of the values, it is basing that decision on the built-in exposure meter. If you want to change that decision, by a relative value, you dial in exposure compensation (-2 to +2 with 1/3 stop steps). If you want to set the absolute values, you use M mode. In that case, you will see, in relative terms, how the camera would set the exposure values, in the viewfinder.
Edited on Sep 05, 2008 at 11:52 AM
